AcidBurns87
Re: Arduino-ide-1.6.5 + due on the Raspberry Pi
Tue Jun 23, 2015 9:39 pm
ok guys, I tried running this on a debian testing system on the RPi2.
I installed custom dependencies:
libastylej-jni, avrdude, libusb-dev, build-dep for arduino (somehow this installs openjdk-7)
and the official ones:
oracle java for rpi (I got the deb file from the raspbian repos), gcc-avr (seems to include avr-gcc and avr-g++), avr-libc, make, ant and git
after that I cloned the arduino repro:
git clone git://github.com/arduino/Arduino.git
and replaced the build.xml with the one from CRImier (https://raw.githubusercontent.com/CRImi ... /build.xml)
compiling with the command "ant" in the Arduino/build directory gives an error after a few seconds:
Buildfile: /root/Arduino/build/build.xml
BUILD FAILED
Target "linux-build linux-libastyle-x86" does not exist in the project "Arduino". It is used from target "linux64-build".
Total time: 2 seconds
I also tried cloning the complete CRImier Arduino git and compiling this; same error.
Compiling on a RPiB+ with Raspbian Jessie also gives the same error. (Only takes a few seconds more)
What am I missing?
Any help highly appreciated!
-Acid
\edit:
forcing the linux arm platform with
ant clean dist -Dplatform=linux -Darch=arm or
also doesn't work...
CRImier
Wed Jun 24, 2015 9:05 am
AcidBurns87 wrote:ok guys, I tried running this on a debian testing system on the RPi2.
Hi!
I'm sorry for this, my build.xml file went to "compile it yourself" to "full Arduino build system integration", so my blog post isn't that relevant anymore =) Now you can make it work using my cloned repository from GitHub and executing the following command:
git reset --hard 6f1bfe1
This evening I'll edit my blog post to make the instructions work.
However, if you just want to make the Arduino IDE work, I suggest you use the already compiled version I've made lately. It is not only already compiled and good to go, it works on Wheezy as well (If somebody wants to see how the process of integration goes, follow this thread).
Once you download my version, just extract it with tar, cd to the directory and execute ./arduino . Should work right away (make sure you have your user in 'dialout' group, if you had older versions of Arduino working without typing sudo, you got it right.) If it doesn't work, please notify me - this is still WIP and I guess things might break =) If it works, I'd be happy if you tested it on every Pi you have - just want to make sure, maybe there's still something I haven't accounted for.
hackaday.io/CRImier
Current project - ZeroPhone
ShorTie
Sun Jun 28, 2015 6:05 pm
Updated build process
KLL
Mon Jun 29, 2015 5:34 am
Thanks CRImier, your latest dropbox pack runs on my RPI model B, WHEEZY raspbian
details see my BLOG.
that is very good news and you should make it a new forum thread,
because if someone start in this one, he waste hours / days working through all posts with the JESSIE... thing until he finds your last ( nearly hidden ) remark about wheezy.
i got it also running from desktop menu, even parallel to the IDE 1.0.1, but somehow
loose the intro picture then.
atmosteam
Mon Jun 29, 2015 5:42 pm
Hi! I followed the steps, I downloaded the arduino-1.6.5-arm_wheezy.tar.xz file.
then I extracted it with
tar –xvf arduino-1.6.5-arm_wheezy.tar.xz?dl=0
now it is located at '/home/pi/arduino-1.6.5'
there is no a icon on the Desktop or something. If I enter to the previous file, I find the arduino program, if I do double click on it, it is opened the arduino ide 1.6.5 successfuly but, I want to see it on my desktop as an icon as the arduino ide 1.0.1, there is also the install.sh file which I try to complete in the LXTerminal but I do not know how to do it in the first steps:
CURDIR='pwd'
APPDIR="$(dirname -- "$(readlink -f -- "${0}")" )"
Does anyone know how to fill it and give me an example?
