rpiMike
Re: How to setup Minecraft 1.12.2 on Pi3 or Pi4
Wed Jul 03, 2019 9:41 pm
R3lay wrote:
Wed Jul 03, 2019 8:45 pm
Is this impossible on the Pi2 or just not tested?
I did originally get Minecraft 1.8.9 running on a Pi2 - haven't tried this version but it might work.
GeeCeeGee
Fri Jul 05, 2019 4:44 pm
Hiya,
Was this problem resolved? I'm getting the same problem - fresh install on a 2Gb Pi4.
when I type java -version, I get;
java -version
openjdk version "11.0.3" 2019-04-16
OpenJDK Runtime Environment (build 11.0.3+7-post-Raspbian-5)
OpenJDK Server VM (build 11.0.3+7-post-Raspbian-5, mixed mode)
Any ideas? Any help appreciated!
cheers
Graeme
Quote
Mon Jul 01, 2019 7:57 pm
hiya, I followed the guide on pi 4. and I get this error?
MINECRAFT_UUID=4194a18fcb284c2d9913741de45b2ac2
OpenJDK Server VM warning: Option UseConcMarkSweepGC was deprecated in version 9.0 and will likely be removed in a future release.
Unrecognized VM option 'CMSIncrementalMode'
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
lambdapi101
Fri Jul 05, 2019 7:15 pm
Buster is similar to Stretch. They said it
galicin
Sat Jul 06, 2019 4:57 am
I use Pi4/4GB and due to the same error get rid of CMSIncrementalMode option, but now I have this error:
Exception in thread "main" java.lang.ClassCastException: class jdk.internal.loader.ClassLoaders$AppClassLoader cannot be cast to class java.net.URLClassLoader (jdk.internal.loader.ClassLoaders$AppClassLoader and java.net.URLClassLoader are in module java.base of loader 'bootstrap')
at net.minecraft.launchwrapper.Launch.<init>(Launch.java:34)
at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
rpiMike
Sat Jul 06, 2019 6:25 am
I’ll try a fresh install later today.
Zewyn
Sat Jul 06, 2019 3:41 pm
Have any of you tried custom launchers that have modpacks f.e Tlauncher with Sevtech Ages?
I'm wondering if that would even start up on a RPi4 and if it does what would the avg fps figure look like?
Most modpacks that officially say they require more than 4GBs of ram run just fine on 3-4 if allocated on a proper pc that has 8 or more cores.
rpiMike
Sun Jul 07, 2019 7:53 am
I've just done a a fresh install on my Pi4 with Buster (fully updated) and all worked fine.
If you are having issues I need more info.
leafs444
Sun Jul 07, 2019 10:32 pm
Ima make a full GUI installer using Whiptail because I'm bored and that's what I do for fun.
First I'll make a script to just fully install (like I did with the other thread) without using the UIs (unless you count read as a UI). I basically just read through the entire raspi-config shell script trying to figure out how to enable fake KMS gl drivers.
GeeCeeGee
Tue Jul 09, 2019 9:51 pm
Tried another fresh install on my Pi4, but still getting the same error.
Followed instructions 1,4 and 5. When I run Minecraft launcher and login I get the attached screen dump.
If Java is loaded ok, should I see 'Javascript required'?
I've also attached the output from running the downloads at stage 4. (attached zip file)
I then follow steps 6,7,8,9,10 and get the error message;
pi@raspberrypi:~/Minecraft $ ./runMC1_12_2_OptifineE3.sh
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 795 100 631 100 164 1959 509 --:--:-- --:--:-- --:--:-- 2461
todays access token = 2942681281104ba49f12d836a69c650c
100 79 100 65 100 14 177 38 --:--:-- --:--:-- --:--:-- 215
MINECRAFT_UUID=4cbdd36164b74b56a4716ccb40592170
Any clues in the info above? I'm sure I must be doing something wrong but can't see what it is!
Thanks again for any help!
installation stage4.zip
text file of output during installation - stage 4
(32.3 KiB) Downloaded 144 times
screen dump from stage 5
Maggi9295
Wed Jul 10, 2019 12:47 pm
Hello everyone,
I freshly installed the newest Raspbian Buster on a RPi4 4GB and followed this tutorial point after point. everything worked without a error during th installation, but when i typed "./runMC1_12_2_OptifineE3.sh" to start Minecraft, I also get a error and minecraft wont start, exactly like GeeCeeGee posted.
It would be awesome if you could make a installer with a GUI, maybe that would fix the Eroor. :D
Best Regards,
Maggi
rpiMike
Wed Jul 10, 2019 1:00 pm
Hello everyone,
Best Regards,
Maggi
Did you install a Raspbian Buster image or from Noobs?
