altella
WiFi connection not worknig automatically at boot up
Sat Aug 30, 2014 8:57 pm
I am using ssh with Ubuntu 14.04, and I have two static PIS in my local network at home, corresponding to my RPI, one for Ethernet and anoher one for my WiFi dongle .
If I connect with SSH using ethernet and connect the wifi, the connection is established, but when I boot the RPI, I am unable to connect through SSH or VNC with the Wifi connection. Ping commands to both IPs are responding correctly ONLY when I have theEthernet connection plugged in. If I only have the WiFi dongle, it does not respond to the Ping command
I want to be able to have the Wifi connection working from the boot automatically. My Wifi dongle is the Tp-Link TL-WN725N V2, and I have installed the driver following the instructions from here http://www.raspberrypi.org/forums/viewt ... p?p=462982 without problems
Any ideas?
Thanks in advance !!
PD: I provide more information in case is needed:
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.12.26+ #704 PREEMPT Wed Aug 20 22:35:11 BST 2014 armv6l GNU/Linux
#auto lo
auto wlan0
iface lo inet loopback
#iface eth0 inet dhcp
# config static IP LAN
auto eth0
iface eth0 inet static
address 192.168.0.99
gateway 192.168.0.1
netmask 255.255.255.0
#network 192.168.0.0
broadcast 192.168.0.255
# end config static IP LAN
allow-hotplug wlan0
iface wlan0 inet manual
#iface default inet dhcp
# config static IP WAN
iface default inet static
address 192.168.0.100
gateway 192.168.0.1
# end config static IP WAN
danjperron
Re: WiFi connection not worknig automatically at boot up
Sun Aug 31, 2014 12:22 pm
Hi altella,
maybe an idea out of my mind.
Both eth0 and wlan use the same IP group ? Maybe a conflict on which port to use?
Are you using a router?
what is the status when you do
sudo ifconfig
could you try to use
instead of wpa-roam. This is more a fix method than like the name says a roam one.
Also I don't know if that make a difference but group all de wlan lines without line space in betweens.
There is others tricks if you are using a router. You could to put the static address at the router dhcpd assignation and use dynamic at the PI.
Daniel
altella
Tue Sep 02, 2014 7:18 am
Hello again;
I finally managed yesterday to test the changes of the final post....
Something strange happens that I cannot understand: If I boot with the ethernet cable plugged in, Ping commands are responding to both Ethernet and Wifi connections correctly. I can also use SSH. However, when I boot with the Ethernet unplugged, the Wifi connection does not work (Host unreachable??). In this situation, if I plug Ethernet again, both connections work again.
I do not understand the problem... maybe it has to do with certain configuration in /etc/network/interfaces.
My final version is:
# LOOPBACK CONNECTION
auto lo
# STATIC ETHERNET CONNECTION
auto eth0
gateway 192.168.0.1
# STATIC WIFI CONNECTION
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
gateway 192.168.0.1
Is it necesary the last line? (iface default inet dhcp)
Any other problems?
Any clue is highly appreciated....
Cheers,
Alberto
Tue Sep 02, 2014 12:08 pm
Remove "network" and "broadcast" addresses, they're just another thing to get wrong and it's easier to let Linux calculate the right value from address & netmask.
Also look at your ifplugd configuration. That stupid piece of software is designed to disable the wireless WLAN0 connection when the ETH0 connection becomes active. My solution to that is sudo apt-get purge ifplugd.
altella
Wed Sep 03, 2014 9:59 am
thank you,
Today I will give it a try.
the Wlan is not deactivated, maybe just the opposite, it works only if Ethernet is plugged in.
If I remove ifplugd, the network will work as always?
Thank you,
Alberto
Wed Sep 03, 2014 10:06 am
ifplugd is a tool that is designed to make your RPi / Linux run the same way that your laptop does. When you connect a wire it disables the wireless. It fiddles with the routing table so that IP packets are sent on the active interface. That's its default function.
