plugwash
Packages from debian you want to see in raspbian repository
Mon Jul 23, 2012 6:21 pm
This thread is for packages that are present in debian wheezy (or in some cases perhaps sid) and are either not present in the raspbian repository or are present but not installable. Please CHECK whether packages are present and installable before posting.
This thread is not for:
* Packages that are present and installable but not working please use individual threads for such packages or groups of packages as they are likely to require deeper analysis that would choke a general thread.
* Packages that are not present in debian
* Packages that are useless without GPU acceleration and therefore require Pi specific builds.
* Begging for newer versions, raspbians goal is to stick as close to debian as possible
asb
Re: Packages from debian you want to see in raspbian reposit
Mon Jul 23, 2012 6:28 pm
Determine what is available in Debian wheezy or sid by searching on: http://www.debian.org/distrib/packages
Edit from plugwash: if you are going to use that site make sure you select testing (for wheezy) or unstable (for sid) not stable (which will give you info on whether a package is in squeeze)
plugwash
Tue Jul 24, 2012 12:26 am
GR-Thunderstorm wrote:I would like to see rpmbuild. :)
http://packages.debian.org/search?keywo ... ection=all
It seems we don't have librpmbuild1 but we do have librpmbuild3 which seems to be it's successor.
mlamat
Tue Jul 24, 2012 12:19 pm
I would like to see usbip.
plugwash
Tue Jul 24, 2012 2:32 pm
Is anyone going to listen to my instructions to check if stuff is already there before asking about it?!
dliloch
Tue Jul 24, 2012 3:27 pm
of course I would like to see Hercules! I'm still trying to find out why it won't compile...
mdewey
Tue Jul 24, 2012 3:42 pm
plugwash wrote:Is anyone going to listen to my instructions to check if stuff is already there before asking about it?!
I wonder whether it would help if you could edit your post to include a link to item 12 in the Raspbian FAQ (Do you have a list of all the packages in the Raspbian repository?) or possibly put the link in the post directly. It may be that people do not appreciate the distinction between it being in the image they just downloaded and being in the repository from which they could in principle install it.
Michael
plugwash
Tue Jul 24, 2012 4:26 pm
dliloch wrote:of course I would like to see Hercules! I'm still trying to find out why it won't compile...
Looks like it's failing with an internal compiler error. I'll try to find a workaround.
chrisw2
Tue Jul 24, 2012 4:59 pm
mdewey wrote:... It may be that people do not appreciate the distinction between it being in the image they just downloaded and being in the repository from which they could in principle install it.
Unfortunately, I suspect you have put your finger on the problem.
Plugwash - I think you are doomed for this to happen over and over and over... again. Hope you are a patient chap!
GR-Thunderstorm
Tue Jul 24, 2012 5:38 pm
Oh sorry I didn't see that list. :( I thought we only have what is preinstalled. :oops:
mdewey
Tue Jul 24, 2012 7:26 pm
GR-Thunderstorm wrote:Oh sorry I didn't see that list. :( I thought we only have what is preinstalled. :oops:
Well GR-Thunderstorm the whole point of this project is to be educational so if you have learned something it has achieved one part of its goals. We are all learning here in the great University of Life.
Michael
plugwash
Tue Jul 24, 2012 9:10 pm
Building with gcc-4.7 worked and the package has now been built and uploaded.
StefanBruens
Tue Jul 24, 2012 11:19 pm
Missing packages - anything that only has "architecture: ... arm armel ..." in its description.
e.g. pulseaudio-module-bluetooth
zaloopa
Tue Jul 24, 2012 11:53 pm
please add aircrack-ng package.
plugwash
Tue Jul 24, 2012 11:56 pm
StefanBruens wrote:Missing packages - anything that only has "architecture: ... arm armel ..." in its description.
Well yeah, if it's not marked as suitable for armhf we won't build it.
Such cases are most likely bugs in debian...
I'll look into getting this fixed in raspbian (and later debian but that always takes a while).
AlArenal
Wed Jul 25, 2012 10:44 am
I bought the book "Land of Lisp" which has some very good reviews and just found out there is no clisp package in Raspbian, there's only the clisp-doc available - pretty useless without the binaries ;-)
So yes, I'd like to see clisp in the Raspbian repos.
dliloch
Wed Jul 25, 2012 11:33 am
Thank you, thank you!!! :-) --- I just love showing how you can run MVS on this machine to
people at the office .. and now it should run faster! :-)
plugwash
Wed Jul 25, 2012 7:51 pm
AlArenal wrote:I bought the book "Land of Lisp" which has some very good reviews and just found out there is no clisp package in Raspbian, there's only the clisp-doc available - pretty useless without the binaries ;-)
I tried.and failed to get this one to build, I added armhf to the arhitecture lists and tried to build it. It failed with an internal compiler error. I then tried modifying the package to build with gcc-4.7. It got futher but it ultimately failed with.
./lisp.run -B . -N locale -E UTF-8 -Epathname 1:1 -Emisc 1:1 -norc -m 2MW -lp /clisp-2.49/src/ -x '(and (load "/clisp-2.49/src/init.lisp") (sys::%saveinitmem) (ext::exit)) (ext::exit t)'
make[1]: *** [interpreted.mem] Illegal instruction
However there are other common lisp implementations in debian and at least ecl and gcl are available in raspbian. Are either of these usable for you?
plugwash
Wed Jul 25, 2012 7:52 pm
zaloopa wrote:please add aircrack-ng package.
Seems this is in a bit of a mess in debian at the moment. Once debian has a package that is building ok on armhf poke me again and i'll try and get it into raspbian.
dliloch
Thu Jul 26, 2012 1:36 am
I tried to do a sudo apt-get install hercules and it couldn't find it.. is there something I am
missing???
dliloch
Thu Jul 26, 2012 1:43 am
sorry about that did a sudo apt-get update then it worked..
AlArenal
Thu Jul 26, 2012 8:54 am
@plugwash
Thanks for your effort and the hints to ecl and gcl. :-)
Land of Lisp should arrive tomorrow but from the bits and pieces I read about it on the web it relies on CLisp throughout the book. I'll see how far I can get with other Lisp implementations.
davidm870
Fri Jul 27, 2012 12:38 am
rrdtool (and its followers-around e. g. python-rrdtool)
plugwash
Fri Jul 27, 2012 9:48 am
davidm870 wrote:rrdtool (and its followers-around e. g. python-rrdtool)
They already seem to be present and installable to me.
Return to “Raspberry Pi OS”
