HermannSW
New bash "operator"   |n   pipes into more than 1 pipe
Tue Sep 14, 2021 12:59 pm
In this posting "C script" pipn.c was posted:
viewtopic.php?f=33&t=319473&p=1913242#p1913242
Normally "n" is no executable:
$ which n
Now creating "n" link to "~/pipn.c" is all that is needed:
$ sudo ln -s ~/pipn.c /usr/local/bin/n
Simple demo for piping into 3 pipes, with 2nd "pipe of pipes":
$ cat /etc/X11/rgb.txt |n 'head -3' "head -55 | tail -17 | wc" "tail -2"
! $Xorg: rgb.txt,v 1.3 2000/08/17 19:54:00 cpqbld Exp $
255 250 250		snow
248 248 255		ghost white
     17      79     407
144 238 144		light green
144 238 144		LightGreen
"n" can be used in the sub pipes as well, with "cat|n":
$ cat /etc/X11/rgb.txt |n 'head -3' "cat|n 'head -55 | tail -17 | wc' 'tail -2'"
255 250 250		snow
     17      79     407
Or just "n":
$ cat /etc/X11/rgb.txt |n 'head -3' "n 'head -55 | tail -17 | wc' 'tail -2'"
255 250 250		snow
     17      79     407
In case normal pipe is good enough for your needs, ok.
If you want to be able to pipe into more than one pipe, you now know "|n".
HermannSW
Re: New bash "operator"   |n   pipes into more than 1 pipe
Tue Sep 14, 2021 1:38 pm
All pipes and pipe commands run in parallel:
https://gist.github.com/Hermann-SW2/c69 ... pipn-c-L36
Therefore you can be lucky to get separate output:
pi@raspberrypi400:~ $ cat /etc/X11/rgb.txt |n 'head -5' "head -5"
255 250 250		snow
248 248 255		GhostWhite
245 245 245		white smoke
255 250 250		snow
Or get mixed output for same command:
255 250 250		snow
255 250 250		snow
This can easily be resolved in redirecting output of the pipes into files, if mixed output is unwanted:
pi@raspberrypi400:~ $ cat /etc/X11/rgb.txt |n 'head -5' "head -5 > out"
255 250 250		snow
pi@raspberrypi400:~ $ cat out
255 250 250		snow
HermannSW
Tue Sep 14, 2021 3:16 pm
trejan wrote:
Tue Sep 14, 2021 3:06 pm
Process substitution + tee can do this already. No additional code needed.
You can definitely not do that with tee:
$ cat /etc/X11/rgb.txt | tee >(head -3) | tail -2
Different output to:
$ cat /etc/X11/rgb.txt |n "head -3" "tail -2"
255 250 250		snow
Please show how you do what "|n" did in the previous example with process substition, as stated in the other thread I cannot see how process substitutions can help to pipe one input to multiple pipes.
trejan
Tue Sep 14, 2021 3:21 pm
It didn't work because you didn't do it properly.
$ cat /etc/X11/rgb.txt | tee >(head -3) >(tail -2) > /dev/null
255 250 250             snow
HermannSW
Tue Sep 14, 2021 6:51 pm
255 250 250             snow
Than you for correcting me!
I know tee for decades -- but only ever saw the single "[FILE]" in synopsis, and not the "files" plural:
$ man tee | head -6
TEE(1)                           User Commands                          TEE(1)
NAME
       tee - read from standard input and write to standard output and files
SYNOPSIS
       tee [OPTION]... [FILE]...
Depending on execution speed, output can happen after command prompt is already available:
pi@raspberrypi400:~ $ echo -e "1\n2\n3\n4" | tee >(wc) >(wc)
1
2
3
4
pi@raspberrypi400:~ $       4       4       8
      4       4       8
This can be corrected by appending "| cat":
pi@raspberrypi400:~ $ echo -e "1\n2\n3\n4" | tee >(wc) >(wc) | cat
1
2
3
4
      4       4       8
      4       4       8
So your method of
... | tee >(cmd1) >(cmd2) ... >(cmdN) > /dev/null
circumvents this, all N command pipes get same input.
Here it can be seen why standard output should go to /dev/null
(because pipe after tee input is different to the N command inputs):
pi@raspberrypi400:~ $ echo -e "1\n2\n3\n4" | tee >(wc) >(wc) | wc
      6      10      56
HermannSW
Tue Sep 14, 2021 7:06 pm
So your method of
Sometimes the command prompt comes too early:
$ cat /etc/X11/rgb.txt | tee >(head -3) >(head -55 | tail -17 | wc) >(tail -2) > /dev/null
$ 144 238 144		LightGreen
255 250 250		snow
     17      79     407
"| cat" has to be used properly (with tee in subshell) in order to delay command prompt, but still get correct output:
$ cat /etc/X11/rgb.txt | (tee >(head -3) >(head -55 | tail -17 | wc) >(tail -2) > /dev/null) | cat
255 250 250		snow
     17      79     407
So the correct way of doing multiple piping should be:
... | (tee >(cmd1) >(cmd2) ... >(cmdN) > /dev/null) ...
P.S:
We talked about this before, since all pipes are processed in parallel, same command output can be different to the one shown above:
255 250 250		snow
     17      79     407
dickon
Wed Sep 15, 2021 8:21 am
That is surprisingly horrible. Congratulations.