Removing it means you have to be in complete control of your network and your routing table, if you connect a new interface you may need to change your route to your gateway.
awair
Wed Sep 03, 2014 10:39 am
Dougie, with reference to ifplugd,
Related to my other thread, does this mean it is better (or necessary) to have (WAN) internet access on wlan0, and any (LAN) Access Point on wlan1, the second wireless adapter?
So connecting eth0 will disconnect wlan0 only, and leave wlan1 running.
Many thanks,
awair
Wed Sep 03, 2014 11:11 am
Alberto,
In response to your last post (just a newbie with respect to this, so heed accordingly), but I've read over a hundred conflicting posts on this in the last few days, so...
Always required:
Three points from this portion:
auto wlan0
allow-hotplug wlan0
gateway 192.168.0.1
1. 'auto wlan0' conflicts with use of wpa_supplicant
2. 'iface wlan0 inet static' needs to be 'manual' for use of wpa_supplicant
3. You can then use 'id_str' in wpa_supplicant.conf to define an interface nickname and a static IP, see below.
My suggested code would be for /etc/network/interfaces:
allow-hotplug wlan0
iface wlan0 inet [b]manual[/b]
iface homewifi inet static
gateway 192.168.0.1
...and for wpa_supplicant.conf, add one line:
# WPA-Personal (PSK)
network={
    ssid="YourHomeWiFiSSID"
    psk="YourHomeWiFiSecret"
    id_str="homewifi"
If someone who knows what they're talking about could let me know if this is all complete rubbish... However, I accept that there may be other ways of dealing with the issue.
Wed Sep 03, 2014 12:16 pm
DO NOT code "broadcast" or "network" in your interfaces file they aren't needed and just give you another thing to get wrong.
This config works!
auto lo
auto eth0
allow-hotplug wlan0
post-up iwconfig wlan0 power off
address 192.168.1.7
gateway 192.168.1.1
netmask 24
update_config=1
network={
        ssid="IAINTTELLING"
        scan_ssid=1
        psk="nottellingyouthiseither"
network={
        ssid="spectrumfree"
        key_mgmt=NONE
        auth_alg=OPEN
altella
Thu Sep 04, 2014 7:21 am
Hi Dougie and awair,
Yesterday I was doing some testing.
First thing I did: sudo apt-get purge ifplugd. ;)
From my interfaces file posted in my last post, I removed "auto wlan0", and the broadcast and network entries.
With this configuration, Wifi network boots with the static IP configured if and only if the ethernet cable is plugged in. "ping" commands to both Ethernet and Wifi are working with the static IP addresses configured.
If the ethernet cable is not in its place I obtain the "host unreachable" error when I boot and I do a "ping" to the wifi connection from my host computer.
I have also tested line by line your respective configurations. For me, they do not work. The Wifi is not connecting automatically in any case, with or without Ethernet :cry:
So, summing up. Having the Ethernet cable connected does something that makes the Wifi connection work at boot up.
I am really running out of ideas, but don´t want to give in yet....
Any other test?
I sincerely appreciate your help....
Cheers,
Alberto
Thu Sep 04, 2014 8:40 am
Look at your routing table.
route -n
It should look something like this.
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.1.1     0.0.0.0         UG    0      0        0 wlan0
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 wlan0
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 eth0
The 0.0.0.0 line tells you which interface is used for traffic that isn't part of your local subnet. So in my example any IP packet destined for an address that isn't in the 192.168.1.0/24 network is routed to 192.168.1.1 (my router). The router works out (from its routing tables) how to get that packet out to the public internet.
To change it to route via eth0 I'd use
ip route del default via 192.168.1.1 dev wlan0
ip route add default via 192.168.1.1 dev eth0
altella
Thu Sep 04, 2014 10:35 am
first of all, thanks a lot Dougie. I do not know if i'll be able to solve the task, but I am learning a lot.
