SrIzan10
Re: How to setup Minecraft 1.12.2 on Pi3 or Pi4
Mon Jul 20, 2020 1:12 pm
Hi!
I have a problem connecting to servers such as play.skycade.net and mc.hypixel.net. It says:
Internal exception: java.lang.NullPointerException
Thank You!
rpiMike
Mon Jul 20, 2020 1:44 pm
Alexander Enderman wrote:
Mon Jul 20, 2020 1:00 am
I have run Minecraft 1.12.2 on 1 gb pi 4. minecraft ran about 20 minutes before crashing
Did you have anything else running at the same time? Any error message?
rpiMike
Hi!
Thank You!
Are you using your own valid Minecraft account?
SrIzan10
Mon Jul 20, 2020 2:35 pm
Hi!
Thank You!
Yes, but I don't purchased Minecraft, it can be that?
rpiMike
Mon Jul 20, 2020 2:37 pm
Hi!
Thank You!
How have you got a valid account if you didn’t purchase it?
SrIzan10
Mon Jul 20, 2020 2:39 pm
I don't renember, it was about 2 years when i created it
rpiMike
Mon Jul 20, 2020 2:48 pm
See if you can login at https://www.minecraft.net/
SrIzan10
Mon Jul 20, 2020 2:51 pm
Yes, I can
SrIzan10
Mon Jul 20, 2020 2:56 pm
I am using a RPi 3b+, by the way
rpiMike
Mon Jul 20, 2020 3:19 pm
Double check your account details in the run script. Otherwise I don’t know.
SrIzan10
Tue Jul 21, 2020 1:02 pm
Hi!
Can I install mods in the game? Where is the folder .minecraft?
Thank you!
SrIzan10
Please help me.
Fri Aug 21, 2020 9:00 pm
I have a problem pls help.
In servers Minecraft crashes a lot.
Making PvP, in lobbies...
I reinstalled it, nothing. Put all optimized, nothing.
I am using a 3b+ with 111mb of GPU.
pigong
Sun Aug 23, 2020 11:15 pm
Thanks a lot for this! It seems to have worked flawlessly for me, RPI4 4Gig, latest Buster... I should add you made two boys of 6 and 7, who missed the mobs in the educational Minecraft Pi, terribly excited! ;-)
Btw, I added a file called minecraftjavaed.desktop in ~/.local/share/applications with this content:
[Desktop Entry]
Type=Application
Name=Minecraft Java Ed
GenericName=Vanilla Minecraft 12.2 Java Edition
Exec=/home/pi/Minecraft/runMC1_12_2_OptifineF4.sh
Icon=/usr/share/pixmaps/minecraft-pi.png
Terminal=false
Categories=Game;ActionGame;AdventureGame;RolePlaying;
NoDisplay=false
StartupNotify=true
It brings up a menu entry in the "Games" category. Clicking it tries your patience a bit (no feedback first), but after a while "Mojang" comes up, and after another while MC's start menu! Have fun, and if somebody knows how to enhance this launcher, let me know here. Thanks!
MilkyMilkyMIlky
Wed Aug 26, 2020 3:28 pm
PLEASE HELP! When I type the last command, minecraft does not start at all though i still get this:
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 703 100 539 100 164 1911 581 --:--:-- --:--:-- --:--:-- 2492
todays access token = eyJhbGciOiJIUzI1NiJ9.eyJzdWIiOiJjODdiYjViYmMwODA2MmJhMDcyMTNmNTM5ZTFkZTYyMCIsInlnZ3QiOiJmMzI0ODAyMmU4MTM0ZDdlYTU4MDRmNTA3Mzg3YjU0MiIsInNwciI6IjgwNmQ1ZTU2YmM1YTRlMmNiMjFhN2NiZTUxMTc5NjkyIiwiaXNzIjoiWWdnZHJhc2lsLUF1dGgiLCJleHAiOjE1OTg2MjgxODUsImlhdCI6MTU5ODQ1NTM4NX0.78qdrWgj71_BOAiU-3sUtwEfeY_WSibJHDiStJpTQq8
100 71 100 61 100 10 324 53 --:--:-- --:--:-- --:--:-- 377
MINECRAFT_UUID=806d5e56bc5a4e2cb21a7cbe51179692
Java HotSpot(TM) Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
[16:23:08] [main/INFO]: Loading tweak class name optifine.OptiFineTweaker
[16:23:09] [main/INFO]: Using primary tweak class name optifine.OptiFineTweaker
[16:23:09] [main/INFO]: Calling tweak class optifine.OptiFineTweaker
OptiFineTweaker: acceptOptions
OptiFineTweaker: injectIntoClassLoader
OptiFine ClassTransformer
OptiFine ZIP file: /home/pi/.minecraft/libraries/optifine/OptiFine/1.12.2_HD_U_F4/OptiFine-1.12.2_HD_U_F4.jar
OptiFineTweaker: getLaunchArguments
OptiFineTweaker: getLaunchTarget
[16:23:09] [main/INFO]: Launching wrapped minecraft {net.minecraft.client.main.Main}
[16:23:10] [main/ERROR]: Unable to launch
java.lang.reflect.InvocationTargetException: null
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_211]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_211]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_211]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_211]
at net.minecraft.launchwrapper.Launch.launch(Launch.java:159) [launchwrapper-of-2.1.jar:2.1]
at net.minecraft.launchwrapper.Launch.main(Launch.java:30) [launchwrapper-of-2.1.jar:2.1]
Caused by: java.lang.UnsatisfiedLinkError: no lwjgl in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867) ~[?:1.8.0_211]
at java.lang.Runtime.loadLibrary0(Runtime.java:870) ~[?:1.8.0_211]
at java.lang.System.loadLibrary(System.java:1122) ~[?:1.8.0_211]
at org.lwjgl.Sys$1.run(Sys.java:72) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_211]
at org.lwjgl.Sys.doLoadLibrary(Sys.java:66) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.loadLibrary(Sys.java:96) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.<clinit>(Sys.java:117) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at bib.I(SourceFile:2825) ~[bib.class:?]