My main objections are:
  • It's unsafe
  • It won't work if /tmp is mounted noexec (which isn't all that uncommon)
  • It won't work if /tmp/pipn.c exists but isn't executable
  • It won't work if /tmp/pipn.c exists, is older than your own ~/pipn.c, but isn't owned by you
  • It won't work for anyone else if your ~/pipn.c isn't readable by them (for whatever reason)
  • I fail to see what it buys you over simply sticking a precompiled copy in /usr/local/bin/
Perhaps I'm missing something.
HermannSW
Wed Sep 15, 2021 6:52 pm
I see your points, and if you don't like C scripts, you don't need to use them.
Motivation can be found in intial posting of C forum thread:
viewtopic.php?f=33&t=319473#p1912584
Basically, all in a single file, bash script, C code, can be easily moved somewhere, just modify and immediatly use modified version without doing anything. The new bash operator script easily can just be a compiled C program (although it is not needed since Linux tee command does a better job). C scripts allow to split stuff between bash code and C code, no need to do that, but for development and use of my "gamepad" it was the right solution for me (low level gamepad event code in C from jason White, high level code in bash):
https://github.com/Hermann-SW/4DoF_robo ... ls/gamepad
dickon
Wed Sep 15, 2021 8:23 pm
Mmm, but traditionally you'd use something like a shar file for that sort of thing, and you'd be in a much better state for it. As described in that post, your 'C scripts' are downright dangerous: anyone who manages to get any form of shell on your machine stands a good chance of getting a shell as your user, which may well end up as a root shell given the NOPASSWD sudo issue debated elsewhere...
Not a fan, I'm afraid. Not a fan at all.
ejolson
Wed Sep 15, 2021 9:31 pm
$ which n
255 250 250		snow
     17      79     407
255 250 250		snow
     17      79     407
Or just "n":
255 250 250		snow
     17      79     407
Don't people usually use tee for this?
https://man7.org/linux/man-pages/man1/tee.1.html
HermannSW
Wed Sep 15, 2021 10:24 pm
Yes, see above in this thread, @trejan showed how to use tee correctly to do exactly that.
dickon
Thu Sep 16, 2021 10:57 am
Yeah. I'm more criticising the approach as implemented, which is extremely dangerous on multiuser machines with potentially hostile users on them. All you'd need to do to exploit it is stick an @reboot entry in a user's crontab to create a script to create a suid-user shell somewhere before doing whatever the untrojaned 'script' was designed to do (one per likely command, so /tmp/pipn.c in this case; others have been mentioned), wait for a reboot, wait for the victim to run it, and you're done, hopefully with your victim none the wiser. It isn't sensible, and it isn't safe, and I can't say I'm entirely happy at it being advocated for on a forum like this where naive newbies might come across it and think it's a good idea.
There are ways to mitigate the problems -- the obvious one would be to put the resultant binaries somewhere not under the control of an attacker, such as a ~/.cscache directory or similar -- but that isn't what's happening here.
Yeah. Horrible.
GlowInTheDark
Thu Sep 16, 2021 11:13 am
Yes, but it is all much-ado-about-nothing because we're not TALKING about a "multiuser machines with potentially hostile users on them". We are talking about a Raspberry Pi, which is almost certainly single user and is generally treated as basically in the same security model as a typical home Windows PC - i.e., no security.
And, not only that, but the posts I've seen so far violate a certain sig notation, that says that posters shouldn't criticize other poster's work product. Note: I AM NOT MAKING ANY STATEMENT about whether it is good or not; I am just comparing things I've read on this (and other) threads.
Poster of inconvenient truths.
Back from a short, unplanned vacation. Did you miss me?
dickon
Thu Sep 16, 2021 11:26 am
We're talking about scripts which can be run under Unix -- Pis, yes, but these things are hardly exclusive to that platform. And who are you to tell me that I have to trust every user on every Pi I own with every byte of data on said Pis?
For your use-case, you're probably right. For *everybody*'s? No. And what's stopping (eg.) a student coming across this, thinking it's a good idea, and copying it up to a university network? Nothing that I can see.
bjtheone
Fri Sep 17, 2021 7:03 pm
Learning and practicing "good security" is never a bad idea. Teaching "good security" is always a good idea.
Plus many of my Pi's at home are true multi user machines and sudo is controlled. You obviously have never met an inquisitive 12 year old with internet access....
GlowInTheDark
Fri Sep 17, 2021 8:23 pm
Luckily, I was smart enough to avoid that trap.
HermannSW
Sun Sep 19, 2021 7:53 am
  • It's unsafe
On the very last bullet, "mixed bash and C" execution, or "C scripts".
First, regarding the subject of this thread, I already agreed with @trejan that "tee" is better than using "|n".
Next, I think I have addressed all that. I completely got rid of need to create any auxiliary filesystem file. The C code extracted from C script and compiled with gcc ends up in an anonymous file that lives in RAM (with memfd_create() system call), with no links from filesystem. ELF binary gets created every time (in RAM) when script is executed, then ELF gets run from memory, and finally disappears immediately after it was executed (directly when binary execution starts, by MFD_CLOEXEC flag). This was possible by new C memrun tool, see github repo and documentation for details:
https://github.com/Hermann-SW/memrun/tr ... r/C#memrun
With memrun "C++ scripts" that "run from memory" became possible:
pi@raspberrypi400:~/memrun/C $ echo "2^64" | bc -q | ./run_from_memory_cin.cpp
foo
bar 42
18446744073709551616
This is (executable) run_from_memory_cin.cpp producing above mixed bash and C++ output:
Return to “Raspberry Pi OS”
