I am working on Windows 10 with a headless pi zero W. I downloaded Raspbian Buster Lite and flashed the micro SD card using balenaEtcher. Normally at this point I would create an empty "ssh" file and configure wpa_supplicant.conf in the /boot partition, but windows cannot find the /boot partition.
I have verified the image does boot. Is there something new I need to do to access the /boot partition from windows?
Re: Buster: Can't find /boot partion
The only partition your windows PC can see is the fat32 ( boot) partition.
So on my windows 7 PC with a buster lite SD card you see this K: drive is my card reader.
you may have to eject the card after writing and reinsert card to get windows to recognise the fat partition.
Thanks, I already tried that without any success. Just tried it on another computer and is works. looks like there is something haywire on my computer.
Some times a reboot will fix problems like this, worth trying before you start digging in to the OS/hardware
Seems to be some odd interaction with network drive mapping... kind of have it working now.
In case anyone is seaching for the solution as I was... this worked for me;
- Open disk management
- Right-click the "boot" partition and select "Change Drive Letter & Paths"
- Click "Add" and allocate it a drive letter
- It will now show in Windows Explorer
theboylloyd wrote: ↑Thu Sep 05, 2019 8:47 amIn case anyone is seaching for the solution as I was... this worked for me;
[spot on info for those who forgot that stuff changes in windows like the weather. Took the card out and put it back in and transferred the ssh file in with no problems last week, today we are looking at root instead.]