at net.minecraft.client.main.Main.main(SourceFile:38) ~[Main.class:?]
... 6 more
I NEED HELP PLEEEEEEEEEAAAAAAAAAAASE
double_nathan7
Sat Aug 29, 2020 11:35 am
... 6 more
You might not have enabled GLDriver I got that problem and I just reinstalled and found my GLDriver wasnt on.
Yicarus7252
Thu Oct 08, 2020 12:38 pm
Thank you from 2020 rpmike! this has turned to be very useful on my raspberry pi model 3 b. Others did not work, but this certainly did!!! :D :D :D
Yicarus7252
Wed Nov 18, 2020 4:31 pm
rpiMike wrote:
Fri Jun 28, 2019 12:47 pm
How to setup Full Minecraft 1.12.2 (with Optifine) on Raspberry Pi3 or Pi4 (using Buster)
Edit: 10/11/2019 Updated to Optifine HD U F4, added video tutorial.
Please note :
Do this at your own risk.
If you have any doubts use a spare SD card.
Pi3: The OpenGL drivers may not work with all screens. If unsure make sure you can ssh onto the Pi from another machine to turn back off.
Pi3: Most likely to have success with OpenGL drivers if using Raspberry Pi 3 with heatsink, genuine 5.1 volt 2.5 amp power supply with heavy duty 2 core power cable, 1080p screen.
Pi4: I'm using the official 5.1V 3.0A power supply, with the Pi4 in an open sided case with small fan.
This tutorial was tested using Raspbian Buster with Desktop - release date 2019-09-26
Video tutorial: https://www.youtube.com/watch?v=huFGL_9adaQ
1 If you need to update an existing version use
sudo apt-get update && sudo apt-get -y upgrade
If you get any questions or prompts during raspbian update press ‘q’ ‘enter’
2 Pi3: In Menu\Preferences\Raspberry Pi Configuration :
Performance Tab - set GPU Memory to 64Mb
Reboot if necessary
3 Pi3: Enable ‘GL Driver’ from a terminal window
sudo raspi-config
This will start the config utility. Select 'Advanced Options', then select 'GL Driver', then select 'GL (Fake KMS)', then select 'Yes' to reboot and enable the driver.
4 Download and run setupMC1 script
This will take a few minutes, including installing Oracle java 8.
mkdir ~/Minecraft && cd ~/Minecraft && wget https://www.dropbox.com/s/4irv50ow07yxn65/setupMC1.sh && chmod +x setupMC1.sh && ./setupMC1.sh
5 Run Minecraft launcher :
cd ~/Minecraft && /opt/jdk/jdk1.8.0_211/bin/java -jar Minecraft.jar
Login with Minecraft email and password
Click 'edit profile' and select use release - 'release 1.12.2', then 'save profile'
Click Play to install game
You will then receive an error
Close launcher
6 Install Optifine
cd ~/Minecraft && /opt/jdk/jdk1.8.0_211/bin/java -jar OptiFine_1.12.2_HD_U_F4.jar
Click install.
7 Run Minecraft launcher
Select the OptiFine profile and click play. The launcher will crash.
8 Run setupMC2 script
cd ~/Minecraft && ./setupMC2.sh
9 Edit runMC1_12_2_OptifineE3.sh
leafpad runMC1_12_2_OptifineF4.sh
or
mousepad runMC1_12_2_OptifineF4.sh
Update MINECRAFT_LOGIN, MINECRAFT_USERNAME and MINECRAFT_PASSWORD to your own (may need "" for special characters)
10 Start Minecraft from terminal window
cd ~/Minecraft
./runMC1_12_2_OptifineF4.sh
Change options in Minecraft to reduce render chunks to 2, this should avoid running out of memory.
