gkreidl
Re: Kodi 15 Packages for Raspbian Wheezy & Jessie for RPi2
Fri Jan 15, 2016 8:07 am
fever3 wrote:Firstly thanks a lot for sharing your work!
I'm looking for a matching IPTV client for your KODI 15 on Jessie.
I found that you are refering to pipplware for this topic. Do you have a link to share? The link I found on one of the posts seams to be not working...
http://pipplware.pplware.pt/pipplware/
Minimal Kiosk Browser (kweb)
Rascas
Fri Jan 15, 2016 1:01 pm
Here it is:
http://pipplware.pplware.pt/pipplware/d ... in/binary/
rjotto
Tue Jan 26, 2016 11:21 am
Hello!
I am using KODI 15.2 on top of Raspbian Jessie.
I am searching for a guide or a tutorial on how to install TVHEADEND Backend server application.
I searched the officail repository and all I can find is kodi-pvr-hts which is the frontend add-on I suppose.
I have used TVHEADEND in an older version of OPENELEC and it came preinstalled but I think it is not anymore.
So please help me out!
gkreidl
Tue Jan 26, 2016 11:53 am
rjotto wrote:Hello!
http://tvheadend.org/projects/tvheadend ... Repository
rjotto
Tue Jan 26, 2016 2:04 pm
gkreidl wrote:
rjotto wrote:Hello!
Thank you very much! I wil try to install it tomorrow.
pontypool
Fri Jan 29, 2016 6:37 pm
can you install all the optional os from noobs into jessie
gkreidl
Fri Jan 29, 2016 6:45 pm
pontypool wrote:can you install all the optional os from noobs into jessie
Which "optional OS"?
kodi is a program like any other and not an OS by itself.
pontypool
Fri Jan 29, 2016 8:03 pm
i hate to keep asking questions, as i feel like im pissing people off, but how do i access sources on kodie? it says something about needing a username and password. i suppose you need to pay for some sources? probably finding a way to access those servers is against the rules on this forum.
the southpark server worked great. love that show. but some of the sports live streams didn't
mathboy4life
Fri Jan 29, 2016 8:39 pm
pontypool wrote:i hate to keep asking questions, as i feel like im pissing people off, but how do i access sources on kodie? it says something about needing a username and password. i suppose you need to pay for some sources? probably finding a way to access those servers is against the rules on this forum.
You want always working sports, if so then pay your cable provider, don't pay pirate apps that offer's you validated credentials after purchase.
asapreta
Sun Jan 31, 2016 1:19 pm
Hello guys.
I reached this page because I'm having problems running simple IPTV client. When I try to activate TV on my Kodi 15 I get an error that it can't be loaded. I'm using Retropie Wheezy (3.3.1) and even using it new Kodi 15 experimental script (that installs 15.2), the PVR problem continues.
So I decided to get a full working package.
But, even following the uninstall/install procedures on the OP I get these errors when installing:
pi@retropie /kodi-15 $ sudo ./install
Reading package lists... Done
Building dependency tree
Building data structures... Done
(Reading database ... 85601 files and directories currently installed.)
Unpacking kodi (from kodi_15.1-150901-3_armhf.deb) ...
dpkg: error processing kodi_15.1-150901-3_armhf.deb (--install):
 trying to overwrite '/usr/lib/kodi/addons/library.xbmc.addon/libXBMC_addon-arm.so', which is also in package kodi-bin 2:15.2-2~wheezy
dpkg-deb (subprocess): decompressing archive member: internal gzip write error: Broken pipe
dpkg-deb (subprocess): cannot copy archive member from 'kodi_15.1-150901-3_armhf.deb' to decompressor pipe: failed to write (Broken pipe)
dpkg-deb: error: subprocess <decompress> returned error exit status 2
Preparing to replace libplatform1 1.0.9-1 (using libplatform1_1.0.9-1_armhf.deb) ...
Unpacking replacement libplatform1 ...
Setting up libplatform1 (1.0.9-1) ...
Can you guys help me out?
Thanks in advance.
gkreidl
Sun Jan 31, 2016 5:40 pm
Remove the older version before installing the new one.
sucdejan
Mon Feb 01, 2016 12:48 pm
Can IMDB addon be installed from repository or manually on Kodi15?
gkreidl
Wed Feb 03, 2016 8:42 am
sucdejan wrote:Can IMDB addon be installed from repository or manually on Kodi15?
Answering questions about installation of certain addons is beyond the level of support I can give.
gkreidl
Wed Feb 03, 2016 8:46 am
Unfortunately someone published two video tutorials on youtube pointing to my kodi-15-Jessie version with the following titles:
How To Install Raspbian and Kodi / XBMC On The Raspberry Pi 2 or 1
and
How To Install Kodi In Raspbian Jessie Raspberry pi 1 , 2 , Zero
This is complete crap, of course, because my packages have been compiled for ARMv7 and will only work on RPi2, as is clearly stated in the title of the OP. And also all additional instructions etc. from the OP are missing.
