stefano.setti
Raspberry Pi 3 B Decode and render image with GLES2
Tue Oct 22, 2019 7:41 am
I am new with graphic programming and what I am trying to do is to decode and display with HW acceleration a JPEG on screen in specific position and dimension without X11.
All example that I found doesn't work (https://www.raspberrypi.org/forums/view ... 6#p1555166), I always get this error when compile:
/usr/bin/ld: video/VideoObjects/VideoObjectGLES2_EGL.o: undefined reference to symbol 'eglCreateImageKHR'
/usr/bin/ld: //opt/vc/lib/libbrcmEGL.so: error adding symbols: DSO missing from command line
I am using Raspbian GNU/Linux 10 (buster).
Someone can help me to fix the error or better give some example to achieve what I need?
dividuum
Re: Raspberry Pi 3 B Decode and render image with GLES2
Wed Oct 23, 2019 5:24 pm
The linked code sounds overly complicated. Also you don't necessarily need GL for any of that. You might have a look at a rather small tool I wrote in 2015: https://github.com/info-beamer/tools/tr ... r/showjpeg. Modifying the dst_rect should allow you to place it freely on the screen.
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
Return to “Graphics programming”