The thing is, I am working in my home LAN, lets say:
Desktop PC: 192.168.0.12
Ethernet Raspberry Pi: 192.168.0.99 (static configured)
WiFi Raspberry Pi: 192.168.0.100 (static configured)
So, after booting:
With Ethernet cable PLUGGED:
Ping from Desktop PC to Ethernet Raspberry Pi ---> OK !!
Ping from Desktop PC to Wifi Raspberry Pi ---> OK !!
With Ethernet cable UNPLUGGED:
Ping from Desktop PC to Ethernet Raspberry Pi ---> Nothing, obvious
Ping from Desktop PC to Wifi Raspberry Pi ---> HOST UNREACHABLE !! :shock: :shock: :shock:
Could it have to do with the routing table as you say? Anyway, i'll test it today.
thanks a lot,
Alberto
altella
Fri Sep 05, 2014 11:16 pm
Hello all;
Just for your interest, I have achieved some advances.
My /etc/network/interfaces is now:
auto lo
auto eth0
allow-hotplug wlan0
iface AlbertoT inet static
gateway 192.168.0.1
And my wpa_suppplicant.conf
update_config=1
network={
        ssid="bla bla bla"
        psk="bla bla bla"
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=TKIP
        auth_alg=OPEN
        id_str="AlbertoT"
Now, with this, I finally have my wifi booting automatically and with an static IP in my local network.
I have seen that if I plug later Ethernet, it takes the same IP than the Wifi.
Is it not possible to have two different IPs for the same raspberry Pi in the same local network?
Thank you for all,
Alberto
eflyguy
Sat Sep 06, 2014 3:01 pm
I too have struggled with this for a couple of days (new to RPi) - I agree with earlier comments that this could be made a little simpler for first-time users. I have a pretty extensive background with unix (I'm an EE/CS in my 40's) but even following specific instructions here and elsewhere, I could not get wifi working until now.
I have found a very similar situation to posted above - the wifi would go down when I *unplugged* ethernet! I discovered, however, that with the following configuration, the device will boot with wifi active and connected.
So here's my config in case it helps others.
uname:
Linux raspberrypi 3.12.22+ #691 PREEMPT Wed Jun 18 18:29:58 BST 2014 armv6l GNU/Linux
lsusb:
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp.
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-20140616.tar.gz
tar -zxvf 8188eu-20140616.tar.gz
sudo install -p -m 644 8188eu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
sudo depmod -a
auto lo
auto eth0
allow-hotplug wlan0
iface Octo inet static
address 10.1.1.35
gateway 10.1.1.1
/etc/wpa_supplicant/wpa_supplicant.conf:
update_config=1
network={
        ssid="my_ssid"
        psk="my_psk"
        proto=RSN
        key_mgmt=WPA-PSK
        id_str="Octo"
Again, this is what has worked for me after two days of struggling. Now to try and replicate this success on the OctoPi image..
eflyguy
Sun Sep 07, 2014 12:37 am
Update - repeated the process on the OctoPi image, but used Lambra's excellent script to install the driver - worked like a charm, and first print (without attached laptop) is completed!
eflyguy
Wed Sep 10, 2014 9:06 pm
... and after a couple of days, it quit working. Now I can't get it working again, even though I rebuilt the image from scratch. It also won't work on a model B board, either.
I did some research and this adapter was problematic for a guy who's tested several USB adapters on the three RPi models. I gave up on the TP-Link adapter. It's back at the store, and I have a Tenda W311MI adapter that (according to elinux.org) is supported without additional drivers. We'll see this evening!
georg.bartzos
working at boot up
Thu Sep 11, 2014 10:54 am
use wpa_passphrase
insert to /etc/network/interfaces ...
auto lo
auto wlan0
iface wlan0 inet dhcp
wpa-ssid routername
wpa-psk. password (wpa_passphrase)
Return to “Raspberry Pi OS”
