Zhendos
WPA_GUI
Mon Oct 05, 2015 2:53 pm
Dear RB PI community;
today I've succesfully written RaspBerry Jessie to another Micro SD card.
After the OS started up, on the UI I've nothing more than a trash.
I've tried into the turminal the following lines:
sudo open wpa_gui
open wpa_gui
open wpa_cli
sudo open wpa_cli
None of the commands let me open the WPA_GUI for my Wi-Fi.
Any suggestions?
metalj
Re: WPA_GUI
Mon Oct 05, 2015 3:01 pm
Wpa_gui is officially gone.
Backspace 28 times :)
Re: WPA_GUI
Mon Oct 05, 2015 3:15 pm
Zhendos wrote:Dear RB PI community;
sudo open wpa_gui
open wpa_gui
open wpa_cli
sudo open wpa_cli
Any suggestions?
Do you not have a Task Bar running acrooss the top of the Desktop :?:
Maybe the image is extending outside the size of your screen :?:
Zhendos
Re: WPA_GUI
Mon Oct 05, 2015 3:34 pm
I got a menu bar, but there isn't sometimes as a "Wifi Config" or something.
There should be a command to open such a config?
Re: WPA_GUI
Mon Oct 05, 2015 3:43 pm
Zhendos wrote:I got a menu bar, but there isn't sometimes as a "Wifi Config" or something.
You stated in original post you only had waste basket...
There is a Network Icon top right (2 screens)
Zhendos
Re: WPA_GUI
Mon Oct 05, 2015 4:36 pm
Once I click on the 2 desktop icons it opens a textfield with the next String
"No wireless interfaces found"
spl23
Re: WPA_GUI
Mon Oct 05, 2015 9:17 pm
Have you got a supported wi-fi device plugged into the USB port? The message you are seeing indicates that the Pi cannot find any wi-fi hardware, which means you either don't have a dongle plugged in, the dongle is broken, or the dongle doesn't have a compatible driver.
Re: WPA_GUI
Mon Oct 05, 2015 9:33 pm
Zhendos wrote:Once I click on the 2 desktop icons it opens a textfield with the next String
Plug in WiFi Adaptor and post output of
lsusb
Return to “Raspberry Pi OS”
