jdonald
Re: Quake and Quake III, but not Quake II?
Fri Nov 23, 2018 4:09 am
JohnnyDub wrote:
Wed Feb 07, 2018 1:33 am
MESA-LOADER: failed to retrieve device information
R_InitContext(): Got an OpenGL version 0.0 context - need (at least) 1.4!
ref_gl::R_SetMode() - invalid mode
ref_gl::R_Init() - could not R_SetMode()
ERROR: Loading ref_gl1.so as rendering backend failed!
Does anyone know whats wrong. I tried everything..rebuilding a secound time..no errors. Now I'm considerably pissed. :oops: :?
Hey JohnnyDub, sorry you never got an answer to this in the past 9 months. For you or anyone else who comes across the same problem I have the following thoughts on troubleshooting:
• Did you remember to run sudo raspi-config and enable the full OpenGL driver with KMS? (Included in spidey57's original instructions, but could have been missed in all the followup.)
• Confirm that the kernel module loads on boot. Run lsmod | grep vc4
• Check if it user software can see it by running sudo apt install mesa-utils, check glxinfo for version 1.4 or higher, and confirm you're getting 60 fps if you run glxgears. Unfortunately there's a lot that can still go wrong with the graphics driver ranging from a patched kernel to the wrong hardware.
• Among the latter requirements, can you confirm you're testing on a Pi 2 or newer? Full OpenGL is not supported on the Pi 1 or Zero.
• Don't use BerryBoot, which mandates the legacy driver.
• When all else fails there's rpi-update which updates the kernel, firmware, and VideoCore blobs.
MattPurland
Wed Jul 01, 2020 10:00 am
Hi Guys,
i followed spidey57 description and got Quake II running with OpenGL_es. It was running ok... if any lighting was on the screen it started dropping the framerate to much to be playable. The i discovered jdonalds thread about the newest branch in normal gl. I downloaded the github repo. Followed exactly the descirption in the readme text with this result: ....everything fine....then this:
Yamagi Quake II v7.11pre
Client build options:
 + SDL2
 - CD audio
 + OGG/Vorbis
 + OpenAL audio
 + Zip file support
Platform: Linux
Architecture: arm
Byte ordering: little endian
Added packfile './baseq2/pak0.pak' (3307 files).
Added packfile './baseq2/pak1.pak' (279 files).
Added packfile './baseq2/pak2.pak' (2 files).
Added packfile '/home/pi/RetroPie/roms/ports/quake2//baseq2/pak0.pak' (3307 files).
Added packfile '/home/pi/RetroPie/roms/ports/quake2//baseq2/pak1.pak' (279 files).
Added packfile '/home/pi/RetroPie/roms/ports/quake2//baseq2/pak2.pak' (2 files).
Using '/home/pi/.yq2//baseq2' for writing.
execing default.cfg
execing yq2.cfg
execing config.cfg
You can't bind the special key "ESCAPE"!
couldn't exec autoexec.cfg
Console initialized.
------- sound initialization -------
LoadLibrary(libopenal.so.1)
AL lib: (WW) alc_initconfig: Failed to initialize backend "pulse"
...opening OpenAL device:ok
...creating OpenAL context: ok
...making context current: ok
OpenAL settings:
AL_VENDOR: OpenAL Community
AL_RENDERER: OpenAL Soft
AL_VERSION: 1.1 ALSOFT 1.15.1
AL_EXTENSIONS: AL_EXT_ALAW AL_EXT_DOUBLE AL_EXT_EXPONENT_DISTANCE AL_EXT_FLOAT32 AL_EXT_IMA4 AL_EXT_LINEAR_DISTANCE AL_EXT_MCFORMATS AL_EXT_MULAW AL_EXT_MULAW_MCFORMATS AL_EXT_OFFSET AL_EXT_source_distance_model AL_LOKI_quadriphonic AL_SOFT_buffer_samples AL_SOFT_buffer_sub_data AL_SOFTX_deferred_updates AL_SOFT_direct_channels AL_SOFT_loop_points AL_SOFT_source_latency
Available OpenAL devices:
- ALSA Default
- bcm2835 ALSA, bcm2835 ALSA (CARD=ALSA,DEV=0)
- bcm2835 ALSA, bcm2835 IEC958/HDMI (CARD=ALSA,DEV=1)
Current OpenAL device:
- OpenAL Soft
Number of OpenAL sources: 31
Starting Ogg Vorbis.
