expandables
Kodi 15.2 for Wheezy (Download)
Fri Nov 13, 2015 7:38 pm
I will be compiling every new stable version of kodi :shock:
You most have 15.0 already installed If you don't install it by following these instructions.
sudo apt-get remove kodi kodi.bin -y
wget http://steinerdatenbank.de/software/kodi-15.tar.gz
tar -xzf kodi-15.tar.gz
cd kodi-15
sudo ./install
To get 15.2 first create this script
nano kodi15.2install.sh
Then put this in the Kodi script
cd /usr/bin && wget -O kodi https://www.dropbox.com/s/4ldu6v6gec1bwog/kodi?dl=1 && wget -O kodi-standalone https://www.dropbox.com/s/ddemn5gql2wxdw3/kodi-standalone?dl=1 && cd /usr/lib/kodi && wget -O kodi.bin https://www.dropbox.com/s/xfrwr611l6sislg/kodi.bin?dl=1 && reboot
Save the script by pressing
Ctrl and the letter X
Run the script with
sudo sh kodi15.2install.sh
Now you should have Kodi 15.2 for wheezy.
I start kodi with this script
#!/bin/bash
sudo rm -r /home/pi/.kodi/addons/packages/*.zip
setterm -cursor off
mkdir -p ~/.kodi
clear
startkodi
setterm -cursor on
exit 0
:mrgreen:
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
dogdayfear
Re: Kodi 15.2 for Wheezy (Download)
Sun Nov 15, 2015 11:28 pm
Hi!
Dont know why but after testing 3 methods of getting kodi 15 running in my wheezy Rasperry 1GB, all of them worked but yours is the one that better permonce gives to me.
GUI is faster than others and in general it seems better.
Only thing is that I cant get my TV remote control to work. And with the other methods it worked.
Could be related to the libcec version 3.0 for CEC (remote control) support?
I tried installing that following the guidelines here: viewtopic.php?f=66&t=109088 and didnt worked.
After that I tried viewtopic.php?f=29&t=117019 but no way.
Could you help with this, please?
Thanks in advance!
expandables
Mon Nov 16, 2015 2:17 pm
Since i didn't needed CEC i didn't compile Kodi with CEC.
I'll compile Kodi with CEC in version 16.0.
:mrgreen:
gkreidl
Mon Nov 16, 2015 2:40 pm
You can't really update by just replacing kodi.bin. Why not create a debian package with "checkinstall"?
(sudo checkinstall make install).
Minimal Kiosk Browser (kweb)
expandables
Mon Nov 16, 2015 3:15 pm
It does update by just replacing kodi-standalone, kodi.bin and kodi.
:mrgreen:
dogdayfear
Mon Nov 16, 2015 3:48 pm
expandables wrote:Since i didn't needed CEC i didn't compile Kodi with CEC.
:mrgreen:
Ok, that would be great.
dogdayfear
Thu Nov 19, 2015 4:15 pm
Another extrange thing:
Volume up key of my usb keyboard works as expected in this version. But not Volume down key.
With other versions both keys worked fine.
Just for you to konw, if it could help.
dogdayfear
Fri Nov 27, 2015 12:02 pm
Ok, I have been able to build kodi myself with CEC support. I would like create a .tar.gz file as you did to run ./install and to be able to install my build when needed.
But dont know wich files do I need to include. How do I generate the installer with all needed files, libraries and dependencies as your .tar.gz file?
Thanks a lot.
Return to “Raspberry Pi OS”
