It's a consumer platform not adhering to the RPi goals<aka education>(even my tablet is running Debian since a while with MATE[Cubian X,it's an Allwinner A20 SoC based tablet], and it's way better with loads of useful software)
If you want some games, try apkenv.(tested both on my Pi and on CubianX ) or check for Java-compatible ones.
There is nearly no hope to get it working *natively*(GPU buffer management sucks).
*** post number 300
Re: Android is useless
IIRC, Android running on VC4 did need a lot of changes for buffer management. Which has never been ported to the pi.
Where is the "full source code" of that? Even if it's here,the Pi has only OpenGL ES 2.0 support so it will not run most of the newer games.jamesh wrote:IIRC, Android running on VC4 did need a lot of changes for buffer management. Which has never been ported to the pi.
Can you do a "while ( aAndroidThreadIsAlive() ) { lockIt() }" or lock the complete subforum and add one for Ubuntu (Snappy)?
Could you please post some information about building apkenv for the RPi? Thanks.mimi123 wrote:If you want some games, try apkenv.(tested both on my Pi and on CubianX )
Internal Broadcom. No idea where it is now.mimi123 wrote:Where is the "full source code" of that? Even if it's here,the Pi has only OpenGL ES 2.0 support so it will not run most of the newer games.jamesh wrote:IIRC, Android running on VC4 did need a lot of changes for buffer management. Which has never been ported to the pi.
It is the same as the sunxi version(linux-x11 branch) with my X11EGLRPI layer.gyeben wrote:Could you please post some information about building apkenv for the RPi? Thanks.mimi123 wrote:If you want some games, try apkenv.(tested both on my Pi and on CubianX )
We should scrap the gaming section too, then. And ban Eben from ever again uttering the phrase 'pretty good media player'.
gralloc is stable now. (vc4-drm uses the same ABI, dma_buf as the ARM Mali gralloc) and it works well.
why don't we just shift this discussion here and free up the stress from the moderators...
https://groups.google.com/forum/#!forum/android-rpi
My apologies for shameless YouTube Plugs...
youtube.com/sahajsarup
twitter @sahajsarup
skype srics1996
e-mail: sahajsarup@gmail.com
Blog: http://www.geektillithertz.com/wordpress
Web: http://www.geektillithertz.com
twitter @sahajsarup
skype srics1996
