juppiter89
Re: Two XBMC (.deb) compiled/prepared for users + instructio
Sat Oct 05, 2013 3:20 pm
Uhm... try to install the package udev
sudo apt-get install udev
mcgyver83
Sat Oct 05, 2013 3:41 pm
No luck
Reading package lists... Done
Building dependency tree
udev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
/usr/lib/xbmc/xbmc.bin: error while loading shared libraries: libudev.so.1: cannot open shared object file: No such file or directory
juppiter89
Sat Oct 05, 2013 3:42 pm
Ok, now try libudev1
sudo apt-get install libudev1
Well, I think I undestood:
in Raspbian Wheezy there is libudev0, not libudev1.
A possible workaround should be to create a symlink. Please try
sudo ln -s /lib/arm-linux-gnueabihf/libudev.so.0 /lib/arm-linux-gnueabihf/libudev.so.1
mcgyver83
Sat Oct 05, 2013 3:55 pm
E: Unable to locate package libudev1
Only *udev
libudev0 libudev-dev
and both are installed
juppiter89
Sat Oct 05, 2013 4:01 pm
Sorry for these troubles, and thank you for your feedback :)
Please try the workaround of my last post.
mcgyver83
Sat Oct 05, 2013 4:08 pm
Sorry??? :ugeek:
You're helping me for free, I have to say thank you!!!!
I made the simlink and now:
xbmc
/usr/lib/xbmc/xbmc.bin: /lib/arm-linux-gnueabihf/libm.so.6: version `GLIBC_2.15' not found (required by /usr/lib/xbmc/xbmc.bin)
/usr/lib/xbmc/xbmc.bin: /lib/arm-linux-gnueabihf/libudev.so.1: no version information available (required by /usr/lib/xbmc/xbmc.bin)
/usr/lib/xbmc/xbmc.bin: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.17' not found (required by /usr/lib/xbmc/xbmc.bin)
juppiter89
Sat Oct 05, 2013 4:15 pm
Hehe, I try to do my best :D
However, unfortunately, I think you have to upgrade to Raspbian Jessie, because I compiled XBMC using Jessie libraries. If you want to do this, run:
sudo nano /etc/apt/sources.list
and change wheezy with jessie in "deb http://mirrordirector.raspbian.org/raspbian" line, then
sudo apt-get update && sudo apt-get dist-upgrade
mcgyver83
Sat Oct 05, 2013 4:21 pm
I Jessie the new version of Weezy?
I red that Jessie is the testing version.
How can I compile myself XBMC?
juppiter89
Sat Oct 05, 2013 4:23 pm
Jessie is the new version of Raspbian, based on Debian Jessie.
Officially it is an "unstable" version, but it is almost perfectly usable.
mcgyver83
Sat Oct 05, 2013 4:27 pm
I trust you. I'm upgrading.
But is too difficult to provide a guide to compile XBMC with only CEC support?
I tried many time following this guide http://www.raspbian.org/RaspbianXBMC but every time something went bad
juppiter89
Sat Oct 05, 2013 4:32 pm
Well, I followed exactly that guide, plus other hints found on the net (expecially https://github.com/xbianonpi/xbian/wiki ... pendencies).
However, compiling is not a easy task, many little things can go wrong.
mcgyver83
Sat Oct 05, 2013 4:40 pm
Ok, so I will update this topic as soon as upgrade ends.
juppiter89
Sat Oct 05, 2013 4:42 pm
Ok, thank you for your testing :D
mcgyver83
Sat Oct 05, 2013 4:44 pm
thank you for the help!!!!!
mcgyver83
Sun Oct 06, 2013 6:07 pm
Before I had only one .xbmc folder under /root/.xbmc.
Now I have also a .xbmc folder under $HOME/.xbmc
I copied the /root/.xbmc folder over the $HOME/.xbmc folder but I still miss all my settings.
I'm on tail on both the xbmc.log files (/root/.xbmc/temp/xbmc.log and $HOME/.xbmc/temp/xbmc.log) but no log lines when I use xbmc
juppiter89
Sun Oct 06, 2013 6:50 pm
Hi, first of all, does XBMC start correctly now?
About the settings, if you have /root/.xbmc folder, you sometime had certainly run XBMC as root, and not as normal user. This is a bad behavior. You should not start XBMC (and any user application) as root!
Having said that, I don't know if you can copy setting between different users (in this case root and pi I presume). However, although not advisable, you might start XBMC as root, so you may see if you can keep your settings.
sudo bash
then
xbmc
EDIT: If you copied from /root/.xbmc to $HOME/.xbmc, make sure to fix permissions of copied files
sudo chmod -R +wr $HOME/.xbmc
mcgyver83
Mon Oct 07, 2013 5:56 am
Thanks again.
Yes, maybe once I run xbmc as root but I'm quite confident not each time.
But no problem, I fixed files permission. Xbmc starts fine now.
I'm at work now, so this evening I'm going to try to run xbmc with fixed permission on $HOME/.xbmc folder ad I'll update this post.
mcgyver83
Tue Oct 08, 2013 7:15 am
None, my settings are lost but doesn't matter, starting from now I'll run xbmc not with sudo.
At the first start xbmc asked me for a password to check for update, what is it?
mcgyver83
Wed Oct 16, 2013 9:24 pm
When I exit from XBMC menu, in the shell I started it, this message is raised:
Exception SystemExit in <function _remove at 0x1ac1b30> ignored
milad69_1
Wed Feb 19, 2014 10:17 am
I have a problem :( i installed xbmc using instruction on this page . I selected no for starting xbmc by default. and after reboot a login page shows and even though i didn't change default user pass (pi/raspberry) i cannot login! actually screen splashes and login page starts again and wont start the any of sessions.
what should i do? is there a way to start a terminal and remove xbmc?
mcgyver83
Sat Mar 01, 2014 5:57 pm
Since a month ago CEC was working with the samsung tv remote control.
Now the "pheriperial" menù in system settings is disable, grey.
How is it possible?
mcgyver83
Mon Mar 03, 2014 9:21 pm
Hi man,
I used your compiled xmbc but now I have a problem with CEC.
So I though to try to compile it.
I followed the guide you suggested https://github.com/xbianonpi/xbian/wiki ... pendencies in this message http://www.raspberrypi.org/phpBB3/viewt ... 61#p432961
All is fine.
After a night and more all the pieces are compiled.
I'm a newbie so, now what I have to do to install xbmc ?
In the guide some "add on" like libcec and libshairport were compiled before xbmc, others (PVR Addons,..)after.
The first were automatically included in the xbmc and the last no?
eloyucu
Fri Jan 23, 2015 10:40 pm
I followed the two first steps:
 wget https://github.com/downloads/RB-tomaz/xbmc-rdp-tomaz/xbmc-rdp-tomaz.armhf.deb
    sudo dpkg -i xbmc-rdp-tomaz.armhf.deb; sudo apt-get -y -f install
But what I got was the scratch IDE!!!!! WTF!!!!!????
DirkS
Fri Jan 23, 2015 10:52 pm
eloyucu wrote:I followed the two first steps:
Have you checked the date that software was last changed at https://github.com/RB-tomaz/xbmc-rdp-tomaz :?:
Why would you want to download and install that :?: :?:
Return to “Raspberry Pi OS”