Tank you
KLL
Tue Jun 30, 2015 12:10 am
@atmosteam as you have the new CRImier zip file in /home/pi/ ( of your ?WHEEZY? system )
or get it with
sudo wget https://www.dropbox.com/s/m4pp9stjhsrc0nf/arduino-1.6.5-arm_wheezy.tar.xz
better extract it to
cd /usr/share/
sudo tar –xvf /home/pi/arduino-1.6.5-arm_wheezy.tar.xz
so there will be
ls arduino that's the prior installed IDE 1.0.1
ls arduino-1.6.5 that's the new IDE 1.6.5
i also not know how to use these install.sh
but here tips about desktop menu
cd /usr/share/applications/
sudo cp arduino.desktop arduino165.desktop
sudo nano arduino165.desktop and change
Name=Arduino IDE 1.6.5
Exec=arduino165
cd /usr/bin/
sudo cp arduino arduino165
change 2 times "/usr/share/arduino" to "/usr/share/arduino-1.6.5"
so now you have 2 icons in desktop menu and can start both IDE, but for the new one possibly not see the intro picture??
blownupp
Sun Aug 02, 2015 5:37 pm
CRImier wrote:...Should work right away (make sure you have your user in 'dialout' group, if you had older versions of Arduino working without typing sudo, you got it right.) If it doesn't work, please notify me - this is still WIP and I guess things might break =) If it works, I'd be happy if you tested it on every Pi you have - just want to make sure, maybe there's still something I haven't accounted for.
Hello! I appreciate the work you've put into this so far, however I'm having a minor issue that no amount of Google seems to be able to solve:
I'm on an RPi2 with Wheezy and I have extracted your precompiled IDE which opens up and runs 'seemingly' normal, but spits out this:
(java:4620): GLib-GObject-WARNING **: Attempt to add property GtkSettings::gtk-entry-select-on-focus after class was initialised
(the following few lines are the same except for after *) ::gtk-entry-password-hint-timeout...
::gtk-can-change-accels...
::gtk-menu-popup-delay...
::gtk-menu-popdown-delay...
::gtk-menu-bar-popup-delay...
::gtk-scrolled-window-placement...
::gtk-button-images... after class was initialised
The main issue I am having however is with the boards manager. When I go and add a custom URL in preferences for additional 3rd party boards, going into Tools -> Boards manager results in:
Downloading platforms index...
Error downloading http://downloads.arduino.cc/packages/package_index.json (which I can access in Chromium without issue, I currently have no firewall running on Wheezy which seems to be the most common issue with that error. I also get more errors in the terminal)
java.lang.RuntimeException: java.lang.Exception: Error downloading http://downloads.arduino.cc/packages/package_index.json
	at cc.arduino.contributions.packages.ui.ContributionManagerUI$3.run(ContributionManagerUI.java:158)
	at java.lang.Thread.run(Thread.java:744)
Caused by: java.lang.Exception: Error downloading http://downloads.arduino.cc/packages/package_index.json
	at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:100)
	at cc.arduino.contributions.packages.ContributionInstaller.download(ContributionInstaller.java:279)
	at cc.arduino.contributions.packages.ContributionInstaller.downloadIndexAndSignature(ContributionInstaller.java:255)
	at cc.arduino.contributions.packages.ContributionInstaller.updateIndex(ContributionInstaller.java:237)
	at cc.arduino.contributions.packages.ui.ContributionManagerUI$3.run(ContributionManagerUI.java:154)
	... 1 more
Caused by: java.net.SocketTimeoutException
	at java.net.SocksSocketImpl.remainingMillis(SocksSocketImpl.java:111)
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
	at java.net.Socket.connect(Socket.java:589)
	at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
	at sun.net.www.http.HttpClient.openServer(HttpClient.java:432)
	at sun.net.www.http.HttpClient.openServer(HttpClient.java:527)
	at sun.net.www.http.HttpClient.<init>(HttpClient.java:211)
	at sun.net.www.http.HttpClient.New(HttpClient.java:308)
	at sun.net.www.http.HttpClient.New(HttpClient.java:326)
	at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1167)
	at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1146)
	at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:997)
	at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:931)
	at cc.arduino.utils.network.FileDownloader.download(FileDownloader.java:137)
	at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:98)
	... 5 more
So I'm a bit at a loss for the moment. My current game plan is to start from scratch and reinstall Java, check and install the various dependencies I've seen mentioned in this thread then try again. While I'm doing that, if anyone has a clear-cut resolution, I would greatly appreciate it as I have been working on this for the past couple days and would really like to use the Arduino IDE with my ESP8266 and Digispark.