This will lead to a lot of useless downloads and also to frustration of users of Pi1 and Pi0. And of course the author does not mention that people should avoid multiple downloads.
I'm not responsible for this. My only chance to avoid unneccessary and useless downloads (by people not using an RPi2) is to rename the Jessie package again.
It's unbelievable what kind of "experts" are publishing "tutorials" these days.
asapreta
Wed Feb 03, 2016 1:28 pm
gkreidl wrote:Remove the older version before installing the new one.
Thanks for the answer, but still no luck after removing the old version.
gkreidl
Wed Feb 03, 2016 5:52 pm
It looks like you are not using a standard Raspbian image. I have no idea how I can help you.
mathboy4life
Thu Feb 04, 2016 2:50 am
You are using retropie that's why it doesn't work for you. :twisted:
mrkrinkle
Tue Feb 09, 2016 10:19 pm
Hello.
I was able to run 15.1 Wheezy just fine. Thank you!!
But I want the updated version you offer.
I'm unable to run Jessie 15.2.
kodi doesn't auto load after I reboot.
If I attempt to load it manually, by entering "startkodi" I get, "/usr/local/bin/startkodi: line 8: kodi: command not found".
Here is exactly what I am entering, when attempt to install 15.2.
sudo apt-get update
sudo apt-get upgrade
wget http://steinerdatenbank.de/software/kod ... rpb.tar.gz
tar -xzf kodi-15.2-jessie-rpb.tar.gz
cd kodi-15-jessie
sudo ./install
(Does this code below need to be added for Jessie?
In your post you were unsure.)
sudo addgroup --system input
sudo nano /etc/udev/rules.d/99-input.rules
SUBSYSTEM==input, GROUP=input, MODE=0660
KERNEL==tty[0-9]*, GROUP=tty, MODE=0660
sudo nano /etc/udev/rules.d/10-permissions.rules
# input
KERNEL=="mouse*|mice|event*", MODE="0660", GROUP="input"
KERNEL=="ts[0-9]*|uinput", MODE="0660", GROUP="input"
KERNEL==js[0-9]*, MODE=0660, GROUP=input
# tty
KERNEL==tty[0-9]*, MODE=0666
# vchiq
SUBSYSTEM==vchiq, GROUP=video, MODE=0660
sudo usermod -a -G audio pi
sudo usermod -a -G video pi
sudo usermod -a -G input pi
sudo usermod -a -G dialout pi
sudo usermod -a -G plugdev pi
sudo usermod -a -G tty pi
sudo nano /boot/config.txt
gpu_mem=160
sudo nano /etc/rc.local
#run Kodi as user pi
su – pi -c startkodi&
gkreidl
Wed Feb 10, 2016 4:07 am
Do you have Jessie installed?
Did you get any error messages during installation?
Running from rc.local might not work any more because it is run earlier by systemd, but putting a
sleep 10
before the startkodi line might help.
mrkrinkle
Wed Feb 10, 2016 3:59 pm
gkreidl wrote:Do you have Jessie installed?
sleep 10
Thanks for your reply!
Yes, I confirmed that Raspbian GNU/Linux 8 (jessie) was installed after the upgrade.
I received no errors during install.
I'll try the sleep 10 later tonight.
gkreidl
Wed Feb 10, 2016 4:47 pm
First run it manually from a terminal or the commend line:
startkdodi
you could also try:
kodi-standalone
If you get the message, that kodi cannot be found, something went wrong during installation.
GTR2Fan
Wed Feb 17, 2016 4:40 pm
Thank you, gkreidl. Following the instructions in the opening post worked like a charm on an up-to-date Raspbian Jessie on my Pi2B. :)
chewy74
Sun Feb 21, 2016 7:35 pm
Hey gkreidl, any plans to offer up kodi 16 (Jarvis)?
https://kodi.tv/kodi-16-0-jarvis-mark-xvi/
gkreidl
Sun Feb 21, 2016 9:19 pm
chewy74 wrote:Hey gkreidl, any plans to offer up kodi 16 (Jarvis)?
No.
stastka
Mon Feb 22, 2016 8:58 am
Try this:
If you want Kodi to automatically start when the system boots, edit /etc/default/kodi and change ENABLED to 1:
# Set this to 1 to enable startup
ENABLED=1
# The user to run Kodi as
USER=kodi
# Adjust niceness of Kodi (decrease for higher priority)
NICE=-5
I have successful installed kodi 15.2 under raspberian jessy
dany
Computer scientist, Photographer and Webpublisher.
My site is my lab http://stastka.ch
Return to “Raspberry Pi OS”
