n0rc
CPAN fails when I run install
Mon Jul 23, 2012 1:25 pm
When I try to install ANYTHING or run update I get:
Going to read '/home/pi/.cpan/sources/modules/02packages.details.txt.gz'
Warning: Your /home/pi/.cpan/sources/modules/02packages.details.txt.gz does not contain a Line-Count header.
Please check the validity of the index file by comparing it to more
than one CPAN mirror. I'll continue but problems seem likely to
happen.
How do I fix this?
saif
Re: CPAN fails when I run install
Mon Jul 30, 2012 6:42 am
I struggled to install cpan modules myself
I eventually used cpanminimus
Steps 1) get cpanm
sudo apt-get install curl
sudo curl -L http://cpanmin.us | perl - --sudo App::cpanminus
cpanm will often fail, because the gcc version installed is 4.6
Step 2) install gcc-4.7
sudo apt-get install gcc-4.7
Step 3) Install the modules you want e.g.
sudo cpanm XML::Parser
nemo096
Thu Jul 18, 2013 9:32 am
I tried to install cpanminus but I got an error saying "curl(6) couldnt resolve host "cpanmin.us"
Does anyone know what is wrong?
IgorGanapolsky
Mon Jan 30, 2017 9:15 pm
I am receiving the following error when trying your command:
Can't locate strict.pm in @INC (you may need to install the strict module) (@INC contains: /etc/perl
[/quote]
Return to “Raspberry Pi OS”
