Rascas
Re: [Guide] Kodi on Raspbian Buster
Wed Dec 18, 2019 5:31 pm
labboy wrote:
Wed Dec 18, 2019 5:23 pm
Hi there people! I updated my raspberry pi 3 to buster yesterday.
Now, I am trying to install the latest version of pvr-teleboy, but it looks the version available is still 18.0.25 from a year ago which is not functional any more. Version 18.1.6 is out there and availbe for ubuntu but not for raspbian yet. Are there any plans to update this or should I switch to ubuntu mate xenial for example?
thanks for your time!
I will update Kodi to 18.5 and all PVRs/binary addons when I have some free time, which is not much in this Christmas/new year season.
You can try Kodi on Ubuntu but it won't be as good as in Raspbian, because it is a generic version, not optimized for the RPi.
labboy
Wed Dec 18, 2019 5:47 pm
Thanks Rascas for all your effort. Yes its maybe not optimised but on the other hand with Raspbian i dont have TV anymore, so I dont really have an option. I will just create a new SD setup with ubuntu mate bionic which is for raspberry at least....
fear nothing, hope nothing, be free
labboy
Sat Dec 21, 2019 11:08 pm
After some adventurous times with other ubuntu version...i came back to raspbian...and ended up compiling teleboy myself, it wasnt so difficult after all....My first compilation !!! Kudos to the instructions of github pvr-teleboy
chewy74
Sun Dec 29, 2019 6:49 pm
Anyone else using watchdog addon and noticing it not updating the library when new files are added? I have kodi installed on a firestick 4k and firetv pendant (kodi 18.5) and watchdog addon for both are working fine.
Pi4 kodi 18.4 with local storage hdd connected
bluenote
Mon Dec 30, 2019 1:13 am
I've noticed that kodi (on a pi2b) seems to require a fair bit of gpu mem for decoding h265 but does it well (!!) nowadays. Is there some way I can control the split so that I have more ram in "desktop mode" and more gpu memory in "kodi mode" ?
thanks for any suggestions. I'm actually experimenting with a dual boot, but I'd rather not have to do that.
arre
Tue Dec 31, 2019 2:02 pm
@rascas: Thanks alot for the build! Could you also provide a source package / build instructions by any chance?
I would like to fix/patch multithreaded SW decoding in my kodi build (see https://github.com/xbmc/xbmc/issues/15893), but I can't seem to find a debian buster source package for kodi (of which you are the registered maintainer)
The alternative would be for me to fall back to libreelec and patch it there, but I'd rather stay on buster.
Thanks in advance for your feedback!
Rascas
Tue Dec 31, 2019 3:59 pm
You can use the CMA (memory alocator). I tried it somewhere in the past but not much, I don't know how it is now.
More information about that here:
https://elinux.org/RPiconfig
Rascas
Tue Dec 31, 2019 4:11 pm
I have already explained this some times here in the forums, but here goes again.
I use cmake/cpack deb to create the deb packages and that does not create a source package.
Anyway, building Kodi for the RPi is easy if you use my github repos:
For RPi 0/1/2/3: https://github.com/PIPplware/xbmc/tree/leia_backports
For RPi 4: https://github.com/PIPplware/xbmc/tree/leia_pi4
You just need to get the build deps, clone the respective repo and run the build_rpi_debian_packages.sh script.
Magnus_A
Tue Dec 31, 2019 9:57 pm
For RPi 0/1/2/3: https://github.com/PIPplware/xbmc/leia_backports
For RPi 4: https://github.com/PIPplware/xbmc/leia_pi4
Your links are not valid.
Please update vith valid links.
Rascas
Thu Jan 02, 2020 6:19 pm
Fixed, but cmon man, the links for the source code are even on the first post, please do a little research before asking for things.
arre
Thu Jan 02, 2020 9:18 pm
Thanks!!
arre
Sat Jan 04, 2020 8:59 am
Just wondering; have you ever cross-compiled (from x64) to rpi before, or do you always compile natively?
