nathanjohnson320
Installing node.js (please test)
Thu Sep 05, 2013 5:50 pm
Hello everyone,
I figured I would share this with everyone in hopes that it saves you some time. This application lets you download a node.js package and install it without the need for compiling from source. It takes two steps:
wget http://node-arm.herokuapp.com/node_latest_armhf.deb
sudo dpkg -i node_latest_armhf.deb
you can check the installation with
node -v
Please test it out and let me know if it works.
https://github.com/nathanjohnson320/node_arm
elatllat
Re: Installing node.js (please test)
Thu Sep 12, 2013 4:27 pm
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
garethcoleman
Tue Sep 17, 2013 4:31 pm
Just to let you know I followed these instructions on 0.2 occidentalis and they worked perfectly, getting me the latest node.js version (0.10.18).
Thanks loads, now I'm off to use it with node-RED http://nodered.org/ and WiringPi!
carride
Sat Nov 09, 2013 2:28 am
Did you Make that deb file you are hosting from the NodeJs.org source or from their binary distro? Do you automatically update when they create the new distribution? I wanted to install the latest Node.js binaries directly from Joyent, so here are my notes. Similar to what some others are doing.
https://gist.github.com/7345428#file-ra ... node-js-md
duberry
Location: standing on a planet that's evolving. And revolving at nine hundred miles an hour
Sat Nov 09, 2013 9:36 am
hi
i use some other (non debian based ) disto's
and to install nodejs i have used ( use with caution always backup ! )
# node_url="http://nodejs.org/dist/v0.10.21/node-v0.10.21-linux-arm-pi.tar.gz"
# wget "$node_url"
node_bin="node-v0.10.21-linux-arm-pi.tar.gz"
sudo tar zxf $node_bin --strip-components=1  -C /
for an brief explanation of the command / arguments used see
explainshell.com/explain?cmd= tar zxf $node_bin --strip-components=1 -C
i think this can work on any linux !
although
this method looks a little more thought out than my simple script
also if you like after installing nodejs you can install https://npmjs.org/package/n - node version manager
using
npm install n
.. its possible to install 'n' before installing nodejs ( its just a shell script )
see https://github.com/visionmedia/n/blob/master/bin/n
lend me your arms, fast as thunderbolts, for a pillow on my journey.
If the environment was a bank, would it be too big to fail
so long; and thanks for all the pi
carride
Sat Nov 09, 2013 2:38 pm
Good point with Vision media's N node version management. I'll have to test if it works with the arm-pi distributions. If so, perhaps that is the most reliable way to install Node after first installing NPM.
Thanks for http://explainshell.com site too.
nathanjohnson320
Wed Nov 13, 2013 10:31 pm
Sorry for the late reply,
I wrote a script that downloads and compiles the source whenever they update the changelog website. It's running on a crontab on my pi every four hours which keeps it up to date.
carride
Sat Nov 16, 2013 5:40 pm
Got it. You are building from the original source. Thanks for the update.
gsnneequaye
Tue Nov 26, 2013 2:48 am
Thank you so so much for this, very easy and reliable. I can now proceed to complete my project :) :)
nedyalkov
Wed Dec 18, 2013 8:08 am
Thank you for sharing this information! It works like a charm :)
imajin
Sun Dec 29, 2013 10:51 pm
totally sweet. This save me time and worked perfectly, big thanks!
GrantsPi
Sun Jan 05, 2014 6:19 am
Works great! Thank you for posting it.
rwhitmire
Tue Feb 18, 2014 3:14 am
i made an account just to thank you. I've been struggling to get the latest version of node installed on my pi all night and your package solved my problem :D
Heater
Tue Feb 18, 2014 1:25 pm
duberry,
No way!
As root user you are going to change to the root of your file system "/" and pull the trigger on untaring a package which you hope does not splatter stuff all over the place and destroy your system.
duberry
Tue Feb 18, 2014 7:18 pm
If you have tar and curl installed n.sh works :!:
(dont use my crazy tar arg's ; unless your mad or have made a backup ;or do so at your peril)
No way!
Way !
+ i get-a fresh one (system) on rebooting ....
To destroy the system now n then (because of the digital nature of these system(s) it)
gives the opportunity to 'fix' or at least restore it...
And then append to the list of "dont do X that will destroy your system"!
IIRC the distant past my list started with- dont "delete autoexec.bat" that will destroy your system. :oops:
... probably trying to get a game working from some magazine free demo floppy disks
.. the system was not mine
and i imagine it cost a fair bit more than $35 ! :lol:
Return to “Raspberry Pi OS”
