Rascas
Re: Kodi 15/16 Packages for Raspbian
Wed May 25, 2016 9:08 pm
sn2016 wrote: Thank you for you help. The reason I have not posted to Kodi official forum is because the problem is unique to my RPi3 installation. I have no issue with my Nexus Player Kodi app. Anyway, I have created a thread there ( https://forums.tvaddons.ag/getting-star ... v-add.html ).
You have only 64 MB of RAM for the GPU. You have to set at least 128 MB, 160 MB for FullHD/High bitrate videos. 256 MB is the recommended for RPi 2/3.
Avie02
Wed May 25, 2016 9:25 pm
Sorry for the late response, the version is kodi 16 and you guys were spot on as the problem was related to the stream being mpeg2. After purchasing the license, everything is running great. Turns out I could have just changed the encoding in my tuner to h264 but oh well the license is a cheap purchase. Big thanks to you guys for the great build and info.
sn2016
Thu May 26, 2016 3:44 am
Thank you very much. I had a typo in my config file.
Rascas
Thu May 26, 2016 1:47 pm
Avie02 wrote:Sorry for the late response, the version is kodi 16 and you guys were spot on as the problem was related to the stream being mpeg2. After purchasing the license, everything is running great. Turns out I could have just changed the encoding in my tuner to h264 but oh well the license is a cheap purchase. Big thanks to you guys for the great build and info.
I don't think you can change the encode type of your TV provider streams, unles you do some sort of real-time reencode.
aik
Re: Kodi 15 Packages for Raspbian Wheezy & Jessie for RPi2
Sat May 28, 2016 11:11 am
Rascas wrote:I bet that it is your user "aik" that hasn't the right permissions set.
How are you running Kodi, from the desktop, terminal or auto-start at boot ? Are you running Raspbian Jessie ? You can turn the debug on in kodi and check the log file.
I got distracted a bit :) The problem is still present on my kodi and I am surprised it is not fixed in the latest builds...
The problem is: whenever Kodi shows a virtual keyboard (search addon dialog, etc), it does not accept keyboard input and treats it as player shortcuts, for example - space is always a pause and it never enters a space character. I doublechecked permissions:
aik@aikrpi ~ $ grep aik /etc/group
tty:x:5:aik,kodi
dialout:x:20:pi,aik,kodi
audio:x:29:pi,aik,kodi
video:x:44:pi,aik,kodi
plugdev:x:46:pi,aik,kodi
input:x:999:pi,aik
lpadmin:x:108:root,aik
aik:x:1002:
I checked all the steps from setup guide, all is there, tried without addons, no difference.
Answering your last questions:
1. I run kodi via a shortcut in XFCE, the process is "/usr/lib/kodi/kodi.bin --lircdev /var/run/lirc/lircd"
2. yes it is jessie debian (PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)")
3. I turned debug on, tried typing "space" in a search window and got this:
20:53:54 72609.132812 T:1944420352 DEBUG: Keyboard: scancode: 0x39, sym: 0x0020, unicode: 0x0000, modifier: 0x0
20:53:54 72609.132812 T:1944420352 DEBUG: OnKey: space (0xf020) pressed, trying keyboard action f020
20:53:54 72609.132812 T:1944420352 DEBUG: OnKey: space (0xf020) pressed, action is Pause
And "Pause" is what really happened.
Kodi version is:
aik@aikrpi ~ $ apt show kodi
Package: kodi
Priority: optional
Section: video
Installed-Size: 28.2 MB
Maintainer: wsnipex <wsnipex@xbmc.org>
Version: 2:16.1-3~jessie
Any way to fix the problem or it is just by design? Thanks.
gkreidl
Sat May 28, 2016 11:29 am
tty:x:5:aik,kodi
input:x:999:pi,aik
aik:x:1002:
Kodi version is:
Package: kodi
Priority: optional
Section: video
Try
sudo chmod 0777 /dev/tty0
before starting kodi.
If that works, add
to
/etc/rc.local
(above "exit 0")
Minimal Kiosk Browser (kweb)
Rascas
Sat May 28, 2016 4:17 pm
tty:x:5:aik,kodi
input:x:999:pi,aik
aik:x:1002:
Kodi version is:
Package: kodi
Priority: optional
Section: video
I still think that is a permissions problem. Try running Kodi as root, just to test it, if it works, that's permissions problem.
aik
Mon May 30, 2016 1:09 pm
gkreidl wrote:Try
This helped, thanks mates!
gkreidl
Mon May 30, 2016 2:01 pm
aik wrote:
gkreidl wrote:Try
Then you can add to rc.local
and it will always work.
rasplumino
Fri Jun 03, 2016 5:35 pm
does anybody know if there is Kodi 16 available in official sources?
