evanjerry1234
Re: Yet Another Bare Metal Tutorial for the RPi3
Sun Aug 18, 2019 6:08 pm
I'm trying to use Geany on the Pi to learn C++. When I use the 'execute' command, the terminal window that opens is blank. I've not changed the default execute command - it is still set to "./%e". I have tried this on 2 different Pi's with the same result. Is this is a known problem? How can I fix it?
Thanks for Great Tuts
Johnbeaumont
Fri Aug 30, 2019 8:15 pm
Will this tutorial work on rpi4?
bzt
Mon Sep 02, 2019 6:53 pm
I didn't had the chance to get an RPi4 yet, so I couldn't test them. I believe you only have to change the MMIO_BASE define in gpio.h, and they should work. As far as I know, all the devices those tutorials use are available on Rpi4 too.
Cheers,
bzt
Damianoslebo
Sat Jan 04, 2020 3:06 pm
Hi all, did anyone get the 15_writesector example to work? Mine times out on waiting for the initial write available. My model is a 3B+ and I tried with a few different SanDisk microsd's (32 GB class 10 and A1).
bzt
Wed Feb 05, 2020 5:43 pm
I haven't had the time to check it out, but someone claims to have located the problem. Please refer to the open issues on github, if you could confirm that those modifications work for you, that would be great.
Cheers,
bzt
