(Please excuse my norwegian-english..)
I've just bought my first Raspberry pi (ver 2), and started this topic to share my progress on building a pi-driven gameboy classic.
I know that this has been done successfully many times before, but I think I have some ideas to share with you guys.
The nostalgic feeling I got when opening the package containing the case was indescribable, even though the case is just a china-copy.
I started visualizing how I wanted it to look, and I started to make changes to the case.
First of all, I extended the LCD-hole to make room for a 3,5" screen, then i gutted the back-side of the case as much as possible. And this was the result.
Now I had to figure out what screen to use.
To be honest, I thought that composite video out was removed, but it was actually just moved inside the audio socket! :p
Every screen I found that connected via GPIO or DSI had this annoying offset (black vertical stripe), and that wouldn't work great with the case. But then i finally found a dead centered 3,5" LCD-screen that would fit the case perfectly
After figuring out that composite video is still present, I don't know if this is the screen I will use eventually.
It costs atleast three times more than the average 3,5" rear view car display, but I don't need to cut or modify no LCD controller-board.
I also wanted to add more buttons. Preferrably six, to be able to emulate psx. Two more in front, and four shoulder buttons.(Currently I am thinking about how to be able to play N64-games with the planned button set-up..)
First, I was playing with the shoulder buttons of a SNES-controller. It would've been awesome to fit four of them at the back of the Gameboy, but I scrapped that thought because of all the space it would take.
And since I had allready torn apart a SNES-controller, I didn't want it to go to waste.
So this is what I ended up with.
Backside
And both front and back
I really messed up when making the two extra holes in the front, by making them too big.. Now I am trying to figure out the best way to fix it without having to buy a new front.
I am trying to figure out what kind of juice I am going to feed the beast.
By salvaging batteries from dead laptops, I have two types of Li-Ion available. The classic round 18650, and a flat type.
The 18650 is rated at 2400mAh, and the flat is at 1900mAh. Some assembly needs to be done before I decide on which battery to use.
I have ordered:
Audio amplifier.
Battery charge/protection circuit
DC to DC step-up converter (5v)
Power switch
Volume thumb-potmeter
Silicone buttons
I am going to order:
3,5" LCD screen
Common ground dmg button pcb
Teensy
4 pole minijack socket
I am also planning to take apart a game-cartridge and superglue it to the game slot, to get some more space.
Do I have everything covered? :p
Time will tell.
Input is appreciated.
TO BE CONTINUED..!
