redhawk
Change rainbow splash screen??
Fri Dec 07, 2012 3:04 pm
When the PI boots up a rainbow coloured squire appears at the start, is it possible to change this image to something else and if so how??
Richard S.
Re: Change rainbow splash screen??
Fri Dec 07, 2012 3:40 pm
You can change it to a black square:
disable_splash=1
in config.txt....
You could then display your desired splash screen earliy in the linux boot (which is what OpenELEC/Raspbmc do).
redhawk
Sat Dec 08, 2012 1:12 am
Thanks for the tip however I would rather replace the image than disable it.
What's the procedure for changing the splash screen does it have to be a specific format or resolution??
Richard S.
daveg
Sat Dec 08, 2012 9:50 am
I don't think you will be able to change it as it is a test image which displays before the gpu starts loading the OS and is probably embedded in the SoC or coded into the gpu blob which isn't for public editing.
mahjongg
Sat Dec 08, 2012 10:01 am
Its not a splash screen, its a test the GPU does, before linux even boots. You have the choice of disabling it.
Sat Dec 08, 2012 12:53 pm
It's actually a four pixels zoomed up to fill the screen. The rainbow effect comes from the scaling kernel.
point
Tue Oct 08, 2013 6:15 pm
The disable_splash=1 in config.txt does not have any influence. I'm running the latest firmware and kernel on RPi B 512 MB version.
What could be the cause?
qubodup
Tue Sep 16, 2014 5:16 pm
Adding
disable_splash=1
to /boot/config.txt should do it as described on http://www.raspberrypi.org/documentatio ... fig-txt.md
disable_splash
If set to 1, don't show the rainbow splash screen on boot. The default value is 0.
However this has no effect in NOOBS raspberrypi 3.12.28+ on RPi B.
Eric_Newman
Fri Dec 04, 2015 3:36 pm
in /boot/cmdline.txt add the following at the end of the line(make sure that all of the contents are placed in one line) :
logo.nologo
this will disappears the pi logo and you can replace the rainbow splash according to the following guide:
http://www.edv-huber.com/index.php/prob ... i-raspbian
blanka
Fri Feb 26, 2016 8:41 pm
Is there a way to disable the smooth scaling of the scaling kernel? I want my Pi to scale "nearest neighbour"
asandford
Fri Feb 26, 2016 10:07 pm
blanka wrote:Is there a way to disable the smooth scaling of the scaling kernel? I want my Pi to scale "nearest neighbour"
I suggest you make a new thread.
Fri Feb 26, 2016 11:29 pm
viewtopic.php?f=63&t=58432
Return to “Raspberry Pi OS”