Rascas
Sat Jan 04, 2020 11:04 am
I don't believe I ever tried to cross compile Kodi on a x86 machine. In RPi 1 only time I compiled Kodi on a x86 machine for it, with qemu + chroot.
bfksoql
Sun Jan 05, 2020 9:36 am
Hello. I use RPI4 + kodi to watch rtsp stream from camera and TV from vu+ client. Both works good for few minutes but after some time it loose FPS - video is live but choopy :-( KODI restart helps but problem come back in few minutes / streams changes. How to resolve this problem ?
arre
Sun Jan 05, 2020 1:42 pm
Question, I noticed that in the official package the kodi bootstrap script checks which version of the pi it is running on, and executes the appropriate kodi binary afterwards (kodi, kodi_v7 or kodi_v8). The official package basically ships all build variants in one.
Is this something that was manually added afterwards? (I now just simply built the backports branch, but it only builds a single bin, and not all 3. If I were to try to generate an "official package" that is installable on all pi's, I would have to manually merge the install packages?
Thanks for your feedback!
arre
Sun Jan 05, 2020 3:06 pm
Also interestingly, even though my build in backports succeeded, the one for the rpi4 failed.
The errors like "xbmc/xbmc/utils/EGLImage.cpp:18:5: error: 'EGL_DMA_BUF_PLANE0_FD_EXT' was not declared in this scope" seems to come from the fact that it tries to include /opt/vc/include/EGL/eglext.h instead of /usr/include/EGL/eglext.h (which I thought it should do). But those defines are not present in the /opt/vc version.
If this rings any bell, thanks for any help on that)
andrum99
Sun Jan 05, 2020 4:21 pm
Hi @rascas. Is it possible to get the systemd script included in the official repo? Or can you possibly explain why it was not included?
Thanks again for your work on this package - it is really helpful to many folk, including me :D
bluenote
Sun Jan 05, 2020 6:00 pm
Has this been removed? https://www.raspberrypi.org/forums/view ... a#p1584101
ParanoYak
Mon Jan 06, 2020 12:36 pm
Hello
I successfully installed Kodi with apt-get install. However I want to use kodi-send commands in order to switch off TV with a command line. Using cec-utils doesn't work, since Kodi comes with its own cec-client.
Hence the idea of using
kodi-send --action=“CECStandby”
command to make it work.
I installed
sudo apt-get install kodi-eventclients-kodi-send
but the command above doesn't work to switch off TV (whereas CEC works perfectly in Kodi), so I guess this is not the proper way to install kodi-send and make it work with the kodi package.
Do you know how I can install it and make it work ? Or do you know where the KODI-built-in-CEC client is installed, so I may use it directly ?
Regards
Franck
Rascas
Mon Jan 06, 2020 2:04 pm
Yep, Kodi is compiled for 3 diferent architectures for better performance. The resulting binaries are added to one package manually afterwards- Just compile for the version of the RPi you have and it is the same, it is just a waist of the time for you to compile the others.
RPi 4 build is currently failing with some error I didn't have the time yet to investigate.
Rascas
Mon Jan 06, 2020 2:08 pm
It could be included, it is not because it is not in the original source code. Also if you check the Kodi packages from Ubuntu PPA for x86, that's not included either.
Rascas
I have no idea. Better create a new topic about that.
Rascas
Mon Jan 06, 2020 2:22 pm
Hello
I installed
Regards
Franck
Yes, that is the correct way to install kodi-send. Don't ask me about the commands though, I never used it.
Kodi uses the same cec-client as the one in the repos, it is compiled dynamically. But using cec-client through command line while Kodi is running may not work. Also notice that some TVs cannot be shutdown/turn on with CEC.
ParanoYak
Mon Jan 06, 2020 2:49 pm
Yes CEC-utils and TV shutting off is indeed working without KODI running. So if someone knows how to use CEC commands while KODI is running (using kodi-send or other ways) thanks for your help :)
andrum99
Mon Jan 06, 2020 5:41 pm
I see. I was just curious why it was in your test builds, but got removed when you built the official version. I will go and fetch if from the test version.
Return to “Raspberry Pi OS”