Thanks for any suggestions and/or answers!
EDIT: Formatting error
drjohnmarino
Tue Aug 18, 2015 2:36 pm
The archive files for 1.6.5 is no longer there. I have a raspberry pi and an arduino/alamode and i'm looking for a download directly to the pi. I could really use the help! Any suggestions?
fruit-uk
Tue Aug 18, 2015 2:57 pm
It is still there at https://www.dropbox.com/s/m4pp9stjhsrc0 ... ezy.tar.xz but downloads as something like H91kumVpTZqijcfQVypOSdpAIaq9ie18B9XP0f4AB1pTXbTypOR95pPBtfO9Od4D
Simply rename to arduino-1.6.5-arm_wheezy.tar.xz once downloaded
froose
Sat Sep 12, 2015 3:52 pm
Hi guys,
Thanks so much for the information. I too have been looking to resolve this for hours. As I am pretty new to linux, Rpi and Arduino, I didn't really know where to look.
Anyway, I downloaded the above version, got it installed (including the icons), but when I do
./arduino
it throws me the following error (and somehow I feel like this will not be the end of it).
Picked up JAVA_TOOL_OPTIONS:
Exception in thread "main" java.lang.UnsatisfiedLinkError: java.awt.SplashScreen._getInstance()J
   at java.wt.SplashScreen._getInstance(Native Method)
   at java.wt.SplashScreen.getSplashScreen(SplashScreen.java:113)
   at processing.app.Base. <clinit>(Base.java:94)
Could not find the main class: processing.app.Base. Program will exit.
What I would really like to do is simply click the Arduino IDE icon and run the program. But that doesn't seem to do much. Even when I chmod it to 777.
Any help would be appreciated greatly.
Thanks a lot!
Blowfly
Tue Sep 15, 2015 8:54 pm
Thanks a lot!
I do have exactly the same problem on a Raspi B with kernel 3.12.28+... Does anyone have a clue?
Thanks!!!
edbrunelle
Thu Sep 24, 2015 12:32 am
ShorTie, I used your instructions at the beginning of this thread to install Arduino 1.6.5 but when I start I get the following error:
at java.awt.SplashScreen._getInstance(Native Method)
at java.awt.SplashScreen.getSplashScreen(SplashScreen.java:113)
at processing.app.Base.<clinit>(Base.java:94)
what did I do wrong?
Ed Brunelle
Phoenix, AZ USA
edbrunelle
Thu Sep 24, 2015 12:38 am
BTW, I noticed when I copied the binaries that you had, they were named "arduino_1.6.0_all.deb" and "arduino-core_1.6.0_all.deb". Since I need 1.6.5 I didn't use them.
Ed Brunelle
Phoenix, AZ USA
solar3000
Wed Sep 30, 2015 3:50 pm
I read somewhere that you can just:
apt-get install arduino.
I tried it and it seems to work.
Is that different from what everyone here is doing?
Antikythera
PeterO
Wed Sep 30, 2015 3:53 pm
solar3000 wrote:I read somewhere that you can just:
On Weeasy that installed a 1.0.X version. I've not tried it on a Jessie.
PeterO
panik
Wed Sep 30, 2015 5:29 pm
PeterO
In the Jessie repo it's also the 1.0.5 version which indeed works fine if you don't need 1.6.x specific features.
