gms0012
c libs
Sun Jun 15, 2014 7:34 pm
hi friends..
are there c libs available für the bare metal pi?
like the arduino libs?
thanks
JRV
Re: c libs
Mon Jun 16, 2014 12:37 pm
Is this what you are looking for: http://wiringpi.com/
gms0012
Re: c libs
Tue Jun 17, 2014 7:58 am
hi .
i am not sure..
that looks for me that there must be running a linux kernel.. or did i understand it wrong?
Re: c libs
Tue Jun 17, 2014 8:06 am
I'm fairly certain those libraries are only for accessing the hardware from programs written to run under Linux, not with a bare metal system.
Accessing the majority of GPIO functions is fairly easy in bare metal, either from C or Assembler (my preferred method).
hldswrth
Re: c libs
Tue Jun 17, 2014 10:29 am
The thing about bare metal is that its entirely up to you. Any C library is going to be based on a load of low-level functions that are specific to whatever bare-metal kernel they are written for (e.g. write to device, allocate memory, etc.). So a bare-metal C library is meaningless on its own. You need a kernel to go with it, or else have the source code and port the C library to use your own low-level kernel functions.
There is at least one open source C library out there I believe, called newlib, which you could try to port to your kernel. I've not looked at it myself.
Alternatively, perhaps the question is really, has anyone got a bare metal kernel + C library?
gms0012
Re: c libs
Tue Jun 17, 2014 11:18 am
yes.. the last thing would be great..
like this http://www.ti.com/tool/starterware-sitara for the BeageBoard..
is there not such a thing for the RI?
joan
Re: c libs
Tue Jun 17, 2014 11:35 am
All the Linux C libraries use /dev/mem to access the gpios. It should be simple to extract the low level routines (read/write/PUD up/down/off/read mode/set mode) and use them on bare metal.
For instance here is part of the source for the pigpio C library.
int gpioSetMode(unsigned gpio, unsigned mode)
   int reg, shift;
   DBG(DBG_USER, "gpio=%d mode=%d", gpio, mode);
   CHECK_INITED;
   if (gpio > PI_MAX_GPIO)
      SOFT_ERROR(PI_BAD_GPIO, "bad gpio (%d)", gpio);
   if (mode > PI_ALT3)
      SOFT_ERROR(PI_BAD_MODE, "gpio %d, bad mode (%d)", gpio, mode);
   reg   =  gpio/10;
   shift = (gpio%10) * 3;
   if (gpio <= PI_MAX_USER_GPIO)
      if (mode != PI_OUTPUT)
         switch (gpioInfo[gpio].is)
            case GPIO_SERVO:
               /* switch servo off */
               myGpioSetServo(gpio,
                  gpioInfo[gpio].width/gpioCfg.clockMicros, 0);
               break;
            case GPIO_PWM:
               /* switch pwm off */
               myGpioSetPwm(gpio, gpioInfo[gpio].width, 0);
               break;
         gpioInfo[gpio].is = GPIO_UNDEFINED;
   gpioReg[reg] = (gpioReg[reg] & ~(7<<shift)) | (mode<<shift);
   return 0;
int gpioGetMode(unsigned gpio)
   int reg, shift;
   DBG(DBG_USER, "gpio=%d", gpio);
   CHECK_INITED;
   reg   =  gpio/10;
   return (*(gpioReg + reg) >> shift) & 7;
int gpioSetPullUpDown(unsigned gpio, unsigned pud)
   DBG(DBG_USER, "gpio=%d pud=%d", gpio, pud);
   CHECK_INITED;
   if (pud > PI_PUD_UP)
      SOFT_ERROR(PI_BAD_PUD, "gpio %d, bad pud (%d)", gpio, pud);
   *(gpioReg + GPPUD) = pud;
   myGpioDelay(20);
   *(gpioReg + GPPUDCLK0 + BANK) = BIT;
   myGpioDelay(20);
   *(gpioReg + GPPUD) = 0;
   *(gpioReg + GPPUDCLK0 + BANK) = 0;
   return 0;
int gpioRead(unsigned gpio)
   CHECK_INITED;
   if ((*(gpioReg + GPLEV0 + BANK) & BIT) != 0) return PI_ON;
   else                                         return PI_OFF;
int gpioWrite(unsigned gpio, unsigned level)
   DBG(DBG_USER, "gpio=%d level=%d", gpio, level);
   CHECK_INITED;
   if (level > PI_ON)
      SOFT_ERROR(PI_BAD_LEVEL, "gpio %d, bad level (%d)", gpio, level);
      if (gpioInfo[gpio].is != GPIO_WRITE)
         if (gpioInfo[gpio].is == GPIO_UNDEFINED)
            if (level == PI_OFF) *(gpioReg + GPCLR0 + BANK) = BIT;
            else                 *(gpioReg + GPSET0 + BANK) = BIT;
            gpioSetMode(gpio, PI_OUTPUT);
         else if (gpioInfo[gpio].is == GPIO_PWM)
         else if (gpioInfo[gpio].is == GPIO_SERVO)
            myGpioSetServo(
               gpio, gpioInfo[gpio].width/gpioCfg.clockMicros, 0);
         gpioInfo[gpio].is=GPIO_WRITE;
         gpioInfo[gpio].width=0;
   return 0;
If you remove all the error checking and debugging paraphernalia it ends up as bare metal routines.
valtonia
Re: c libs
Thu Jun 19, 2014 9:28 pm
Here's a really ancient all-c library that gives you most of the basic functions. It doesn't include printf as that's quite platform specific. I don't remember where this code came from now - it might even have been from a book!
Anyway, it might be enough to get you started.
http://pastebin.com/C8yhHi4E