Ogg Vorbis not initializing.
Sound sampling rate: 0
----- refresher initialization -----
LoadLibrary(ref_gl1.so)
Refresh: Yamagi Quake II OpenGL Refresher
Client: 7.11pre
Refresher build options:
 + Retexturing support
 - Gamma via X11
SDL version is: 2.0.7
SDL video driver is "x11".
setting mode 4: 640 480
Shutting down OpenAL.
Cmd_RemoveCommand: force_centerview not added
Cmd_RemoveCommand: +mlook not added
Cmd_RemoveCommand: -mlook not added
Shutting down input.
recursive shutdown
Error: Couldn't load a rendering backend!
Apologies for resurrecting an old thread, but I'm getting the same issue. Though with the latest commit, instead of failing completely, it's falling back to the software renderer - which does run at full speed on the RPi4. So it's at least playable.
I may contact the developer and get their input - as the RPi4 does support OpenGL 2.1, so the OpenGL 1.4 renderer should work (I pressume, I've no idea on OpenGL backwards compatibility)
Gavinmc42
Wed Jul 01, 2020 10:04 am
Vulkan based vkQuake?
viewtopic.php?f=63&t=277779
I'm dancing on Rainbows.
MattPurland
Wed Jul 01, 2020 11:23 am
I literally just found Yamagi Quake 2 has a Vulkan branch:
https://github.com/yquake2/yquake2/tree/ref_vk
I don't have a RPi3 free to test this with the new Vulkan driver, and there's not a Vulkan driver for RPi4 (yet)
Gavinmc42
Wed Jul 01, 2020 1:11 pm
Pi4 Vulkan
viewtopic.php?f=63&t=277125&p=1678832&h ... n#p1678832
I did get it working and then broke it ;)
A path issue or missed step?
I got a bunch of Vulkan examples and demos and they all compiled in 32 and 64bit but popped an error when trying to run.
I probably should go back and try again.
It is probably not far away now for some beta guys, at least for 32bit.
MattPurland
Wed Jul 01, 2020 2:28 pm
Pi4 Vulkan
I'm aware of the new Vulkan driver, but wasn't sure what state it's in as there's no official release
MattPurland
Wed Jul 01, 2020 3:20 pm
Just tried the Vulkan version of yQuake2 on a RPi4 and got the following error:
...found 1 Vulkan-capable device(s)
Could not find a suitable physical device!
R_InitContext() - could not initialize Vulkan!
Shutting down Vulkan
Real display mode: 800x480@60 (vid_fullscreen: 0)
Enabled extensions: VK_KHR_surface VK_KHR_xlib_surface
...created Vulkan instance
...created Vulkan surface
vk: error: v3dv_GetPhysicalDeviceProperties2: ignored VkStructureType 1000212000:VK_STRUCTURE_TYPE_PHYSICAL_DEVICE_PCI_BUS_INFO_PROPERTIES_EXT
WARNING: v3dv is neither a complete nor a conformant Vulkan implementation. Testing use only.
Looks like we'll have to wait for the driver to be more complete
spidey57
Fri Jul 03, 2020 9:41 pm
Hi Matt
Just ran through compiling this on Rpi4 4gb (its been a while)...
get source code
https://deponie.yamagi.org/quake2/quake2-7.43.tar.xz
extract from archive
sudo apt-get update
sudo apt-get install build-essential libgl1-mesa-dev libsdl2-dev libopenal-dev libcurl4-openssl-dev
make
compile ok
copy
pak0.pak 175.5mb
into /release/baseq2
cd /quake2-7.43/release
./quake2
defaults to opengl 1.4
running ok here
My version of Raspbian:-
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
cat /etc/rpi-issue
Raspberry Pi reference 2020-02-13
Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, 5f884374b6ac6e155330c58caa1fb7249b8badf1, stage4
Hope this helps
Gavinmc42
Mon Jul 27, 2020 9:54 am
Have not been on my Pi's for a few days, just noticed this.
vkquake is working.
http://planet.igalia.com/
spidey57
Fri Oct 23, 2020 10:26 pm
Quake2 on Rpi4 using Vulkan driver.
Just had a quick look at this...
If you follow my post at
viewtopic.php?f=78&t=180667&start=25#p1690172
But get the Vulkan source code for yamagi quake2 at:-
Select the ref_vk branch and download the zip file. Unzip & compile as usual.