Microcontroller addon boards and software for Raspberry Pi A+/B+/Pi2:
- ARMinARM: ARM Cortex-M3 (STM32)
- AVRPi: ATmega32U4 & ATmega328 ("Arduino")
http://www.onandoffables.com
fruit-uk
Mon Nov 09, 2015 2:15 pm
I see Arduino IDE 1.6.6 is now out, though lots of bug reports already.
I've had a look around the sources but too much for me to follow :(
Sadly still no Pi/arm support but thanks CRImier, ShorTie, NicoHood and others I may have missed, for trying to get it added and thanks to all the others who have helped us keep up until now.
sdpatsdp
Sun Nov 22, 2015 9:31 am
fruit-uk wrote:I see Arduino IDE 1.6.6 is now out
My regard to all the guys that helped me with the upgrade to 1.6.5.
I have to say (sadly!) that I find very unfair not to support ARM build officially, Arduino, even after the problems with name and group, they still want to be an open community, but this looks like a "commercial thing" to go against the ARM platform (Raspberry, Orange, beagleboard and many other boards...).
I love do build projects using the CPU power of "Raspberry class boards" and the I/O versatility of "Arduino class boards" they live together as a charm!
ShorTie
Re: Arduino_IDE-1.6.7/github on the Raspberry Pi
Mon Jan 18, 2016 8:55 pm
Made a build script for github
ShorTie
Wed Jan 20, 2016 1:15 pm
Finished up some code and updated README.md
https://github.com/ShorTie8/Arduino_IDE
yorch
Fri Jan 22, 2016 6:33 pm
i tried to build, but it always stops with these error:
How to solve it?
pi@raspberrypi:~ $ sudo /home/pi/Downloads/Arduino_IDE-master/Arduino_IDE_builder.bash
+ echo -e '\n\nConfiguration values\n\n'
+ Silence_is_Golden=yes
+ echo -e '\n\nSystem check\n\n'
System check
++ date
+ start_time='Fri 22 Jan 18:06:59 UTC 2016'
++ pwd
+ Start_Directory=/home/pi
++ pwd
+ Working_Directory=/home/pi/Arduino/build
+ echo -e '\n\nChecking for root .. \n'
++ id -u
+ '[' 0 '!=' 0 ']'
+ echo 'Yuppers .. :)~'
Yuppers .. :)~
+ [[ '' == \y\e\s ]]
+ echo -e '\n\nJava Checking and setup\n'
++ java -version
++ sed 's/java version "\(.*\)\.\(.*\)\..*"/\1\2/; 1q'
+ Java_Version=18
+ echo
+ [[ 18 != \1\8 ]]
++ uname -s
+ '[' Linux == Linux ']'
++ readlink -f /usr/bin/javac
++ sed s:bin/javac::
++ grep 8
+ '[' /usr/lib/jvm/java-8-oracle/ ']'
+ JAVA_HOME=/usr/lib/jvm/java-8-oracle/
+ export JAVA_HOME
+ echo -e '\n\nChecking for go\n'
Checking for go
++ uname -s
+ [[ ! -f /usr/local/go/bin/go ]]
+ /usr/local/go/bin/./go version
go version go1.4.3 linux/arm
+ echo -e '\n\nDetermining system type\n'
++ uname -s
++ uname -m
++ grep arm
+ '[' armv7l ']'
+ Sys=arm
+ SysTag=armhf
++ nproc
+ [[ 4 > 2 ]]
++ nproc
+ JOBS=5
+ JOBS+=' -s'
+ echo -e '\n\nBuilding Arduino_IDE for arm\n\n'
+ [[ ! -d Arduino ]]
+ cd /home/pi/Arduino/build
+ [[ ! -d toolchain-avr ]]
++ ls linux/avr-gcc-4.8.1-arduino5-armhf-pc-linux-gnu.tar.bz2
+ '[' '!' linux/avr-gcc-4.8.1-arduino5-armhf-pc-linux-gnu.tar.bz2 ']'
++ ls linux/avrdude-6.0.1-arduino5-armhf-pc-linux-gnu.tar.bz2
+ '[' '!' linux/avrdude-6.0.1-arduino5-armhf-pc-linux-gnu.tar.bz2 ']'
+ [[ ! -d astyle ]]
+ [[ ! -f libastylej-2.05.1.zip ]]
+ [[ ! -d ctags ]]
+ [[ ! -f ctags/ctags ]]
+ [[ ! -d listSerialPortsC ]]
+ echo -e '\n\nGetting listSerialPortsC\n'
+ git clone https://github.com/facchinm/listSerialPortsC.git
Cloning into 'listSerialPortsC'...
