klricks
STICKY: How to use Autostart - Raspberry Pi OS (Desktop)
Tue Dec 08, 2020 9:14 pm
Note the settings and defaults described below are found in the Raspbian 'Buster' and later RPi OS releases.
Raspbian 'Stretch' and before releases used different defaults as noted below. ***
The autostart feature can be used to automatically start just about any app, script or command at boot (User login). Requires boot to Desktop (GUI) enabled.
Autostart is particularly useful when you need to run Desktop apps or any scripts which require Desktop (GUI).
Other methods such as rc.local or cron @reboot do not easily handle GUI programs as they attempt to start the app before the Desktop in ready resulting in failure to open.
There are 4 autostart methods or options:
• System (All Users) *** Default in 'Buster' and later OS releases ***
• User (Specific Users) *** Default in 'Stretch' and earlier OS releases ***
• Traditional (All Users) with .desktop files
• Traditional (Specific User) with .desktop files
System Method:
The System method is easiest as the required autostart file is already present and commands can easily be added with a simple edit. By default, the System autostart is applied to all users and executes each time a user logs in.
The System autostart file is located here: /etc/xdg/lxsession/LXDE-pi/
To open System autostart using the nano editor:
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
See Using the Autostart File & Sample Autostart Files below.
User Method:
The user method works much the same as the System method but allows for a unique or custom autostart file for each user. If there is only one user (pi) or your multiple users do not require different apps or scripts started at login / boot, then there is no advantage to doing the user method.
The user autostart file and associated path does not exist by default.
The pi user autostart needs to be located here: /home/pi/.config/lxsession/LXDE-pi/ (If not user pi then substitute your username for pi /home/{user}/.config/lxsession/LXDE-pi/).
You will first need to create the lxsession and LXDE-pi sub directories then copy the System autostart to the user(s) location(s).
For user pi:
mkdir /home/pi/.config/lxsession
mkdir /home/pi/.config/lxsession/LXDE-pi
cp /etc/xdg/lxsession/LXDE-pi/autostart /home/pi/.config/lxsession/LXDE-pi/
Note: If a user autostart file exists at /home/pi/.config/lxsession/LXDE-pi, then the System autostart file is totally ignored (for that user).
To open the User autostart using the nano editor:
nano /home/pi/.config/lxsession/LXDE-pi/autostart
Using the Autostart File (System or User):
The default System autostart file:
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xscreensaver -no-splash
• The first 2 lines are important and must not be removed and must also be present if doing the User method. If you have made an autostart file without these lines, the desktop will boot to a blank (Openbox) screen. To recover, right click anywhere on the screen and select terminal from the menu. Then edit autostart and add those 2 lines.
• The xscreensaver command is only relevant if you have installed xscreensaver. If not then it can be removed or just ignored.
• The @ is optional. With @ present, if there is an error on first try, the system will attempt to run the command up to 4 more times before giving up.
• Note that the autostart file is not a bash script and is processed differently. The commands in the autostart file are processed independently at near the same time in a parallel fashion. Or the system does not wait for the previous command to complete before starting the next command. If you have multiple commands that are dependent on being run in a specific order then you would need to put your commands in a bash script, then call your bash script from autostart.
• All programs launched by autostart run in the background so no need to use & at the end of the command.
• It is important to use the complete paths to scripts in autostart. Also calls within a script need to have the complete path specified. Paths to installed apps are not required.
• Scripts must be made executable.
• If your script requires keyboard and/or console interaction, then use the lxterminal -e command. See examples and notes below.
• If your command or app requires network and does not seem to work from autostart, then try enabling the wait for network at boot option in sudo raspi-config
• In some rare cases you may need to add a delay before starting your script to give the Desktop more time to complete the booting process before your app starts. This can be done with a bash sleep command. Do not attempt to add the sleep command directly in autostart, it won’t work. Use the sleep command in a bash script instead.
