Defiant
Re: Gstreamer 1.0 for raspbian
Sun Aug 17, 2014 4:44 pm
I have updated the Gstreamer packages (base, good, bad, ugly) to Version 1.2.4.
Compared with Gstreamer in Debian the following elements have been disabled because of missing dependencies in Raspbian Wheezy:
-bad: mplex, sbc & webp
-good: vpx
Gst-openmax has also been updated to 1.2.
The following new packages have been added:
-python-gst-1.0
-python3-gst-1.0
-libgstrtspserver-1.0-0
-libgstrtspserver-1.0-dev
-gir1.2-gst-rtsp-server-1.0
Also the packages and repository are now signed with my pgp-key 0C667A3E.
Please note that this is the last version I'll compile for Raspbian Wheezy, beginning with 1.4 Gstreamer requires more up to date packages.
gkreidl
Wed Aug 20, 2014 7:26 am
Defiant wrote: Also the packages and repository are now signed with my pgp-key 0C667A3E.
How can I add that key? At the moment apt-get update does not accept parts of your repository.
Minimal Kiosk Browser (kweb)
gkreidl
Wed Aug 20, 2014 7:48 am
gkreidl wrote: How can I add that key? At the moment apt-get update does not accept parts of your repository.
solved using:
gpg --recv-keys 0C667A3E
gpg -a --export 0C667A3E | sudo apt-key add -
but still the following packages are not upgraded (hold back):
gstreamer1.0-plugins-bad gstreamer1.0-plugins-bad-dbg
gstreamer1.0-plugins-good libgstreamer-plugins-bad1.0-0
Defiant
Wed Aug 20, 2014 4:41 pm
Strange, I have tested that on a separate installation. Do you have en entry in /etc/apt/preferences or /etc/apt/preferences.d/?
Can you paste the output of the following commands:
apt-cache policy gstreamer1.0-plugins-bad
apt-get install gstreamer1.0-plugins-bad
Also, are you on irc?
gkreidl
Wed Aug 20, 2014 4:53 pm
I meanwhile ran an upgrade with Synaptic. It seems to work, although there was an error at the end.
gstreamer1.0-plugins-bad:
  Installiert:           1.2.4-1.1
  Installationskandidat: 1.2.4-1.1
  Versionstabelle:
 *** 1.2.4-1.1 0
        500 http://vontaene.de/raspbian-updates/ ./main armhf Packages
        100 /var/lib/dpkg/status
Defiant
Wed Aug 20, 2014 4:56 pm
So you are now on the latest version, what was the error?
thassan
Thu Sep 18, 2014 5:08 pm
Hi, newbie here.
I have been using gstreamer successfully for the past couple of months on a model B Pi with NOOBS. However, today I installed the latest raspbian (09-09-2014) and when I try to install gstreamer i get the following output (see the last few lines):
pi@pi2 ~ $ sudo apt-get install gstreamer1.0
Reading package lists... Done
Building dependency tree
Note, selecting 'libgstreamer1.0-dev' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-base' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-audiosource' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-audiosink' for regex 'gstreamer1.0'
Note, selecting 'libgstreamer1.0-0' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-visualization' for regex 'gstreamer1.0'
Note, selecting 'libgstreamer1.0-0-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-omx-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-ugly' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-base-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-base-doc' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-gnomevfs' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-doc' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-bad' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-base-apps' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-tools' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-omx' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-libav' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-good' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-bad-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-bad-doc' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-videosink' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-videosource' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-pulseaudio' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-ugly-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-good-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-ugly-doc' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-alsa' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-plugins-good-doc' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-libav-dbg' for regex 'gstreamer1.0'
Note, selecting 'gstreamer1.0-x' for regex 'gstreamer1.0'
gstreamer1.0-alsa is already the newest version.
gstreamer1.0-omx is already the newest version.
gstreamer1.0-plugins-bad is already the newest version.
gstreamer1.0-plugins-bad set to manually installed.
gstreamer1.0-plugins-bad-dbg is already the newest version.
gstreamer1.0-plugins-base is already the newest version.
gstreamer1.0-plugins-base set to manually installed.
gstreamer1.0-plugins-good is already the newest version.
gstreamer1.0-tools is already the newest version.
gstreamer1.0-x is already the newest version.
gstreamer1.0-x set to manually installed.
libgstreamer1.0-0 is already the newest version.
libgstreamer1.0-0 set to manually installed.
libgstreamer1.0-0-dbg is already the newest version.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
 gstreamer1.0-omx-dbg : Depends: gstreamer1.0-omx (= 1.0.0.1-0+rpi12rpi1) but 1.2.0-1 is to be installed
E: Unable to correct problems, you have held broken packages.