remote: Counting objects: 74, done.
remote: Compressing objects: 100% (44/44), done.
remote: Total 74 (delta 42), reused 61 (delta 29), pack-reused 0
Unpacking objects: 100% (74/74), done.
Checking connectivity... done.
+ cd listSerialPortsC
+ rm -rvf libserialport
removed directory: ‘libserialport’
+ git clone https://github.com/facchinm/libserialport.git
Cloning into 'libserialport'...
remote: Counting objects: 1101, done.
remote: Total 1101 (delta 0), reused 0 (delta 0), pack-reused 1101
Receiving objects: 100% (1101/1101), 336.29 KiB | 605.00 KiB/s, done.
Resolving deltas: 100% (738/738), done.
++ ls liblistSerials-1.0.5.zip
+ [[ ! -n liblistSerials-1.0.5.zip ]]
+ [[ ! -d arduino-builder ]]
+ [[ ! -f arduino-builder/arduino-builder ]]
+ echo -e '\n\nSome Checksums\n'
Some Checksums
++ cat linux/avr-gcc-4.8.1-arduino5-armhf-pc-linux-gnu.tar.bz2.sha
+ avr_gcc_sha=ecfd88ed4b61ee1508eccf13e2ce8186ac9459fc
++ cat linux/avrdude-6.0.1-arduino5-armhf-pc-linux-gnu.tar.bz2.sha
+ avrdude_sha=ae63dea30e95fab1c066247157c950a602345ded
++ cat arduino-builder-arm-1.3.10.tar.bz2.sha
+ arduino_builder_sha=cfa415e57d21a42960a44a3095691aae5fc13d1d
+ [[ ! -f linux/work/arduino ]]
+ echo -e '\n\nBuilding Arduino IDE for arm\n'
+ ant clean build
Buildfile: /home/pi/Arduino/build/build.xml
subprojects-clean:
clean:
   [delete] Deleting directory /home/pi/Arduino/arduino-core/bin
   [delete] Deleting: /home/pi/Arduino/arduino-core/arduino-core.jar
clean:
   [delete] Deleting directory /home/pi/Arduino/app/bin
   [delete] Deleting: /home/pi/Arduino/app/pde.jar
linux-clean:
   [delete] Deleting directory /home/pi/Arduino/build/linux/work
windows-clean:
macosx-clean:
clean:
build:
revision-check:
     [echo] Latest revision detected in shared/revision.txt is: 1.6.8
     [echo]                      Revision in BaseNoGui.java is: 1.6.8
linux-checkos:
subprojects-build:
compile:
    [mkdir] Created dir: /home/pi/Arduino/arduino-core/bin
    [javac] Compiling 138 source files to /home/pi/Arduino/arduino-core/bin
    [javac] /home/pi/Arduino/arduino-core/src/processing/app/I18n.java:74: warning: '_' used as an identifier
    [javac]   public static String _(String s) {
    [javac]                        ^
    [javac]   (use of '_' as an identifier might not be supported in releases after Java SE 8)
    [javac] 1 warning
     [copy] Copying 64 files to /home/pi/Arduino/arduino-core/bin
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_af.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_af.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_an.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_an.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_ar.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_ar.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_ast.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_ast.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_be.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_be.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_bg.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_bg.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_bs.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_bs.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_ca.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_ca.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_cs_CZ.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_cs_CZ.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_da_DK.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_da_DK.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_de_DE.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_de_DE.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_el_GR.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_el_GR.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_en.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_en.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_en_GB.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_en_GB.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_es.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_es.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_et.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_et.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_et_EE.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_et_EE.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_eu.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_eu.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_fa.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_fa.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_fa_IR.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_fa_IR.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_fi.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_fi.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_fil.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_fil.