jannis
Re: VLC's support for OpenMAX
Fri Feb 24, 2012 1:12 pm
VLC seems to support OpenMAX IL for doing some decoding stuff:
http://mailman.videolan.org/pi.....72919.html
http://www.jbkempf.com/blog/tag/OpenMax
Did anyone of the devs/beta-board-users test this? May I kindly ask if someone (who has some piece of raspberry hardware) wants to try it out?
Would maybe be more user-friendly for people not used to a command-line only video player.
cloudsloth
Fri Feb 24, 2012 8:27 pm
vlc always does seem to save the day
robwriter
Sat Feb 25, 2012 7:03 pm
I'd like to use the Pi (amongst other things) as a media device, so anything that helps decode MPEG2 is a bonus. I guess that whilst there's a chance that the CPU could decode SD MPEG2 anyway, any kind of help is a bonus.
I realise its a big if, but does anyone know if VLC works in this manner, will it be portable to other programs (such as XMBC)?
jannis
Sun May 13, 2012 8:48 pm
By now I do have a Rasberry Pi and Gentoo is running on it (hardfp by the way :). The demos using OpenMAX (hello_world, hello_audio, hello_video and hello_triangle) all do work fine (a big thank you to Hexxeh here).
Now it might take quite a while until I have xorg-x11 and vlc compiled on the Pi (and by the Pi) and then I can post my own results here.
jannis
Fri May 18, 2012 2:01 pm
Okay, I got VLC compiled but it doesn't seem to be willing to use OpenMAX w/o applying force:
http://forum.videolan.org/viewtopic.php?f=13&t=101149
Let's see how fast they react :)
Desintegr
Mon Jul 30, 2012 1:33 pm
Hi.
I have posted an answer on the VLC forum :
http://forum.videolan.org/viewtopic.php ... 49#p348151
I don't know if this will fix the problem but I will try this soon on my Raspberry Pi !
giaur500
Sun Oct 14, 2012 9:04 pm
So, if there is any solution to make vlc work with OpenMax, I think it's good idea to place OpenMax-enabled .deb in raspbian repository