I have added deb http://vontaene.de/raspbian-updates/ . main to /etc/apt/sources.list and have also done what gkreidl suggested
gkreidl wrote: solved using:
If anyone has a solution please let me know. I really need to get this working soon.
Thanks in advance.
Defiant
Thu Sep 18, 2014 5:21 pm
You have a package gstreamer1.0-omx-dbg from an unknown origin. Since I never created such a package its not coming from me which does not make it my fault :))
Please post the output of
apt-cache policy gstreamer1.0-omx-dbg
Thu Sep 18, 2014 5:54 pm
thassan wrote:Hi, newbie here.
Thanks in advance.
It would appear that the Vontaene GStreamer conflicts with the RPi version in the latest image or installed by undertaking dist-upgrade http://www.raspberrypi.org/forums/viewt ... ne#p606663
Defiant
Thu Sep 18, 2014 6:09 pm
Oh great, and no one told me...
Try this. Create a file /etc/apt/preferences.d/gstreamer with the following contents:
Package: *
Pin: origin archive.raspberrypi.org
Pin-Priority: 1001
then do a dist-upgrade. Then remove the just created file and vontaene.de from sources.list
Thu Sep 18, 2014 6:53 pm
Defiant wrote:Oh great, and no one told me...
Package: *
Pin-Priority: 1001
Unfortunately Collobora who were tasked with compiling Web (Epiphany) Browser on the RPF's behalf have requested an upgrade of many packages so Raspbian Wheezy is no longer a clone of Debian 7.6 ARMHF.
IMHO the time would of been better spent on Debian Jessie 8 (as it is reasonably solid) and compile Maynard & Epiphany etcetera.. The RPF could call it its own Distro :shock:
thassan
Fri Sep 19, 2014 9:46 am
Package: *
Pin-Priority: 1001
Thanks that worked and I was able to install gstreamer successfully, but now my stream is not working anymore.
On the Pi I'm using the following:
pi@pi2 ~ $ raspivid -w 640 -h 480 -fps 20 -b 10000000 -t 0 -o | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=10 pt=96 ! udpsink host=172.17.100.221 port=9000
and on a windows machine to receive the stream I'm using:
C:\gstreamer\1.0\x86\bin\gst-launch-1.0 -v udpsrc port=9000 caps="application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264" ! rtph264depay ! avdec_h264 ! videoconvert ! autovideosink sync=false
This used to work perfectly before the update with minimal lag. But now I'm not receiving anything. Maybe I need to change something in the pipeline?
thassan
Fri Sep 19, 2014 9:51 am
Ah never mind, just did a reboot again and it seems to be working now.
Thanks for the help and the quick responses.
Stetanchi
Mon Oct 20, 2014 7:00 pm
Hi there,
I am having the same issue with installing gstreamer1.0
I tried this
Package: *
Pin-Priority: 1001
But without success.
"apt-get install gstreamer1.0" still terminates with the following error message:
Output of "apt-cache policy gstreamer1.0-omx-dbg":
root@pi1:~# apt-cache policy gstreamer1.0-omx-dbg
gstreamer1.0-omx-dbg:
  Installed: (none)
  Candidate: 1.0.0.1-0+rpi12rpi1
  Version table:
     1.0.0.1-0+rpi12rpi1 0
        500 http://archive.raspberrypi.org/debian/ wheezy/main armhf Packages
Any hint how to get gstreamer installed?
Thanks, Stefan.
Defiant
Tue Oct 21, 2014 4:18 am
Stetanchi wrote: "apt-get install gstreamer1.0" still terminates with the following error message:
did you execute "install" or "dist-upgrade"?
If it still does not work on upgrade try apt-get install gstreamer1.0-omx=1.0.0.1-0+rpi12rpi1
Also you probably don't need the dbg-package...
Stetanchi
Tue Oct 21, 2014 9:35 am
Hi Defiant,
first I executed "apt-get update" and then "apt-get dist-upgrade"
I will give it try with your suggestion tonight.
