DarkPlatinum
Contact: YouTube
Re: How to setup Minecraft 1.12.1 on Raspberry Pi 3
Sat Sep 08, 2018 7:20 pm
leafs444 wrote:
Sat Sep 08, 2018 3:27 am
unclebod wrote:
Sat Aug 18, 2018 12:04 pm
leafs444 wrote:
Sun Jul 29, 2018 8:47 pm
I made a installer script for the whole process. rpiMike you can update the forum with it if you want. :D
do this in terminal: git clone https://github.com/Minecraft1-12-2Pi/Mi ... 1.12.2.git
That script takes some time to run for me.... (OK, it starts with a system upgrade, so that could explain the time it takes)
Also, it is hardcoded about where in the directory tree the Minecraft1.12.2 folder is. Not the best to do...
After placing it in the correct place, I've found at least two bugs in the script:
The optifine it downloads is not correctly moved do Downloads
It installs 1.12.1 version of optifine
I'm going to do the 1.12.2 install manual, I think...
Could you please update the readme with eaxtly what it installs?
It's still in beta testing. What do you mean by "Could you please update the readme with exactly what it installs?"? Also, if you'd like to work with me on this, I'm open.
survivalcraftofthemc@gmail.com
I think he/she means in your readme file, post what your script installs, Optifine 1.12.2, mods, etc
leafs444
Sat Sep 08, 2018 8:00 pm
DarkPlatinum wrote: [quote=leafs444 post_id=<a href="tel:1362873">1362873</a> time=<a href="tel:1536377275">1536377275</a> user_id=273986]
[quote=unclebod post_id=<a href="tel:1354462">1354462</a> time=<a href="tel:1534593878">1534593878</a> user_id=271036]
[quote=leafs444 post_id=<a href="tel:1346709">1346709</a> time=<a href="tel:1532897221">1532897221</a> user_id=273986]
[/quote]
[/quote]
[/quote]
I fixed the repo, should work now. The official optifine download page uses a verification key. That is why it wouldn’t work.
leafs444
Sun Sep 09, 2018 1:17 pm
RazCat
Tue Oct 02, 2018 6:52 am
I'm getting soild 40fps with a texture pack playing online on the pi3 B v1.2, happy days, also using leafs 1.12.2 repo[Image
Unbelievable Jeff
leafs444
Tue Oct 02, 2018 12:36 pm
Great, maybe I’ll work on forge soon!
JamesPi123
Wed Oct 10, 2018 10:03 pm
Minecraft doesn't even open for me - I get a crash log every time
rpiMike
Wed Oct 10, 2018 10:11 pm
Which model of Pi? Which OS? Which version of Minecraft are you trying to run? What is the error?
JamesPi123
Wed Oct 10, 2018 10:15 pm
Raspberry pi 3 B (not B+) with latest software (updated last night) and OptiFine 1.12.1 HD U C5 from optifine.net as per your instructions
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 299 100 126 100 173 136 187 --:--:-- --:--:-- --:--:-- 187
todays access token = (censored for security)
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0. 72
MINECRAFT_UUID= (censored for security)
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/logging/log4j/Level
at net.minecraft.launchwrapper.Launch.launch(Launch.java:94)
at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
Caused by: java.lang.ClassNotFoundException: org.apache.logging.log4j.Level
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
... 2 more
rpiMike
Thu Oct 11, 2018 8:36 am
When you installed Minecraft did you 'edit profile' and select use 'release 1.12.1' ?
d_a_v_e
Tue Oct 16, 2018 2:16 am
So I got the game to launch finally using minecraft 1.12 and the optifine provided in the original post. However, when I try to create a world, the game freezes and my raspberry pi basically just stops. It freezes when "building terrain" It won't process any mouse input. Have I done something wrong like wrong gpu memory or bad setting in minecraft? I was really excited when the game launched after working on it for hours, but I have to say I am disappointed in the results. If anyone knows what might be going on please help.
rpiMike
Tue Oct 16, 2018 10:05 am
Which Pi are you using? Did you get glxgears running at close to 60fps? Don't run any other applications when trying to run Minecraft.
Please don't forget this is a £30 educational single board computer - its a miracle it works at all!
Rasilon
Tue Oct 16, 2018 8:29 pm
They want $35 can for this? I wanted to set one up as an experimental server to show my friends how the pi can handle it, but I cannot justify the cost.
PS: excellent tutorial though. Thank you for your work.
d_a_v_e
Wed Oct 17, 2018 11:59 pm
rpiMike wrote: Which Pi are you using? Did you get glxgears running at close to 60fps? Don't run any other applications when trying to run Minecraft.
Im using the rpi 3 b+
glxgears works fine at 60 fps. I restarted the installation process at the beginning and went through more carefully. I got the game to launch and load a level! I was getting very respectable fps but as soon as I broke a block the game crashed.... frustrated but mildly amused at the same time.
So I tried closing all background apps and had just minecraft running. It works! 30-40 fps average with peaks in 50 fps. Thank you for the guide. I dont know why it crashed before. Probably ran out of RAM space and just freaked out.
