gkreidl
HOWTO: Install Kodi on Raspbian
Thu Feb 12, 2015 1:57 pm
Update September, 6th, 2017: A lot of information in this thread is deprecated. rascas (kodi package provider) has started a new tutorial which should be used in the future: viewtopic.php?f=66&t=192499
Edit March, 28th, 2016: This update is long overdue
If you want to have the best of both worlds (Raspbian and XBMC, now called Kodi) without having to install different operating systems or using multiple SD cards, you can install Kodi on Raspbian. Here's an easy way how to do that.
kodi 15.2 is now available from the Raspbian repository. For other versions (in some ways optimized 15.x versions or kodi-16) see here: viewtopic.php?f=66&t=109088&hilit=kodi
Installation from the repository:
sudo apt-get install kodi
We have to create the group "input" if it doesn't exist.
sudo addgroup --system input
Install kodi
sudo apt-get update
Create & edit the following file:
sudo nano /etc/udev/rules.d/99-input.rules
enter the following text and save it:
SUBSYSTEM==input, GROUP=input, MODE=0660
KERNEL==tty[0-9]*, GROUP=tty, MODE=0660
sudo nano /etc/udev/rules.d/10-permissions.rules
enter this text and save it:
# input
KERNEL=="mouse*|mice|event*",   MODE="0660", GROUP="input"
KERNEL=="ts[0-9]*|uinput",     MODE="0660", GROUP="input"
KERNEL==js[0-9]*,             MODE=0660, GROUP=input
# tty
KERNEL==tty[0-9]*,            MODE=0666
# vchiq
SUBSYSTEM==vchiq,  GROUP=video, MODE=0660
run the following commands for user pi (if you haven't changed your user name):
sudo usermod -a -G audio pi
sudo usermod -a -G video pi
sudo usermod -a -G input pi
sudo usermod -a -G dialout pi
sudo usermod -a -G plugdev pi
sudo usermod -a -G tty pi
To play full HD video in Kodi, you have to set
gpu_mem=160
in /boot/config.txt (or higher)
Start kodi from the command line with:
kodi-standalone
Solving some additional possible problems
1) See the following post for patching kodi's desktop file
2) For better keyboard support:
Add to /etc/init.d/rc.local:
chmod 0777 /dev/tty0
3) If you still have problems with a black screen after leaving kodi, you might try my "startkodi" script:
viewtopic.php?f=28&t=139758&p=927086
Minimal Kiosk Browser (kweb)
piuser14
Re: HOWTO: Install Kodi on Raspbian
Tue Feb 17, 2015 1:23 am
In addition to your tutorial, how about fixing up the kodi.desktop file in case the user wants to launch the program within the lxde menu > Sound and Video?
sudo nano /usr/share/applications/kodi.desktop
Replace the following:
[Desktop Entry]
Version=1.0
Name=Kodi Media Center
GenericName=Media Center
Comment=Manage and view your media
Exec=kodi <-- this line
Icon=kodi
Terminal=false
Type=Application
Categories=AudioVideo;Video;Player;TV;
Actions=Fullscreen;Standalone;
[Desktop Action Fullscreen]
Name=Open in fullscreen
Exec=kodi -fs <-- this line
OnlyShowIn=Unity;
[Desktop Action Standalone]
Name=Open in standalone mode
Exec=kodi --standalone
OnlyShowIn=Unity;
With:
[Desktop Entry]
Version=1.0
Exec=kodi-standalone <-- this line
Icon=kodi
Terminal=false
Type=Application
Exec=kodi-standalone -fs <-- this line
OnlyShowIn=Unity;
OnlyShowIn=Unity;
expandables
Tue Feb 17, 2015 3:44 am
What about the exit problem? Every time i exit Kodi i get
Exception SystemExit in ignored Exception SystemExit in ignored
Any fix for that?
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
DirkS
Tue Feb 17, 2015 11:40 am
expandables wrote:What about the exit problem? Every time i exit Kodi i get
Any fix for that?
'The' exit problem? I've never seen it...
This is something that should be reported to the Kodi developers, for example on their forum at http://kodi.tv/
tgraudo
Wed Feb 18, 2015 1:11 pm
Yesterday I followed this steps with a "Black Screen" when Kodi exits.
I had no time to see the logs. I will investigate deeper this weekend.
Grettings
DirkS
Wed Feb 18, 2015 1:33 pm
tgraudo wrote:Yesterday I followed this steps with a "Black Screen" when Kodi exits.
Grettings
What happens when you press a key?
DirkS
Wed Feb 18, 2015 1:38 pm
Grettings
Or try
fbset -depth 8 && fbset -depth 16
expandables
Wed Feb 18, 2015 1:55 pm
Is already in kodi-standalone. That person is getting the exit problem i was talking about. :mrgreen:
gkreidl
Wed Feb 18, 2015 2:10 pm
If I start kodi once and exit, I get back to the command line. If I start it a second time, I return to a black screen (but kodi isn't running any more).