Now follow Mike's script at
This will take a while to run so put the kettle on ....
Now when you are in the release folder and before running ./quake2
export VK_ICD_FILENAMES=/home/pi/local-install/share/vulkan/icd.d/broadcom_icd.armv7l.json
and quake2 should start - now set the video option to Vulkan.
QBall1977
Mon Oct 26, 2020 1:03 am
Thought this was the final missing piece of the puzzle. Followed the steps. I really appreciate you taking the time, but when I run quake2 it seems to try to load and then comes back with a segmentation fault. The version yQuake2 not using Vulkan runs fine.
I made sure to set the path to export VK_ICD_FILENAMES=export VK_ICD_FILENAMES=/home/pi/local-install/share/vulkan/icd.d/broadcom_icd.armv7l.json
infact I tried to use the locate command to find any versions of this icd, locate icd
I have tried all of these versions, it crashes out, but also leaves the screen resolution at 1280.
/home/pi/mesa/_build/src/broadcom/vulkan/broadcom_icd.armv7l.json
/usr/local/share/vulkan/icd.d/broadcom_icd.armv7l.json
/usr/share/vulkan/icd.d/broadcom_icd.armv7l.json
This is the error...
Product: Yamagi Quake II
Version: 7.44pre
Platform: Linux
Architecture: arm
Compiler: 8.3.0
Signal: 11
Backtrace:
Segmentation fault
Any further suggestions would be greatly appreciated.
____________________________________________
Looking for where to start - try Kernel Panic - http://goo.gl/EEQ5J
spidey57
Mon Oct 26, 2020 2:22 pm
Hi Q
Try
not
maybe?
leggazoid
Sun Nov 08, 2020 1:43 am
https://github.com/kondrak/vkQuake2
I had this working recently.
I had to reinstall and have not recompiled it yet. Still working on getting Vulkan working on Pi OS 64-bit.
Old Kid
Sat Jan 02, 2021 11:22 am
@leggazoid,
Can you explain your process for getting vkQuake2 working? I have been beating my head on this problem for a while now. Here is what I have tried in a nutshell...
I have gotten the Vulkan drivers working on the Pi4 Raspberry Pi OS 32-bit and have a working Vkcube spinning around :D
Methodology for how I installed the Mesa Vulkan drivers here: http://www.old-kid.com/vulkan/
From the Github compiling instructions, I was under the impression that vkQuake 2 required the Vulkan SDK.
AFAIK there is no version of it for the Pi, but a forum member explained to me that I didn't need the whole SDK, just the header files and loader:
https://github.com/KhronosGroup/Vulkan-Loader
https://github.com/KhronosGroup/Vulkan-Headers
This outputs a bunch of ".h" headers at /home/pi/Vulkan-Headers/build/install/include/ (assuming you cloned into your home/pi directory)
and "libvulkan.so,libvulkan.so.1 and libvulkan.so.1.2.165" at /home/pi/Vulkan-Loader/build/loader/. The makefile references $VULKAN_SDK, so I tried to make sense of the directory structure it is looking for and copied those files into a format it understands...
export VULKAN_SDK=/home/pi/vulkanbuildfiles
/home/pi/vulkanbuildfiles/lib/ === put library files here...?
/home/pi/vulkanbuildfiles/include/ === put headers here...?
Perhaps my problem is that the makefile is not correctly linking the files provided by the loader and header, but I am not sure what I am doing wrong.
It seems no matter what I do, I am getting an error at the launch of ./quake2:
------- Loading ref_vk.so -------
LoadLibrary("/home/pi/vkQuake2/linux/releasearmv7l/ref_vk.so")
ref_vk version: Vulkan (vkQuake2 v1.5.5)
Initializing Vulkan display
...setting mode 11: 1920 1080
Using XFree86-VidModeExtension Version 2.2
./quake2: symbol lookup error: /home/pi/vkQuake2/linux/releasearmv7l/ref_vk.so: undefined symbol: __atomic_store_8
I keep getting the advice that I needed to add "-latomic" to the make command when compiling vkQuake2, but so far it has not corrected this. I have also tried adding this flag to the compiling of the Vulkan-Headers and Vulkan-Loader as well, but it doesn't seem to make a difference.
I am excited to see what you have done to make this work so I can correct my build process!
Return to “Gaming”