Anyone else that cares: Can confirm that Minecraft runs on the pi 3 b+ using this guide. 1.12.1 version is the only one I tested so I cant speak for other versions.
kirshman
Thu Oct 18, 2018 2:20 am
I've been trying to get this going, and today, seemingly everything installed and went as it should, but when I try and run the game this is what follows. Can anyone help me with what to do next?
100 793 100 619 100 174 1707 479 --:--:-- --:--:-- --:--:-- 1709
todays access token = 182e9fcfe1424fd9a72b4bdc046b8842
100 67 100 59 100 8 228 30 --:--:-- --:--:-- --:--:-- 228
MINECRAFT_UUID=d78d6c1a9f10480eb41ff3a517a9da70
[21:14:01] [main/INFO]: Loading tweak class name optifine.OptiFineTweaker
[21:14:01] [main/ERROR]: Unable to launch
java.lang.ClassNotFoundException: optifine.OptiFineTweaker
at java.net.URLClassLoader.findClass(URLClassLoader.java:381) ~[?:1.8.0_65]
at java.lang.ClassLoader.loadClass(ClassLoader.java:424) ~[?:1.8.0_65]
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331) ~[?:1.8.0_65]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:1.8.0_65]
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:106) ~[launchwrapper-1.12.jar:?]
at java.lang.Class.forName0(Native Method) ~[?:1.8.0_65]
at java.lang.Class.forName(Class.java:348) ~[?:1.8.0_65]
at net.minecraft.launchwrapper.Launch.launch(Launch.java:98) [launchwrapper-1.12.jar:?]
at net.minecraft.launchwrapper.Launch.main(Launch.java:28) [launchwrapper-1.12.jar:?]
d_a_v_e
Thu Oct 18, 2018 4:48 am
Any number of things could have gone wrong during the installation. The error log says something like java could not find the Optifine class to execute OptifineTweaker, so that leads me to believe that maybe something went wrong with the optiFine installation. What version of Optifine did you download? Did you run ./runOptifine1_12_1.sh in the terminal? You must launch the game with that script.
JamesPi123
Sat Oct 20, 2018 5:51 am
@rpiMike yes i did
HawaiianPi
Sat Oct 20, 2018 10:46 am
I've been running a SpigotMC Minecraft Java Edition 1.12.2 SMP server on a Pi3B for almost a year now. It works well for a small group of players (most I've had online at once is 4 on my Creeper Pie server). SpigotMC is much faster than the Mojang supplied server, so it's worth the extra time and effort to build.
Considering the low heat, noise and power consumption, I think $35 (+PSU and uSD card) is a steal.
On the other hand, I don't actually play Minecraft on a Pi. While it is impressive that people have gotten it to work, the short render distance and other graphical reductions needed are too much of a compromise for me. So I play on my laptop and connect to my Creeper Pi3 server.
DarkPlatinum
Contact: YouTube
Sat Oct 20, 2018 7:43 pm
I played minecraft on a pi for a few months, after the server I played reset due to "fake" backups, I quit as it was a waste of time and not the most enjoyable experience. Grinders drop to 1-12 fps which is basically unplayable. Minecraft on a pi is definitely not going to win you any duels either ;)
Adithya
Tue Oct 23, 2018 9:36 pm
can someone help me i get this error opening minecraft
[17:26:25 ERROR]: java.io.IOException: Stream closed
[17:26:25 INFO]: Game ended with no troubles detected (exit code 0)
[17:26:25 INFO]: Deleting /home/pi/.minecraft/versions/1.2.1/1.2.1-natives-1109435718657
djchewmacca
Fri Oct 26, 2018 6:31 pm
Any news on an update so that 1.13.2 will work on the Pi 3?
rpiMike
Sat Oct 27, 2018 3:16 pm
Not until someone gets lwjgl3 working on the Pi
https://github.com/LWJGL/lwjgl3/issues/206
rpiMike
Sun Oct 28, 2018 8:48 am
[deleted] wrote:
Sun Oct 28, 2018 3:57 am
HELP somehow one of the things I sudo app geted made my speakers go weird how do I delete :( :shock:
Any reason you can't re-flash your sd card with Raspbian?
[deleted]
Mon Oct 29, 2018 12:27 am
help when I try and run optifine ist says
pi@raspberrypi:~ $ cd ~/Downloads && java -jar OptiFine_1.12.1_HD_U_C5.jar
Error: Unable to access jarfile OptiFine_1.12.1_HD_U_C5.jar
pi@raspberrypi:~/Downloads $
what now? I ran it with launcher open.
[also the speakers were fixed]
[deleted]
Mon Oct 29, 2018 12:57 am
fixed other things
now when I try and download says Minecraft version 1.12.1 not found you need to start the version 1.12.1 manually once
rpiMike
Mon Oct 29, 2018 7:03 am
Did you do step 7 running the Minecraft launcher?
In step 7 did you also specify release 1.12.1? - If your using a newer Minecraft.jar click 'edit profile' and select use release - 'release 1.12.1', then 'save profile'
Click Play to install game
Return to “Gaming”
