Michael_O
mencoder not in jessie?
Fri Oct 16, 2015 2:04 pm
I tried to install mencoder to make a timelapse video from a set of images but I get a strange error:
pi@raspberrypi ~ $ sudo apt-get install mencoder
Reading package lists... Done
Building dependency tree
Package mencoder is not available, but is referred to by another package.
E: Package 'mencoder' has no installation candidate
Mencoder is used in the RPF timelapse learning resource so this should concern them.
ffmpeg and avconv both have the same problem. I have confirmed that I have full access to the repository by installing other packages such as iceweasel.
Can anybody tell me what is going on?
Re: mencoder not in jessie?
Fri Oct 16, 2015 2:13 pm
Michael_O wrote:I tried to install mencoder to make a timelapse video from a set of images but I get a strange error:
ffmpeg / avconv / mencoder all replaced.
libav-tools and mpv are the updated packages in Jessie:
https://packages.debian.org/jessie/libav-tools
https://packages.debian.org/jessie/mpv
http://mpv.io
https://libav.org
Cloud-Hopper
Mon Mar 28, 2016 6:00 pm
All,
Good news for mencoder users. I have just installed mencoder under jessie yesterday (2016-03-28) on a RPI v3.
You will have to compile from the source, having also installed ffmeg.
It took about 25 minutes to build on the Pi v3 and there were a few compile warnings, but no errors.
To do this, follow the build instructions as normal .. ./configure, make, make install ... and you should get a working binary.
As noted, this will not be a permanent solution so look to move away from mencoder in the longer term under debian.
Good luck!
Cloud-Hopper
Build commands from history ...
wget http://www.mplayerhq.hu/MPlayer/releases/mplayer-export-snapshot.tar.bz2
bunzip2 *
tar xvf *
cd mplayer-export-2016-03-26/
sudo apt-get install ffmpeg
./configure
make
< ... wait a long time here ...>
./mencoder
sudo make install
Tue Mar 29, 2016 6:50 am
Try using tar xavf rather than bunzip2 followed by tar xvf. I think you'll be amazed at what happens.
gomako
Fri Mar 24, 2017 8:47 pm
I used the new packages on my Pi Zero W.
Install the tools:
sudo apt-get install libav-tools
Then you can combine stills using a command from the link https://wiki.libav.org/Snippets/avconv# ... e_sequence
I used:
avconv -framerate 25 -f image2 -i image-%04d.jpg -b 65536k out.mov
Return to “Raspberry Pi OS”