The archive.raspberrypi.org repository only has 2:15.2-2~jessie 0.
pi@raspberrypi:~ $  apt-cache policy kodi
kodi:
2:15.2-2~jessie 0
500 http://archive.raspberrypi.org/debian/ jessie/main armhf Packages
regards
Rascas
Fri Jun 03, 2016 8:04 pm
Not from official sources. But you have Kodi 16 packages, check the first post.
kxb3292
Mon Jun 06, 2016 5:03 am
I have installed raspbian on my new raspberry pi 3 and I have kodi v16 on top of it. I have followed a tutorial to set the system in read only mode.
Once, it is is read only mode, if i try to launch kodi. It tells me gives me the following error message
Could not init logging classes. Permission errors on ~/.kodi (/home/pi/.kodi/temp/)
Error: Unable to create application. Exiting
Could't get a file descriptor referring to the console
It looks like kodi needs to write some logs to launch. Is there any way I can make it write those logs to a different location (RAM)? or disable writing logs altogether so that it works when the SD card is in read only mode?
Thank you so much.
Rascas
Tue Jun 07, 2016 3:28 pm
kxb3292 wrote:Hello,
Thank you so much.
I don't know, but I think not. Better check the Kodi Wiki and/or ask the same question in Kodi official forum.
bleep42
Fri Jun 17, 2016 6:26 pm
Hi Rascas,
I'm using your version of Kodi 17. Unfortunately it is now crashing if I try to play a h265 file, I'm assuming other Pi updates since March have broken it, any chance you will be updating it?
Many thanks. Kevin.
Rascas
Fri Jun 17, 2016 6:45 pm
bleep42 wrote:Hi Rascas,
Many thanks. Kevin.
That is strange. Earlier this week I was showcasing a RPi 3, recently updated with that Kodi 17 version and it played some h265 test files just fine. I will try again on monday, i am out this weekend.
I was expecting to compile a new Kodi 17 version when the first beta comes out.
bleep42
Fri Jun 17, 2016 9:43 pm
Many thanks. Kevin.
Ok thanks, don't worry for the moment then. I am using the very latest kernel 4.4.14 I think. I'll look forward to the beta.
Thanks Kevin.
bleep42
Sat Jun 18, 2016 2:31 pm
Hi Rascus,
For your information, I have now reverted to kernel 4.4.11-v7+ #888 and your build of Kodi 17 is again working fine when displaying h265 video files. :-)
Regards, Kevin.
hawkeyexp
Sun Jun 26, 2016 12:14 am
Will we see a newer build of kodi 17 in next time ? last build is from march.
bleep42
Sun Jun 26, 2016 11:07 am
hawkeyexp wrote:Will we see a newer build of kodi 17 in next time ? last build is from march.
Hi, Try reading the two or three posts just above yours!
baxalo
Tue Jul 05, 2016 4:50 pm
Hallo..
I make fresh install of jessie and install kodi 16.1
When i try to play a movie i have only sound and no picture.
Before fresh install it works fine but now i have this problem.
anyone have any idea?
thnks.
gkreidl
Wed Jul 06, 2016 4:59 am
baxalo wrote:Hallo..
thnks.
GPU Memory?
baxalo
Wed Jul 06, 2016 1:42 pm
thnks.
GPU Memory?
256
Rascas
Wed Jul 06, 2016 3:12 pm
thnks.
Please post your Kodi log. Get it here after reproducing the problem:
/home/pi/.kodi/temp/kodi.log
Or follow this instructions:
http://kodi.wiki/view/Log_file
baxalo
Thu Jul 07, 2016 11:19 am
I reinstall the jessie and kodi and all is fine now.
I don't know what was the problem.
After reinstall i see the answer of Rascas.
Anyway, Thnks a lot.
b1990liam
Sat Jul 16, 2016 5:26 pm
Hi I'm a total noob to pi & Linux.
I have bought a pi2 and have managed to install raspbian Jessie and got kodi 15.2, I have been reading many post regarding adding deb http://pipplware.... but from start to finish how exactly do you do this ?
Return to “Raspberry Pi OS”
