bash bug / shell shock now fixed on Raspbian
The well-publicised vulnerability in bash appears to have been fixed in Raspbian some time in the last couple of hours (after 9am, before 1pm Thu 25 Sept 2014 BST). Thank-you to the Raspbian, Foundation and/or other staff that have done this so quickly.
If your Pi is connectable from the outside world, you should update/upgrade urgently.
http://www.theregister.co.uk/2014/09/24 ... hell_vuln/
aoakley@khepri:~$ env X="() { :;} ; echo busted" `which bash` -c "echo completed"
busted
completed
aoakley@khepri:~$ sudo apt-get update && sudo apt-get -y dist-upgrade
The following packages will be upgraded:
bash libnss3
/bin/bash: warning: X: ignoring function definition attempt
/bin/bash: error importing function definition for `X'
completed
busted
completed
bash libnss3
completed
Andrew Oakley - Cotswold Raspberry Jam, Gloucestershire - http://www.cotswoldjam.org
Re: bash bug / shell shock now fixed on Raspbian
Great news. Thanks for posting.
The fixed package was available by the end of Wednesday (UTC) from at least some mirrors.aoakley wrote:The well-publicised vulnerability in bash appears to have been fixed in Raspbian some time in the last couple of hours (after 9am, before 1pm Thu 25 Sept 2014 BST).
If your Pi gives bash unsanitised environment variables from the internet, in contexts where the remote user is not trusted to run arbitrary commands, I suggest disconnecting it to fix that issue and audit your code.If your Pi is connectable from the outside world, you should update/upgrade urgently.
Yeah, I don't get this "bug" at all. Which probably means that it's just never been adequately explained to me.
But, here's my understanding of it. What's the difference between:
and:
The main difference is that in the first method, it just doesn't happen right away.
myfunc() { do something bad when myfunc gets called }
myfunc() { Only do good things here }; do Something Bad here
BBC journalists manage to get things wrong as normal....
"Bash - which stands for Bourne-Again SHell - is a command prompt on many Unix computers. Unix is an operating system on which many others are built, such as Linux and Mac OS."
"a command prompt"... It's an interpreter not a prompt !
And someone who writes "Linux is built on Unix" doesn't understand the history of the relationship.
PeterO
PeterO
Covfefe
Covfefe
That will test whether bash is vulnerable.aoakley wrote:aoakley@khepri:~$ env X="() { :;} ; echo busted" `which bash` -c "echo completed"
To test whether you SYSTEM is vulnerable do
env X="() { :;} ; echo busted" /bin/sh -c "echo completed"
Interesting read, thanks
- Richard-TX
I have known about the bash bug for quite some time. I dismissed it as yet another reason to not use bash as a scripting shell. For more years than I care to admit to, I have insisted at work that everyone write all shell scripts in /bin/sh; if for no other reason than portability. Now I can add security to that list of reasons.
I once went on a job site to do some consulting. I was shown a very elaborate script written in ksh. My comment was, "I see that the author went out of his way to write a script that could only be executed in korn shell." The response was "I hear a lot of that."
Anyway, the bottom line is that my rule to write all shell scripts in /bin/sh seems to be a good one. Not that /bin/sh is totally secure but it seems better than the alternatives.
Richard
Somehow "I told you so" just doesn't quite say it.
Richard
Richard
Doing Unix since 1985.
And you didn't tell anyone ?Richard-TX wrote:I have known about the bash bug for quite some time..
PeterO
- ShiftPlusOne
Probably worth mentioning that it's not fixed in jessie yet.
jessie/testing doesn't get security updates like wheezy/stable does. Instead the updates go straight into (Debian) sid/unstable and then trickle down to jessie within a few days.ShiftPlusOne wrote:Probably worth mentioning that it's not fixed in jessie yet.
Seeing as this is the first search link that comes up for 'raspberry pi shellshock' for me I think its worth mentioning that to update the pi users can open a terminal and type sudo apt-get update and this should install all the packages to fix this bug.
(Correct me if I'm wrong about that, only new to this.)
ty
ty
- DougieLawson
This is hardly a big deal for a stand-alone Pi sitting on a NAT'd LAN with one or two users and no shell access from the public internet for random users.
The BBC article was shouting "#weareallgoingtodie!" over something that's somewhat less than exciting and mostly a trivial thing discovered by a security researcher with too much time on his hands.
I've seen reports on irc that +deb7u1 fixes the initial bug but there is a variant that it doesn't fix
The solution was given in the first post in the thread......shellshock wrote:Seeing as this is the first search link that comes up for 'raspberry pi shellshock' for me I think its worth mentioning that to update the pi users can open a terminal and type sudo apt-get update and this should install all the packages to fix this bug.
ty
PeterO
Should
sudo rpi-update
fix this? It does not here.
