hostingnuggets
ZFS package on Raspbian
Wed Nov 09, 2016 5:57 pm
I would love to try out ZFS on Rasbian but noticed that there are no packages yet. Is anyone willing to create one?
I would be happy to help but I am no programmer and have little experience with compiling source code.
Best regards,
John
epoch1970
Re: ZFS package on Raspbian
Wed Nov 09, 2016 6:28 pm
Pi is not exactly a target for ZFS; It's short on memory and I/Os and at least for the zfsonlinux implementation from LLNL, you need a 64-bit OS.
hostingnuggets
Wed Nov 09, 2016 7:30 pm
epoch1970 wrote:Pi is not exactly a target for ZFS; It's short on memory and I/Os and at least for the zfsonlinux implementation from LLNL, you need a 64-bit OS.
I am totally aware about that, it's just to build up a proof of concept for testing, not for production usage.
Right now I am building SPL by having run "configure" and "make pkg-utils pkg-kmod", it build the RPM package files but unfortunately does not build the .deb files... Here relevant make output:
Executing(--clean): /bin/sh -e /tmp/spl-build-pi-DB0ByBSl/TMP/rpm-tmp.99bx4Q
+ umask 022
+ cd /tmp/spl-build-pi-DB0ByBSl/BUILD
+ rm -rf spl-kmod-0.7.0
+ exit 0
make[1]: Leaving directory '/home/pi/git/spl'
name=spl; \
version=0.7.0-rc2_2_gcbba714; \
arch=`rpm -qp ${name}-kmod-${version}.src.rpm --qf %{arch} | tail -1`; \
pkg1=kmod-${name}*${version}.${arch}.rpm; \
fakeroot alien --bump=0 --scripts --to-deb $pkg1; \
rm -f $pkg1
kmod-spl-4.4.26-v7+-0.7.0-rc2_2_gcbba714.armv7l.rpm is for architecture armel ; the package cannot be built on this system
Any idea why alien does not want to convert the .rpm to a .deb although it is an arm arch... ?
Wed Nov 09, 2016 8:22 pm
Because Raspbian is armhf, not armel. Wrong arm arch.
hostingnuggets
Wed Nov 09, 2016 9:26 pm
Good point! As you can now notice, I am pretty new to the whole Raspberry Pi thingy ;-)
So thanks to your hint I adapted the Makefile of SPL to force the architecture by adding the "--target armhf" to the rpmbuild commands. I now have SPL compiled and 4 .deb packages ready to install, which I am going to try right now.
I am one step closer to get ZFS running on RasPi!
tpylkko
Wed Nov 09, 2016 9:34 pm
Due to the licensing issues ZFS was added to Debian only recently and they only added the source to the DKMS module to contrib section.
https://bits.debian.org/2016/05/what-do ... ebian.html
But btrfs is available straight OOTB on Raspbian and has all the same properties (almost at least).
hostingnuggets
Wed Nov 09, 2016 10:40 pm
Fantastic, I got ZFS 0.7.0 running on Raspbian 8-)
ejolson
Thu Nov 10, 2016 2:30 am
hostingnuggets wrote:Fantastic, I got ZFS 0.7.0 running on Raspbian 8-)
How many drives are in the storage pool and what sizes? How well does it work?
hostingnuggets
Thu Nov 10, 2016 8:00 pm
For now I just tested with two "virtual drives" of 1 GB each created by using "dd if=/dev/zero of=/vdrive1 ..." and then created a zfs mirror out of them.
My plan is to attach two SSD USB drives of 500 GB each and create a zpool with one mirror out of them. I should have time next week to do that and will post my results here as soon as I tried that out.
serged
Sat Dec 17, 2016 11:11 pm
What options did you use to compile ZFS successfully?
I did try couple of things already but I always hit the same error using 4.4.34 on a raspberry 3.
configure: error: in `/tmp/spl-build-pi-d0NVWUrR/BUILD/spl-0.7.0':
configure: error: C compiler cannot create executables
serged
Sun Dec 18, 2016 9:08 pm
ok, I finally succeed ... here are the steps I used if someone is interested
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install build-essential autoconf libtool
sudo apt-get install gawk alien fakeroot gdebi
sudo apt-get install zlib1g-dev uuid-dev libattr1-dev libblkid-dev
sudo apt-get install libselinux-dev libudev-dev parted lsscsi wget ksh
sudo apt-get install raspberrypi-kernel-headers
sudo apt-get install libdevmapper*
download the latest openZFS (0.7.0) for github
spl-0.7.0-rc2.tar.gz
zfs-0.7.0-rc2.tar.gz
mkdir zfs
move the 2 files under zfs directory
cd zfs
tar xzf s*0
tar xzf z*0
cd s*0
./autogen.sh
cd ../z*0
./autogen.sh
cd ../s*0
./configure
make
sudo make install
cd ../z*0
./configure
make
sudo make install
sudo vi /etc/ld.so.conf
and add the following line at the end of the file
/usr/local/zfs/lib
then save and exit.
sudo depmod -a
sudo modprobe zfs
.. et voila
Then I just did create a flat file to use as vdev for quick testing
root@rasp01:~# zpool create p1 /tests/f1
root@rasp01:~# zpool list
NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
p1 192M 100K 192M - 1% 0% 1.00x ONLINE -
root@rasp01:~# uname -a
Linux rasp01 4.4.34-v7+ #930 SMP Wed Nov 23 15:20:41 GMT 2016 armv7l GNU/Linux
glumpf
Sun Mar 12, 2017 7:24 pm
Hi serged,
i followed your steps, it works fine, till i reboot. I created pools, but after reboot
zpool list
shows that no pools are available. What should i do? Thanks
qippur
Tue Apr 04, 2017 5:58 pm
Bookmarked. It worked like a charm. Thank you!
Anyone has any suggestion to have zfs as root filesystem for the raspberry? That would be great.
Regards
qippur
Return to “Raspberry Pi OS”