Sample Autostart Files:
Example to start Calculator:
@galculator
Example to start browser:
@chromium-browser www.raspberrypi.org
Example to start a Python 3 script:
@python3 /path/my_script.py
Example to start a Python 3 script with terminal:
@lxterminal -e python3 /path/my_script.py
Example to start a Bash script:
@bash /path/my_script
Example to start a Bash script with terminal:
@lxterminal -e bash /path/my_script
Example to open Lxterminal without running a command:
@lxterminal
Notes on using lxterminal -e:
(Notes below apply when lxterminal -e is used directly in autostart file. The noted behavior may different than what happens when run from the terminal command line).
No ‘ or “ in the path/filename to a script. This means that paths or filenames with spaces cannot be used. Use bash script instead.
Only 1 command per line. (Cannot use ; to specify multiple commands). Put multiple commands in bash script instead.
If the script or command exits to the command line for any reason then the terminal is immediately closed. This means if there is an error or the program terminates then you will not be able to see what happened as the terminal window will flash by too quickly.
Traditional System Method (All Users):
Beginning with the Dec 2020 release, Raspberry Pi OS now uses the /etc/xdg/autostart directory to start some background apps for printer etc. You can use this directory to start apps or scripts which will apply to all users.
Note that autostart here is a directory and not a file.
This method does not use an autostart file. It uses filename.desktop files instead. See example .desktop file below.
Traditional User Method (Specific User):
The traditional method also has a user based option. It requires your filename.desktop file(s) to be located here for pi user /home/pi/.config/autostart/ or for other user /home/{user}/.config/autostart/
You may need to create the auotstart directory if not present
Note that the System autostart file OR User autostart file if present, is run and processed along with the .desktop file(s).
In addition the .desktop files for system /etc/xdg/autostart and the .desktop files in the users home directory /home/pi/.config/autostart/ will all be processed.
Example .desktop file to start File Manager:
[Desktop Entry]
Name=File Manager
Exec=pcmanfm
Type=Application
Give the file a unique name such as pcm.desktop and place it in /etc/xdg/autostart for system wide all users or /home/pi/.config/autostart for specific user.
You can have multiple .desktop files.
neilgl
Re: How to use Autostart - Raspberry Pi OS (Desktop)
Thu Jan 14, 2021 8:04 pm
Good post thanks
Pearl.852
Tue Mar 02, 2021 5:26 pm
Excellent information!! Thanks for posting.
Raspberry Pi Model B Rev 1 (256MB) ......... Raspberry Pi 2 Model B Rev 1.1
Raspberry Pi 3 Model B Rev 1.2 .................. Raspberry Pi 3 Plus Model B Rev 1.3
Raspberry Pi 4 Model B Rev 1.1 (4GB) ....... Raspberry Pi Zero 2 W Rev 1.0
GlowInTheDark
Tue Mar 02, 2021 5:46 pm
What a mess. Way too complicated - and seems to change every few releases of the OS.
All best avoided.
There are much better ways to startup processes on boot.
Poster of inconvenient truths.
Back from a short, unplanned vacation. Did you miss me?
craigevil
Tue Mar 02, 2021 6:02 pm
With /home/pi/.config/autostart all you have to do for a User app is drag and drop.
Raspberry PI 400 Raspberry Pi OS (Debian Sid) Kernel: 5.15.15-v8+ aarch64 DE: MATE Ram 4GB
Debian - "If you can't apt install something, it isn't useful or doesn't exist"
dexington
Re: STICKY: How to use Autostart - Raspberry Pi OS (Desktop)
Fri May 28, 2021 7:20 am
I'd like to know where the documentation is for this?
This is still buggy. I tried to start VNC Server using /etc/xdg/autostart/vncserver.desktop. This kept spawning new vnc server processes until the pi crashes.
I'd love to know why rc.local had to be disabled to implement this. Seems shortsighted, dumb.
klricks
Fri May 28, 2021 2:45 pm
Autostart is run each time a user logs into the desktop (Not necessarily at boot).