Dennis
sudo rpi-update
Dennis
- ShiftPlusOne
Nope, rpi-update is for rpi specific stuff like the kernel and firmware.
I ran
It took a long time to run, supposedly fixed a lot of stuff.
Ran the test and shell shock problem is fixed.
Dennis
Dennis
The patches are not sufficient. A new CVE has been given:
http://web.nvd.nist.gov/view/vuln/detai ... -2014-7169
What if we don't want to fully upgrade the distro, just fix the bash bug?
My understanding is that
...will show which version of Bash is currently installed.
What I don't know is which is the latest / most recent 'bad' version in Raspbian, and which is the earliest 'good' version.
As far as I know
...will install the latest available version of bash over the currently installed version, and then doing this again
..should confirm the new / current version of bash?
After doing this on 25th September 2014 the output from the above command is
Final edit: after a couple of patch-ups, the final fully fixed version now available from the repos for Raspian is
dpkg -s bash | grep Version
As far as I know
sudo apt-get update && sudo apt-get install bash
Version: 4.2+dfsg-0.1+deb7u1
Version: 4.2+dfsg-0.1+deb7u3
Last edited by SiriusHardware on Tue Oct 07, 2014 7:02 pm, edited 1 time in total.
aptitude safe-upgrade bashSiriusHardware wrote:What if we don't want to fully upgrade the distro, just fix the bash bug?
for wheezy: 4.2+dfsg-0.1+deb7u1which is the earliest 'good' version.
for jessie: 4.3-9.1
That works too.sudo apt-get update && sudo apt-get install bash
So you have a version which fixed the first reported issue, but as cyrano reported, it's not all that needs to be fixed.After doing this on 25th September 2014 the output from the above command isCode: Select all
Sorry, you missed a step. apt-get update only updates the list of available packages. After that's done, either run "apt-get upgrade" to upgrade all packages that you have installed for which newer versions are available, or "apt-get install bash" in order to install the latest version of bash, which will replace your currently-installed version.shellshock wrote:Seeing as this is the first search link that comes up for 'raspberry pi shellshock' for me I think its worth mentioning that to update the pi users can open a terminal and type sudo apt-get update and this should install all the packages to fix this bug.
ty
It's good practice to periodically update your system anyway with: apt-get update; apt-get upgrade
For the most up to date fix (the intial fix was incomplete) you need version 4.2+dfsg-0.1+deb7u3 which should have hit the raspbian wheezy repos sometime between midnight and 1AM UK time.
Jessie is still vulnerable to the variant attack right now, hopefully it should be fixed soon.
I ran
# apt-get update
# apt-get upgrade
but my bash is still vulnerable.
# cat /etc/debian_version
7.1
# dpkg -s bash | grep Version
root@domoticzpi:/etc/apt# apt-get update
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Hit http://distribution-us.hexxeh.net wheezy Release.gpg
Hit http://archive.raspberrypi.org wheezy Release.gpg
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Hit http://distribution-us.hexxeh.net wheezy/main armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Hit http://distribution-us.hexxeh.net wheezy/contrib armhf Packages
Hit http://distribution-us.hexxeh.net wheezy/non-free armhf Packages
Hit http://distribution-us.hexxeh.net wheezy/rpi armhf Packages
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_SG
Ign http://archive.raspberrypi.org wheezy/main Translation-en_SG
Ign http://distribution-us.hexxeh.net wheezy/contrib Translation-en_SG
Ign http://distribution-us.hexxeh.net wheezy/main Translation-en_SG
Ign http://distribution-us.hexxeh.net wheezy/non-free Translation-en_SG
Ign http://distribution-us.hexxeh.net wheezy/rpi Translation-en_SG
Reading package lists... Done
root@domoticzpi:/etc/apt# apt-get upgrade
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@domoticzpi:/etc/apt# apt-get install bash
bash is already the newest version.
The following package was automatically installed and is no longer required:
libelf1
Use 'apt-get autoremove' to remove it.
What am I missing?
# apt-get update
# apt-get upgrade
7.1
libelf1
What am I missing?
Indeed. One of the worst security bugs ever (10 out of 10), in the code for 22 years, and you sat on it? The original report for this was 09/24/2014. if anyone knew about this from before that, well, not reporting it was practically criminal. Are you sure you knew about it?PeterO wrote:And you didn't tell anyone ?Richard-TX wrote:I have known about the bash bug for quite some time..
PeterO
