Konsta
[DEV] LineageOS 16.0 (Android 9) for Raspberry Pi 3 B and B+
Thu Jun 27, 2019 11:20 am
Here’s my build of LineageOS 16.0 for Raspberry Pi 3 Model B and Model B+. It is unofficial and unsupported by the LineageOS team. It’s for advanced users only.
Important! This image includes parts that are licensed under non-commercial license (Creative Commons Attribution-NonCommercial-ShareAlike 4.0 International). You may use this build freely in personal/educational/etc use. Commercial use is not allowed with this build!
https://konstakang.com/devices/rpi3/LineageOS16.0/
Sources:
KonstaKANG.com
ViktorWa
Re: [DEV] LineageOS 16.0 (Android 9) for Raspberry Pi 3 B and B+
Sat Jul 06, 2019 9:41 am
Hi!
This build is awesome, thank you very much!
Do you know if there is a way to force portrait mode?
I have tried to add display_rotate=3 to the boot config file, but nothing changes.
I have also tried Android apps such as Set orientation, but those only distort the view not actually rotate the screen.
i read someware that changing the system property config.override_force_orient might work but can that be done without recompiling and stuff?
Regards
Viktor
Konsta
Sat Jul 06, 2019 2:25 pm
Hi!
Regards
Viktor
This (https://www.raspberrypi.org/forums/view ... 3#p1409367) should work but I haven't tested it with this LineageOS 16.0 build (edit. tested, works fine).
No, you don't need to compile anything to change system properties. You'll need root access to mount system partition rw to make modifications, though. There's e.g. several build.prop editors available on the Play Store.
Or in the command line:
su
mount -o rw,remount /system
echo "config.override_forced_orient=true" >> /system/build.prop
KonstaKANG.com
ViktorWa
Sat Jul 06, 2019 3:16 pm
Hi!
Regards
Viktor
This (https://www.raspberrypi.org/forums/view ... 3#p1409367) should work but I haven't tested it with this LineageOS 16.0 build.
su
OK, so that is how you change system properties. I will give it a try and report back.
ViktorWa
Sun Jul 07, 2019 10:28 pm
Hi again!
Your solution worked perfectly!
I ended up sticking the sd card into my ubuntu-laptop and edited the file with sudo.
Then I used the "Rotation control" app to rotate the screen.
I have one more question if you have the time....
The Pi now takes a very long time to find (show picture on) my monitor, compared to when I was running rasbian.
From the time I connect my monitor it takes up to 10 minutes before the picture appears on my screen.
I am using on old laptop panel connected to a vga controller card with a max resolution of 1440x900, it detects my TV right away though.....
I find this very weird as it worked fine when I used Raspian.
I adding persist.dash.max.rep.resolution=1440x900 but that didn't do any difference.
/Viktor
Konsta
Mon Jul 08, 2019 9:02 am
Hi again!
/Viktor
There's debug.drm.mode.force=1280x720 property in /system/build.prop that you can change if you want to experiment with this. Don't think persist.dash.max.rep.resolution does anything here.
How current implementation works, it chooses resolution set by debug.drm.mode.force property from the list of supported resolution display reports through EDID. I don't actually know what happens if the display doesn't support 1280x720 or doesn't send EDID.
KonstaKANG.com
ViktorWa
Tue Jul 09, 2019 5:57 am
That did it!
I change debug.drm.mode.force=1280x720 to
debug.drm.mode.force=1440x900
and my "monitor" was found instantly.
Thank you very much!
Yanazake
Tue Jul 16, 2019 2:56 pm
I tried this, and... am I doing something wrong?
Download image, burn it to sd card with win32diskimager, stick sd card to raspberry and power it up.
That's how it goes, right?
It took... quite a while to boot. About 10 minutes, I think. After that, the screen was just a really small square on my monitor [quarter of it?] with the edges being cut off - couldn't even see properly what was happening. I got a bunch, and I mean a BUNCH of app xxx is not responding. It was locking up every time I tried to do anything.
My board is the 3b+.
Is the 16.0 experimental? Should I try burning version 15?
fishred
Wed Jul 24, 2019 7:51 am
It seems there is something tricky for display config. This works fine when I connect board to my full HD TV but it will display blank screen while using official raspberry touch screen which has a 800x480 resolution.
