I see below three configs related to raspberry-pi board. Can someone here confirm which is the default config to be used to build a kernel for type-b?
arch/arm/configs/bcmrpi_cutdown_defconfig
arch/arm/configs/bcmrpi_emergency_defconfig
arch/arm/configs/bcmrpi_defconfig
Regards,
Subash
- Licaon_Kter
Re: Default kernel config required
arch/arm/configs/bcmrpi_defconfig is
but, this is the minimal set, you need to enable many other options as needed
BFQ+BFS or RT on a RPi? 4'real: https://github.com/licaon-kter/ (source and compiled!)
Does 2012-08-16-wheezy-raspbian kernel's .config available ?Licaon_Kter wrote:arch/arm/configs/bcmrpi_defconfig is
Just boot it up and:joe2act wrote:Does 2012-08-16-wheezy-raspbian kernel's .config available ?
zcat /proc/config.gz
dom wrote:Just boot it up and:joe2act wrote:Does 2012-08-16-wheezy-raspbian kernel's .config available ?Code: Select all
Thanks. That is cool.
$ zcat /proc/config.gz > current-rpi-defconfig
$ cat current-rpi-defconfig
# Automatically generated file; DO NOT EDIT.
# Linux/arm 3.2.27 Kernel Configuration
CONFIG_ARM=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_SCHED_CLOCK=y
This bit of information is a true gem.
It and the following allowed me to finally build a kernel with the modules I need.
http://mitchtech.net/raspberry-pi-kernel-compile/
The new kernel is 5325476 bytes. The one from wheezy-2012-10-28 is 2695192.
I added only one module.
Any suggestions as to why this is so? I presumed the .config from the SD card would reflect the kernel contents.
Peter
Peter
The smaller kernel is the zImage (just rename it to kernel.img). It is compressed.
Anybody have a link to help determine what other options are needed? I was successful in building 3.6.11+ and it runs but now my SPI test program doesn't work. I used default config and pressed ENTER for all new configuration options to accept defaults, but I suspect there's more to it than that. Is there a list of what's needed for the "B" raspberry pi anywhere?Licaon_Kter wrote:arch/arm/configs/bcmrpi_defconfig is