I've tried to post a comment at Michaels website, but was blocked by the spam filter.
Otherwise it's really working well for me.
expandables
Wed Feb 18, 2015 2:25 pm
gkreidl wrote:If I start kodi once and exit, I get back to the command line. If I start it a second time, I return to a black screen (but kodi isn't running any more).
That's exactly what i am experiencing .
:mrgreen:
expandables
Wed Feb 18, 2015 2:58 pm
Methanoid
Fri Feb 20, 2015 3:21 pm
Nice guide!
Will this also work on a Pi2? On Ubuntu/Linaro image?
gkreidl
Fri Feb 20, 2015 3:37 pm
Methanoid wrote:Nice guide!
Works on Pi1 and Pi2 (Raspbian); I cannot test it on Ubuntu myself.
eriktheitalian
Fri Feb 20, 2015 5:10 pm
Confirmed. Archlinux arm official repos including kodi. When i'm trying quit kodi then system freezing with black screen.
I cant using enough English language. My writings can be wrong grammer.$
"in micro$oft we not trust"
expandables
Fri Feb 20, 2015 5:52 pm
The system does not freeze Kodi appears to close the windows manager but does not so i create a script to search for a specific string in in the kodi log file
WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
and if it finds that string it will exit kodi and bring you out of the blackscreen.
http://www.raspberrypi.org/forums/viewt ... 3&t=100811
eriktheitalian
Fri Feb 20, 2015 7:32 pm
expandables wrote:The system does not freeze Kodi appears to close the windows manager but does not so i create a script to search for a specific string in in the kodi log file
im tried your fix. when im tried exit, system is not freeze. my tv lcd tv unoparete with hdmi cec. im operating tv and selecting hdmi connection there is no xfce destkop.
SeriyGrey
Sun Feb 22, 2015 11:54 pm
I've installed Kodi but it only works with my remote, not with my keyboard. What's wrong?
gkreidl
Mon Feb 23, 2015 7:46 am
SeriyGrey wrote:I've installed Kodi but it only works with my remote, not with my keyboard. What's wrong?
run
cat /etc/group
Check if the group "input" exists and if it looks like that:
input:x:999:pi,kodi
(if you didn't create a new user are using it instead of "pi")
SeriyGrey
Mon Feb 23, 2015 11:35 am
run
cat /etc/group
input:x:999:pi,kodi
Apparently my user wasn't a member of the input group. So that fixed it, but I have stumbled upon a different problem. Everything worked fine till I rebooted the Pi.
Picture:
http://u.cubeupload.com/riick/photo20150223122949.jpg
What is going on?
Seyaro
Sat Feb 28, 2015 10:37 am
Hey.
Thanks for the guide. However, it seems like commenting out the last three lines in the config is actually what causes the blank screen on exit. At least for me, if I don't comment it out Kodi exits correctly. But if I do as you suggest i need to ssh to the pi and run sudo killall kodi.
gkreidl
Sat Feb 28, 2015 1:24 pm
Seyaro wrote:Hey.
For me it didn't; by commenting out these last three lines I got it to return to a normal screen when started for the first time, but not when starting it a second time.
The real problem is that kodi doesn't exit cleanly, but often crashes, when you exit. Killing kodi.bin from a SSH terminal restarts it and when I exit it again I can return to a normal screen.
The problem has been reported to the package maintainer, but there hasn't been any reaction ASAIK.
Seyaro
Sat Feb 28, 2015 1:49 pm
gkreidl wrote: For me it didn't; by commenting out these last three lines I got it to return to a normal screen when started for the first time, but not when starting it a second time.
Ah, too bad :/
For me it seems to be working flawlessly now anyway, maybe I'm just lucky.
Others might want to try too.
I'm on RPI2 if that matters.
cesqt
Sun Mar 01, 2015 3:59 pm
If you hold down the Ctrl-Alt-F1 keys on your keyboard, you will return to the shell that is active on tty1.
cesqt
Sun Mar 01, 2015 6:28 pm
Here are the two links and code corrections that seemed to solve my problems (so far anyway) with the Raspbian and Kodi implementation above.
http://raspberrypi.stackexchange.com/qu ... d-or-mouse
http://forum.freetronics.com/viewtopic.php?f=37&t=5943
gkreidl
Sun Mar 01, 2015 11:12 pm
cesqt wrote:Here are the two links and code corrections that seemed to solve my problems (so far anyway) with the Raspbian and Kodi implementation above.
This is a different implementation and the problem described in the linked post (no mouse, no keyboard) doesn't exist, if you follow the tutorial in the OP.
Return to “Raspberry Pi OS”