Konsta
Wed Jul 24, 2019 2:18 pm
You need to use a display that supports 1280x720 resolution. Read comments above if you want to experiment with other resolutions. Resolution is selected with a system property from the list the of supported resolutions display reports via EDID.
Each LineageOS build (14.1, 15.1, and 16.0) actually use different graphics drivers and each have their own set of issues because of that. You're welcome to experiment of course.
KonstaKANG.com
Konsta
Wed Jul 24, 2019 2:19 pm
Yeah, I've heard the official display doesn't currently work so it's unsupported for now.
KonstaKANG.com
fishred
Wed Jul 24, 2019 10:38 pm
It still works when I tried with 15.0. I will compare the config to see if I can find any clue.
evon
Mon Aug 26, 2019 8:54 pm
This is working great on my Raspberry. Is there any way I can dual boot this with another OS?
Konsta
Wed Aug 28, 2019 6:29 am
I think you already got your answer elsewhere. This was also recently discussed here (https://forum.xda-developers.com/showpo ... stcount=19).
KonstaKANG.com
ViktorWa
Sun Oct 06, 2019 3:48 pm
Hi!
My Pi has started freezing after about an hour of use, I can't do anything but remove power. This didn't happen before.
I suspect the micro-SD card is failing, but are there any syslog or such that might give me clues to why the freezes occur?
/Viktor
Konsta
Mon Oct 07, 2019 5:47 pm
Hi!
/Viktor
Yes, there's 'logcat' for Android logs and 'dmesg' for kernel logs. You can connect to your Pi using adb over wifi/ethernet or use a serial console adapter.
KonstaKANG.com
wpHu
Tue Oct 08, 2019 2:13 am
Hi! I am not able to download the zip file from this link https://www.androidfilehost.com/?fid=60 ... 4117904151
wpHu
Tue Oct 08, 2019 9:47 am
The link does not work on Ubuntu 16.04 but works on Win10
Konsta
Tue Oct 08, 2019 11:48 am
Works fine for me with Chrome on Android and Ubuntu 18.04. More likely a browser issue rather than the OS. Or AndroidFileHost just has random issues sometimes with finding mirrors if that's what happened.
KonstaKANG.com
nischebrod
Wed Nov 13, 2019 1:06 pm
Hello, is it possible to output video to composite RCA? I've burn image and run raspberry with tv connected, and there is no any effort, just black screen.
Also, do you interested into further support of your port for rpi3, or prefer to concentrate on rpi4 and drop this?
Konsta
Wed Nov 13, 2019 3:20 pm
No, you need to use a HDMI display that supports 1280x720 resolution.
I don't currently have any active development plans on any Android/Pi project. Busy with other stuff. Maybe there will be some updates in the future if there's something worth releasing. LineageOS 14.1 and 15.1 builds have been discontinued for quite some time now so I can pretty much guarantee I won't be releasing any updates on those (both are open source with build instructions available so you can make a fresh build anytime yourself, though).
KonstaKANG.com
psedog
Wed Nov 20, 2019 11:06 am
Wow, I've never had anything install so easily on a Pi. I burned it. Plugged it into my TV. Hooked up a mouse and away it went. Set the time, connected to WiFi, downloaded an APK and viola. I'm watching TV.
Now to get my IR blaster to work...
Konsta
Sun Dec 22, 2019 2:36 pm
New build.
-update to MESA 19.3 and latest upstream versions of minigbm gralloc, drm_hwcomposer, and libdrm
-set default resolution using a configuration file (see FAQ)
-add vendor init library to set serial number, revision, and resolution properties
-add health HAL to fake battery/charging
-add script to enable audio through 3.5mm jack (see FAQ)
-add initial support for RTC hardware (tested with DS3231)
-update to Linux 4.14.160 kernel and patch known vulnerabilities (CVE-xxxx-xxxx, and more)
-Android security patch level: 5 December 2019 (merged)
KonstaKANG.com
jorge19sf
Wed Dec 25, 2019 6:53 pm
That did it!
good. I have raspberry pi 3b +, the screen shows colors. how can I solve that?. I could explain it step by step I am new with raspberry pi.
Konsta
Thu Dec 26, 2019 7:08 am
That did it!
Please read the FAQ on my site. https://konstakang.com/devices/rpi3/LineageOS16.0/
With the latest build there is a file called resolution.txt in the boot partition which you can edit if you want to change the resolution.
KonstaKANG.com
Return to “Android”