Turn everything down to low in the video settings (and turn on things like fast math)
Suggest running in the default sized window for best performance.
Hopefully Minecraft should run :P
https://www.youtube.com/watch?v=2PeYIZ1-zH4
Could this be updated fo the latest version of minecraft for the pi 3?
Im Hoping it could. :D
rpiMike
Wed Nov 18, 2020 5:05 pm
I don't think the Pi3 with only 1GB would cope, Pi4 2GB minimum required.
ardera
Sat Nov 21, 2020 7:08 pm
If anyone else has a problem when running with the DSI display, here's how I fixed it:
  1. create and open in your favorite text editor:
    ~/Minecraft/xrandr
  2. paste the following text and save:
    #!/bin/bash
    echo "Screen 0: minimum 320 x 200, current 800 x 480, maximum 7680 x 7680"
    echo "DSI-1 connected primary 800x480+0+0 (normal left inverted right x axis y axis) 0mm x 0mm"
    echo "    800x480    60.05*+"
  3. execute in a terminal:
    chmod +x ~/Minecraft/xrandr
  4. open in your favorite text editor
    ~/Minecraft/runMC1_12_2_OptifineF4.sh
  5. go to the line where it says
    /opt/jdk/jdk1.8.0_211/bin/java \
  6. modify the line so it looks like this and save:
    PATH=./:$PATH /opt/jdk/jdk1.8.0_211/bin/java
LWJGL's xrandr support is absolutely nuts. They just parse the output of `xrandr -q` like a mad man, and they don't even support all the possible outputs. In particular, xrandr outputs "FIXED_MODE 60.05*+" as the modeline for the DSI display, but LWJGL expects modelines to look something like "123x456 78.9*+". When it finds the "FIXED_MODE", it doesn't recognize that as a mode and thus it outputs "No modes available". So we just build our own xrandr script which just outputs a static text, but with "800x480" instead of "FIXED_MODE". Then, to get Minecraft to run our own xrandr instead of the system default, we overwrite the PATH variable given to Minecraft so ~/Minecraft/xrandr is preferred.
mrausch2404
Sun Jan 17, 2021 8:22 am
Hi there,
i have an RP4b 8GB.
Steps 1-5 work very well.
Many Thanks.
Unfortunately, I cannot log into the launcher with a Microsoft account.
What can that be?
Hallo,
ich habe einen RP4b 8GB.
Die Schritte 1-5 funktionieren sehr gut.
Vielen Dank.
Leider kann ich mich mit Microsoft Account nicht über den Launcher anmelden.
Woran kann das liegen?
Danke.
rpiMike
Sun Jan 17, 2021 1:53 pm
Sorry, only works with Mojang accounts, blame Microsoft.
Please vote for a Pi port of the latest Minecraft Java launcher:
https://feedback.minecraft.net/hc/en-us ... spberry-Pi
digitalcoins
Mon Jan 18, 2021 11:11 am
Hello! I am sorry, if this section is not appropriate for me question (I just don't know where to post it). I am new to Python and Raspberry PI also. I am trying now to import scripts from Minecraft education and start them with Raspberry PI. Is that possible? For example there are such libraries like mc and world and I have issues with them. Here is the error: "Traceback (most recent call last):
File "blocks.py", line 1, in <module>
from mc import world, blocks, player
ImportError: cannot import name 'world' from 'mc' (/usr/local/lib/python3.8/dist-packages/mc/__init__.py)". What is the best place to find answer for this question and how to resolve this issue?
Unounited
Mon Jan 18, 2021 6:35 pm
Nice tutorial on how to install minecraft java, it runs really well on my pi4. I have downloaded 1 map called the toy story 2 adventure map for my minecraft java and I really enjoyed it. Here's the map: www.mediafire.com/file/3q2wrgny65wad7s/ ... 1.zip/file.
First create a new world and then go here for a tutorial on how to put the map on minecraft java: https://minecraft.gamepedia.com/Tutorials/Map_downloads.
If you can't find the .minecraft folder, click VIEW, and SHOW HIDDEN, or hit CTRL-H.
Hope you enjoy the map, Thanks!
dudethis
Thu Mar 04, 2021 5:32 pm
hey if you want to squeeze every fps possible try this:
do: sudo nano /boot/config.txt and write at the bottom:
gpu_mem=516
over_voltage_sdram_c=3
over_voltage_sdram_i=3
over_voltage_sdram_p=4
sdram_schmoo=0x02000020
sdram_freq=3200
kernel=zImage
core_freq=525
arm_freq=2000
gpu_freq=650
over_voltage=6
:D hope this helps
I get 60 fps on hypixel with 6 chunks and optifine on my rpi4 8gb ram
I love that smell of hot metal after overclocking too much :twisted:
Return to “Gaming”
