MarkR
How to get the wifi working on Pi3, on Raspian "wheezy"
Fri Mar 04, 2016 11:56 pm
Here is a little recipe I cooked up:
Suppose you've got a PI2 (or Pi1) and want to transfer its SD card with all the goodness, to a Pi3. Great hey?
* On the old pi, run raspi-update, apt-get update, apt-get dist-upgrade etc
* Transfer SD card to the new Pi
And all is great.
Except the wifi, which won't work.
If you don't want to upgrade to the new OS "Jessie", there are missing files.
At the time of writing, the Pi foundation haven't made the firmware package available for "Wheezy" - the old version.
It took me some time to work this out.
To fix this, get the firmware file, for example:
wget 'http://archive.raspberrypi.org/debian/p ... i4_all.deb'
Then install with dpkg -i firmware-brcm80211_0.43+rpi4_all.deb
Note that these instructions will probably be obsolete very soon, and will probably be inadvisable soon after that.
Essentially you need the files:
/lib/firmware/brcm/brcmfmac43430-sdio.bin
/lib/firmware/brcm/brcmfmac43430-sdio.txt
Which are included in the package above.
Happy pi3.
Mark
eddie7332
Re: How to get the wifi working on Pi3, on Raspian "wheezy"
Tue Jun 27, 2017 1:25 pm
Hola,
funciona perfectamente.
Le he cargado la:
http://archive.raspberrypi.org/debian/p ... i1_all.deb
de fecha: 13-Jun-2017 10:07 3.4M
muchas gracias...
Return to “Raspberry Pi OS”