Thanks, Stefan.
sphaero
Sun Oct 26, 2014 12:24 pm
I'm running the latest Raspbian with gstreamer from vontaene.de/raspbian-updates/ and kernel 3.12.30+ #717 PREEMPT
ii  gstreamer1.0-alsa:armhf              1.2.4-1.1                         armhf        GStreamer plugin for ALSA
ii  gstreamer1.0-omx                     1.2.0-1                           armhf        OpenMAX IL GStreamer wrapper
ii  gstreamer1.0-plugins-bad:armhf       1.2.4-1.1                         armhf        GStreamer plugins from the "bad" set
ii  gstreamer1.0-plugins-base:armhf      1.2.4-1.1                         armhf        GStreamer plugins from the "base" set
ii  gstreamer1.0-plugins-good:armhf      1.2.4-1.1                         armhf        GStreamer plugins from the "good" set
ii  gstreamer1.0-pulseaudio:armhf        1.2.4-1.1                         armhf        GStreamer plugin for PulseAudio
ii  gstreamer1.0-tools                   1.2.4-1.1                         armhf        Tools for use with GStreamer
I'm testing to see if 1080p playback runs smooth through the video example and gstreamer:
./hello_video.bin test.h264
This runs smooth!
# gst-launch-1.0 -v filesrc location=/opt/vc/src/hello_pi/hello_video/test.h264 ! decodebin ! eglglessink sync=false
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, width=(int)1920, height=(int)1080, parsed=(boolean)true, stream-format=(string)byte-stream, alignment=(string)au
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-h264, width=(int)1920, height=(int)1080, parsed=(boolean)true, stream-format=(string)byte-stream, alignment=(string)au
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0.GstPad:sink: caps = video/x-h264, width=(int)1920, height=(int)1080, parsed=(boolean)true, stream-format=(string)byte-stream, alignment=(string)au
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-h264, width=(int)1920, height=(int)1080, parsed=(boolean)true, stream-format=(string)byte-stream, alignment=(string)au
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, framerate=(fraction)0/1
/GstPipeline:pipeline0/GstEglGlesSink:eglglessink0.GstPad:sink: caps = video/x-raw, format=(string)I420, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, framerate=(fraction)0/1
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstDecodePad:src_0.GstProxyPad:proxypad1: caps = video/x-raw, format=(string)I420, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, framerate=(fraction)0/1
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
This doesn't run smooth. As you can see the decodebin uses omxh264dec thus it is hardware decoded. Anybody had more success getting smooth playback? I think using the test.h264 file is the easiest to test with. It should be available on any Raspberry.
There is a newer Gstreamer available (1.4). However eglglessink is deprecated and now merged with glimagesink. Should I be compiling that version?
http://twitter.com/sphaero
http://twitter.com/z25org
Defiant
Sun Oct 26, 2014 5:57 pm
You no longer need the vontaene.de-repository. Gstreamer 1.0 and gst-omx are now in raspbian, probably in a newer version.
So you better update to the raspbian version and remove the extra repository.
sphaero
Sun Oct 26, 2014 8:35 pm
It's not in stable, only in jessie (testing) from what I can see.
I'll try a jessie raspbian as well.
gkreidl
Sun Oct 26, 2014 8:51 pm
sphaero wrote:It's not in stable, only in jessie (testing) from what I can see.
No. it's in the latest image and dist-upgrade. It's needed by the new webkit engine (epiphany browser).
Sun Oct 26, 2014 9:07 pm
sudo apt-get update
sudo apt-get dist-upgrade
This will take you to 24th Oct '14 and should be undertaken as includes the openssl and bash security updates.
sphaero
Sun Oct 26, 2014 10:04 pm
Thanks for the pointer. I missed some sources indeed.
Just tested and it is much smoother :) although gstreamer takes quite some overhead. 50% cpu compared to 3-7%. Anybody got lower cpu burden?
Sun Oct 26, 2014 11:22 pm
sphaero wrote:Thanks for the pointer. I missed some sources indeed.
Did you fully remove the packages installed by the byvontaene.de-repository prior to dist-upgrade ?
sphaero
Mon Oct 27, 2014 8:21 am
Yes it was a clean install. Also it makes sense that displaying through GL is a higher overhead than displaying directly like the hello_video does. Just curious what best performance can be achieved and where the bottleneck would be.
Btw I need to do (add queue)
decodebin ! queue ! eglglessink
to make it smooth. Without it is still stutters a bit.
Ivan Tham
Thu Oct 30, 2014 5:35 am
Can I use Gstreamer1.0 in midori or other browser?
Return to “Raspberry Pi OS”