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_fr.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_fr.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_fr_CA.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_fr_CA.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_fy.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_fy.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_gl.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_gl.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_gl_ES.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_gl_ES.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_hi.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_hi.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_hr_HR.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_hr_HR.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_hu.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_hu.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_hy.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_hy.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_in.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_in.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_it_IT.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_it_IT.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_iw.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_iw.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_ja_JP.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_ja_JP.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_ka_GE.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_ka_GE.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_ko_KR.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_ko_KR.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_lt_LT.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_lt_LT.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_lv_LV.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_lv_LV.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_mr.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_mr.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_my_MM.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_my_MM.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_nb_NO.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_nb_NO.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_ne.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_ne.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_nl.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_nl.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_nl_NL.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_nl_NL.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_pl.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_pl.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_pt.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_pt.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_pt_BR.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_pt_BR.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_pt_PT.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_pt_PT.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_ro.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_ro.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_ru.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_ru.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_sk.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_sk.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_sl_SI.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_sl_SI.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_sq.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_sq.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_sv.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_sv.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_ta.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_ta.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_th.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_th.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_tr.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_tr.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_tzl.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_tzl.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_uk.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_uk.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_vi.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_vi.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_zh_CN.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_zh_CN.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_zh_TW.Big5.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_zh_TW.Big5.properties
     [copy] Copying /home/pi/Arduino/arduino-core/src/processing/app/i18n/Resources_zh_TW.properties to /home/pi/Arduino/arduino-core/bin/processing/app/i18n/Resources_zh_TW.properties