What output do you get if you run the following commands?
java -version
sudo update-alternatives --install /usr/bin/java java /opt/jdk/jdk1.8.0_211/bin/java 100
sudo update-alternatives --install /usr/bin/javac javac /opt/jdk/jdk1.8.0_211/bin/javac 100
java -version
rpiMike
Wed Jul 10, 2019 1:04 pm
Don't worry about the javascript error. When installing Minecraft did you 'Edit Profile' and select 'Release 1.12.2' and save?
java -version
java -version
GeeCeeGee
Wed Jul 10, 2019 4:46 pm
Did you install a Raspbian Buster image or from Noobs? I've tried both - also Buster with recommended software and without - and also a couple of different SD cards
Don't worry about the javascript error. When installing Minecraft did you 'Edit Profile' and select 'Release 1.12.2' and save? Yes did that. The screenshot was taken just before I did this.
java -version
java -version
I get the following;
pi@raspberrypi:~ $ java -version
OpenJDK Runtime Environment (build 11.0.3+1-Raspbian-1)
OpenJDK Server VM (build 11.0.3+1-Raspbian-1, mixed mode)
pi@raspberrypi:~ $ sudo update-alternatives --install /usr/bin/java java /opt/jdk/jdk1.8.0_211/bin/java 100
pi@raspberrypi:~ $ sudo update-alternatives --install /usr/bin/javac javac /opt/jdk/jdk1.8.0_211/bin/javac 100
pi@raspberrypi:~ $
I'm creating my SD image on a Mac, could this be an issue?
cheers
Graeme
Maggi9295
Wed Jul 10, 2019 4:58 pm
Thanks a lot for your fast reply!
I used the normal "Raspbian Buster with desktop and recommended software"(Release date:2019-06-20), NOT noobs.
Here is what i got:
(Note: there was no output from the second and third command)
rpiMike
Wed Jul 10, 2019 5:09 pm
I don't understand why the default java version is not changing.
What happens if you both edit the run script and add the full path to Oracle java:
cd ~/Minecraft
leafpad runMC1_12_2_OptifineE3.sh
Approx line 54 (Options,Line Numbers) change
java \
to
/opt/jdk/jdk1.8.0_211/bin/java \
Maggi9295
Wed Jul 10, 2019 5:38 pm
Thanks a lot! It works flawlssly!
even in maximised windowed mode it runs at a average of 20 fps, very playable. I also tested multiplayer, no problm, i was able to connect to my server.
Great work! :D
GeeCeeGee
Wed Jul 10, 2019 9:52 pm
Fantastic! That's fixed it for me too.
Thanks for your help! :D :D :D :D
jdonald
Sun Jul 21, 2019 5:07 pm
Because you have these lines commented out in setupMC1.sh :
#sudo update-alternatives --install /usr/bin/java java /opt/jdk/jdk1.8.0_211/bin/java 100
#sudo update-alternatives --install /usr/bin/javac javac /opt/jdk/jdk1.8.0_211/bin/javac 100
Also I think you need to call update-alternatives with --config after --install, especially if someone already has JDK11 installed.
Thanks for providing this example though. I had been wondering how to install JDK8 after Oracle broke things with the new terms.
By the way, the longer your scripts get the more I'd recommend putting:
#!/bin/sh -e
at the top to make it stop on errors. When troubleshooting obscure issues on others' systems you get more useful info when focusing on the first error encountered rather than all the noise if everything else runs through with limited success.
rpiMike
Sun Jul 21, 2019 5:42 pm
I commented out those 'update-alternatives' lines because they seemed to work for me - but no one else. So added the full path to java in the run script.
Nice tip about stopping on errors, I will do that.
jdonald
Sun Jul 21, 2019 9:52 pm
Oh I get it now. You commented out those lines because they weren't working, and not: they weren't working because you commented them out.
Most likely it wasn't successfully configuring java initially because you were missing the update-alternatives --config step, but what you have now is cleaner anyhow. Certainly preferred to avoid messing with anyone's existing JDK (~11) installation.
leafs444
Mon Jul 22, 2019 2:47 pm
Hey @rpiMike,
I was wondering if you’d be OK with me posting my shell script that uses parts of your shell script on here.
Thanks in advance,
leafs444
rpiMike
Mon Jul 22, 2019 2:51 pm
Hey @rpiMike,
Thanks in advance,
leafs444
Yes, that’s ok
COMMANDERY11
Tue Jul 23, 2019 9:01 pm
This tutorial did work however it takes a very long time to get into worlds even crashing! I am running this on a pi3 which explains the crashing since the pi 4 has much more ram then the 3. Is there any way I can maybe play an older minecraft version like 1.8.9? It would probably run a lot faster since there is less things to load. With all that stuff they are adding to minecraft the pi3 just is not capable of running a newer version of minecraft at a playable speed. Any help is greatly appreciated!
Tomdizzy
Tue Jul 23, 2019 11:30 pm
Hello, i'm on a pi4 4gb with the official dsi display and i'm getting this error
Description: Initializing game
java.lang.ExceptionInInitializerError
	at Config.getDisplayModes(Config.java:1854)
	at bid$a.<clinit>(GameSettings.java:3569)
	at bid.<init>(GameSettings.java:331)
	at bib.aq(SourceFile:443)
	at bib.a(SourceFile:404)
	at net.minecraft.client.main.Main.main(SourceFile:123)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at net.minecraft.launchwrapper.Launch.launch(Launch.java:135)
Caused by: java.lang.RuntimeException: org.lwjgl.LWJGLException: No modes available
	at org.lwjgl.opengl.Display.<clinit>(Display.java:141)
	... 12 more
Caused by: org.lwjgl.LWJGLException: No modes available
	at org.lwjgl.opengl.LinuxDisplay.init(LinuxDisplay.java:740)
	at org.lwjgl.opengl.Display.<clinit>(Display.java:138)
	... 12 more
jdonald
Wed Jul 24, 2019 1:33 am
Another user recently got the same error with Forge: https://raspberrypi.stackexchange.com/q ... 12-2-issue
Though their use-case is different (1024x768 HDMI television) the troubleshooting steps may be similar, i.e. I recommend providing the output of xrandr -v and xrandr -q.
And did you get this with Forge installed, or Minecraft alone?
Return to “Gaming”