Since starting vncviewer initiates a user login, autostart is run again and again and again........ until memory fills up with multiple instances of vncserver.
If you use a script to first check if vncserver is already running then you can use autastart.
#!/bin/bash
if ps aux | grep '[/]usr/bin/vncserver'
then
     echo Already Running
else
     # echo Not running
     vncserver -geometry 1024x768
fi
This will assure that vncserver is only started once.
Note: Do not attempt to write the above script directly in the autostart file. Create a script file and then call the script file from autostart.
GlowInTheDark
Fri May 28, 2021 3:38 pm
rc.local has not been disabled. Where did you get that idea?
But, yes, you are absolutely right that "autostart" is a mess. But many posters on this forum seem to take a "It is what it is, so we have to use it as it is" attitude to it. I think it should just be either:
1) Fixed, so it works reliably and well. I have posted elsewhere about what I mean by this; I need not go into it here.
or
2) Removed.
RossDv8
Tue Jun 22, 2021 8:00 am
I had a cow of a time getting Autostart working for my Pi4B. I could not get the RealVNC server that comes with the Pi (Enabled in raspi-config under 'Interfaces').
In the end I installed tigervnc-scraping-server (which is in the repos)
sudo apt install tigervnc-scraping-server
and that worked. Oddly, the most of the Remore Viewers in Linux Mint (my other computers) could not see it. The problem was solved when I installed the GNOME VNC client called vinagre
sudo apt install vinagre
Later I discovered RealVNC have a download page that has RealVNC Viewer for Linux, which doesn;t need to be installed. It is an executable file like an Appimage.
BACK to the Server.
To get a VNC Server booting at startup I had to use the Autostart method used by Ubuntu.
I created an autostart folder in /pi/.config
mkdir /pi/.config/autostart
Then I created a file in the autostart folder called StartVNC.desktop
The contents of the file are:
[Desktop Entry]
Type=Application
Name=StartVNC
Exec=x0vncserver -SecurityTypes=none
Terminal=true
StartupNotify=false
I made it executable, but I don;t know if that's needed since it is afterall a .desktop file
Terminal=true was supposed to run it in a Terminal so I could see if it was running, but that didn't work.
I also installed gufw
sudo apt install gufw
so that I could easily see if the ufw Firewall was running and see any Firewall Rules.
Then I made sure the port TigerVNC uses was open on all the computers by doing:
sudo ufw allow 5900/tcp
sudo ufw allow 5900/udp
In a Terminal on each including the Pi.
From there, just a reboot of the Pi, and when I started the VNC Viewers on the Linux computers, the Pi was sitting there happily in the window.
I have no idea why the built in RealVNC Server was not visible, but I am happy that the tigervnc-scraping-server was in the Repository :-)
Remember, nobody is listening to you
until you fart ...
electronicstoday
Mon Jul 12, 2021 6:57 pm
All best avoided.
Exactly. This is "The Linux way":
"We have 77 ways of doing that, you should try them all and see which works, but any arbitrary number of them are subject to change, largely undocumented, and without notice"
I don't have time to waste on this. Fail.
ViennaMike
Thu Oct 14, 2021 2:04 am
I have a related, but somewhat different issue. For a script I have, the script requires pulseaudio. I know this starts with the desktop, which explains why using autostart works, but cron and systemd are problematic. But what if I don't want to boot to desktop?
How can I have a script that requires that pulseaudio has been started run automatically on boot regardless of whether booting to CLI or the desktop, and if it makes a difference, regardless of using full Rasbian OS or the Lite version?
brig001
Fri Oct 29, 2021 1:50 pm
Is it possible to autostart on the LCD only?
I use an autostart file in /home/pi/.config/autostart
Brian
calcu
Sun Nov 14, 2021 1:20 pm
I had this working on Buster, i updated to Bullseye and it was working too, but i used now another SSD in other to do a fresh install of Bullseye, and now it's not working.
