karlharv
Problem : illegal instruction
Sun May 24, 2015 1:18 pm
Hi, I have a problem since a dist-upgrade I think.
Can't use anymore Sudo command.
I don't think the content of the source.list file has been changed.
Can't find any solution to this on internet.... please help !! ;-(
Re: Problem : illegal instruction
Sun May 24, 2015 1:57 pm
karlharv wrote:Hi, I have a problem since a dist-upgrade I think.
It should be all lower case sudo and not Sudo ;)
Joe Schmoe
Sun May 24, 2015 2:05 pm
Yes, but that typo is unlikely to cause an "illegal instruction" trap.
karlharv
Sun May 24, 2015 9:02 pm
Don't worry about the typo... any idea why i get this ?
Mon May 25, 2015 9:01 am
If you haven't changed anything in sources.list, then the only thing I can think of is a corrupt file.
Pi 1 or Pi 2?
There are various checks you can do to see if the sudo file is ok
Check it is the right general CPU type (ARM not i386)
rpdom@raspi5 ~ $ file /usr/bin/sudo
/usr/bin/sudo: setuid ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.26, BuildID[sha1]=0x2911544d109eb20766d56dce67962a69d29bdcb1, stripped
Then make sure it is ARMv6, (although v7 will work on a Pi2)
rpdom@raspi5 ~ $ readelf -A /usr/bin/sudo| grep CPU
  Tag_CPU_name: "6"
  Tag_CPU_arch: v6
Of course it might not be the actual sudo file which is wrong, it could be one of the libraries it uses. You'd need to look at using strace to find out where the error is happening and if it comes to that amount of work you might want to consider backing up what you can and reinstalling. :(
Return to “Raspberry Pi OS”
