I was able to compile xbmc as described on the raspbian page (pisces) and it's working fine so far! Your work is very much appreciated and I will definitely stay with raspbian for various reasons! I have one problem so far (which isn't solved on raspbmc and openelec too) and thats the xbmc ac3 sound over the analog output. It has got way to low volume and I can't raise it (and btw the audio on xvids (mp3) could use some more headroom too). I can raise the volume of the tv (Im running a euro PAL analog tv) but that leads to slight distortions/noises. The provided signal is just too weak!
Things I tried:
- Increase the normal xbmc volume
- Increase the "super-" volume in the audio settings during playback (no effect at all)
- play around the advancedsettings.xml audio settings: ac3downmixgain + headroom (no effect at all)
- /etc/asound.conf:
pcm.!default {
type hw
card 0
ctl.!default {
type hw
card 0
- alsamixer aumix ("cannot open mixer: No such file or directory" / "error opening mixer: No such file or directory")
Any suggestions? Is this a known problem being worked on? I need help!