Anyone knows something about this? i tried to use the global autostart, the personal , put the @lxterminal before @xscreensaver, after, at the end of the file, anything works.
any idea?
Thanks for all
Stargazer2022
Sun Dec 19, 2021 1:33 am
Can anyone give an additional example of the correct syntax for an autostart at bootup of a desktop shortcut? I have a led matrix which does work with the desktop shortcut but can't get it to run at boot on a raspi-3b running buster.
Stargazer2022
Sun Dec 19, 2021 5:37 pm
What's the correct syntax to autostart a desktop shortcut .
Here's what i have in the autostart file:
@lxterminal -e /home/pi/Desktop/Test.desktop
Note-- a terminal window does pop up at reboot but does not run the shortcut
Please help Anybody???
klricks
Mon Dec 20, 2021 3:14 pm
.desktop files can not be executed like scripts.
The simplest solution is to copy your Test.desktop file to the /etc/xdg/autostart folder then don't use the autostart file.
sudo cp /home/pi/Desktop/Test.desktop /etc/xdg/autostart
Refer to the traditional method sections of the write-up in the OP above...
If you prefer to use the autostart file then you would need to copy the contents of the exec= line from the .desktop file...
@lxterminal -e /home/pi/whatever
thagrol
Mon Dec 20, 2021 4:03 pm
Really? You recommend using the global, appplies to all users location? Even if your sysytem has and will only ever have a single desktop users that isn't the best way.
@Stargazer2022
I'd also strongly advise against using a starts on login approach (which includes autostart) as should you have more than one active login you'll get more than one instance of the target program running. Unless that is exactly the behaviour you want.
And if your target code needs to be started at boot but does not require the desktop (i.e. uses no features of the desktop and has no output that you need to be permanently displayed in a terminal window) there are alternative, arguably better methods.
See viewtopic.php?t=314455
Stargazer2022
Tue Dec 21, 2021 12:27 am
Thanks @Klricks for the reply and recommended solution (sudo cp /home/pi/Desktop/Test.desktop /etc/xdg/autostart) however, that also gives the same result of a stuck terminal window on reboot.
Will study the Autostart Beginners Guide you suggested. I have a feeling a bash script will be the solution due to the pi hat to the martix starting prematurely. Really didn't want to get so deep into this but i guess that's the nature of the pi.
thagrol
Tue Dec 21, 2021 1:08 am
The guide I suggested (not the one Klricks did) covers much more than autostart.
That's the nature of Linux. It's not specific to Pi. Windows can be just as complicated too at times.
Incidentally, I suspect the best option is likely to be a custom systemd service. That way you have control over dependencies and an option to restart if it fails.
P1so
Thu Dec 23, 2021 1:16 am
Is it possible to run multiple scripts with autostart?
klricks
Thu Dec 23, 2021 3:01 am
Yes however:
The commands in the autostart file are processed independently at near the same time in a parallel fashion. Or the system does not wait for the previous command to complete before starting the next command. If you have multiple commands or scripts that are dependent on being run in a specific order then you would need to put your commands in a bash script, then call your bash script from autostart.
Stargazer2022
Thu Dec 23, 2021 5:50 pm
Has anyone had any success getting a Led Matrix display to actually start up on boot? I've tried just about every method but the Pi hat fails to load. It does work from a desktop shortcut after boot up.
I'm now thinking it can't be done.
If you have succeeded , please tell us how you did it.
klricks
Thu Dec 23, 2021 6:22 pm
Does your script require network? If so try enabling the wait for network at boot option in sudo raspi-config
Also try using a bash script to start your program after a short sleep delay. Something like this:
#!/bin/bash
sleep 5       #Adjust time as needed
/path_to_your program/your_program
thagrol
Thu Dec 23, 2021 6:42 pm
#!/bin/bash
Don't keep trying random stuff 'til it works. Find out why it's failing and fix the problem. There's advice on doing that in my guide.
Return to “Raspberry Pi OS”