build:
      [jar] Building jar: /home/pi/Arduino/arduino-core/arduino-core.jar
compile:
    [mkdir] Created dir: /home/pi/Arduino/app/bin
    [javac] Compiling 107 source files to /home/pi/Arduino/app/bin
    [javac] Note: Some input files use unchecked or unsafe operations.
    [javac] Note: Recompile with -Xlint:unchecked for details.
build:
      [jar] Building jar: /home/pi/Arduino/app/pde.jar
linux-build:
    [mkdir] Created dir: /home/pi/Arduino/build/linux/work
    [mkdir] Created dir: /home/pi/Arduino/build/linux/work/hardware
     [copy] Copying 26 files to /home/pi/Arduino/build/linux/work
     [copy] Copying 9 files to /home/pi/Arduino/build/linux/work/lib
     [copy] Copying 42 files to /home/pi/Arduino/build/linux/work/lib
assemble:
     [copy] Copying 3 files to /home/pi/Arduino/build/linux/work/tools
     [copy] Copying 1 file to /home/pi/Arduino/build/linux/work/lib
assemble-hardware:
     [copy] Copying 496 files to /home/pi/Arduino/build/linux/work/hardware
     [copy] Copying 230 files to /home/pi/Arduino/build/linux/work/examples
    [mkdir] Created dir: /home/pi/Arduino/build/linux/work/reference
untar-unzip-check:
untar-unzip-download:
untar-unzip-checksum:
     [echo] Testing checksum of "shared/reference-1.6.6-3.zip"
unzip:
     [echo] Unzipping shared/reference-1.6.6-3.zip into folder linux/work/reference/
untar-unzip-check:
     [echo] Testing checksum of "shared/Galileo_help_files-1.6.2.zip"
unzip:
     [echo] Unzipping shared/Galileo_help_files-1.6.2.zip into folder linux/work/reference/
untar-unzip-check:
     [echo] Testing checksum of "shared/Edison_help_files-1.6.2.zip"
unzip:
     [echo] Unzipping shared/Edison_help_files-1.6.2.zip into folder linux/work/reference/
assemble-libraries:
     [copy] Copying 509 files to /home/pi/Arduino/build/linux/work/libraries
untar-unzip-check:
     [echo] Testing checksum of "Firmata-2.5.0.zip"
unzip:
     [echo] Unzipping Firmata-2.5.0.zip into folder linux/work/libraries
untar-unzip-check:
     [echo] Testing checksum of "Bridge-1.6.0.zip"
unzip:
     [echo] Unzipping Bridge-1.6.0.zip into folder linux/work/libraries
untar-unzip-check:
     [echo] Testing checksum of "Robot_Control-1.0.2.zip"
unzip:
     [echo] Unzipping Robot_Control-1.0.2.zip into folder linux/work/libraries
untar-unzip-check:
     [echo] Testing checksum of "Robot_Motor-1.0.2.zip"
unzip:
     [echo] Unzipping Robot_Motor-1.0.2.zip into folder linux/work/libraries
untar-unzip-check:
     [echo] Testing checksum of "RobotIRremote-1.0.2.zip"
unzip:
     [echo] Unzipping RobotIRremote-1.0.2.zip into folder linux/work/libraries
untar-unzip-check:
     [echo] Testing checksum of "SpacebrewYun-1.0.0.zip"
unzip:
     [echo] Unzipping SpacebrewYun-1.0.0.zip into folder linux/work/libraries
untar-unzip-check:
      [get] Getting: https://github.com/temboo/Temboo/archive/1.1.4.zip
      [get] To: /home/pi/Arduino/build/Temboo-1.1.4.zip
      [get] Error opening connection java.io.FileNotFoundException: https://github.com/temboo/Temboo/archive/1.1.4.zip
      [get] Can't get https://github.com/temboo/Temboo/archive/1.1.4.zip to /home/pi/Arduino/build/Temboo-1.1.4.zip
     [echo] Testing checksum of "Temboo-1.1.4.zip"
 [checksum] Could not find file /home/pi/Arduino/build/Temboo-1.1.4.zip to generate checksum for.
BUILD FAILED
/home/pi/Arduino/build/build.xml:94: The following error occurred while executing this line:
/home/pi/Arduino/build/build.xml:576: The following error occurred while executing this line:
/home/pi/Arduino/build/build.xml:195: The following error occurred while executing this line:
/home/pi/Arduino/build/build.xml:210: The following error occurred while executing this line:
/home/pi/Arduino/build/build.xml:222: The following error occurred while executing this line:
/home/pi/Arduino/build/build.xml:785: Could not find file /home/pi/Arduino/build/Temboo-1.1.4.zip to generate checksum for.
Total time: 1 minute 5 seconds
fruit-uk
Fri Jan 22, 2016 9:01 pm
Looks as though https://github.com/temboo/Temboo/archive/1.1.4.zip no longer exists though there are references in google to it
It may be possible to comment out references to it but I don't have the build files here - just an idea
ShorTie
Fri Jan 22, 2016 10:39 pm
Hmmm, that is not my error it's coming from the Arduino/build/build.xml file.
Just got done playing, and didn't see that on the build though.
Got Update_git and Update_Arduino_git working a lot better.
Maybe try them .. :/~
Still need to copy some files I think.
Added a self check too, so it be wise to do a new pull
kolban
Sat Jan 23, 2016 3:46 am
I just downloaded and ran and got the same error as described by @yorch.
FREE book on Raspberry Pi usage and programming
https://leanpub.com/pi
ShorTie
Sat Jan 23, 2016 5:39 am
Seems to have disappeared from github for the time being
here is the file, it goes into Arduino/build
https://www.dropbox.com/s/rssx34cco54w1 ... -1.1.4.zip
Return to “Raspberry Pi OS”
