offgridone
Re: STICKY: rpix86 (Raspberry Pi x86 emulator) ver 0.19 released!
Thu Oct 10, 2019 4:27 pm
For my previous post, I forgot to mention that this is on a Rpi3, in case that makes a difference.
jontylovell
Mon Apr 13, 2020 9:41 am
I love rpix86, but I have been trying without success, to get it to run on Raspbian Buster on a Raspberry Pi 4. It seems to run, but just hangs. Has anyone been able to get this working?
flaviov
Mon Jun 22, 2020 7:13 pm
I have not tried rpix86 on Raspberry Pi 4, but if you want to run userspace x86 32 bits Linux programs on Raspberry Pi 4, box86 may be a better option (https://github.com/ptitSeb/box86). And if you want to give it a try without bothering to install/compile it, you can try Twister OS (https://raspbian-x.com/).
I hope this helps.
guidol
Wed Dec 09, 2020 4:04 pm
I did try to run rpix86 under Raspberry Pi OS 12/2020 buster, after linking the librarys
ln -s /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2 /usr/lib/arm-linux-gnueabihf/libGLESv2.so
ln -s /usr/lib/arm-linux-gnueabihf/libEGL.so.1.1.0 /usr/lib/arm-linux-gnueabihf/libEGL.so
ln -s /usr/lib/arm-linux-gnueabihf/libncurses.so.6.1 /usr/lib/arm-linux-gnueabihf/libncurses.so.5
rpix86 did ask about downloading 4DOS.COM.
But after the download of 4DOS.COM I do get an segmentation fault:
/home/fbterm/rpix86# ./rpix86
./rpix86 -a2 -d/home/fbterm/rpix86 -f1 -w1280 -h1024
Unable to find 4DOS.COM command interpreter (shell) from /home/fbterm/rpix86!
Do you wish to let rpix86 attempt to download it for you?
If you prefer to download it yourself, enter n for No (y/n)? y
--2020-12-09 18:53:52--  http://rpix86.patrickaalto.com/4DOS.COM
Auflösen des Hostnamens rpix86.patrickaalto.com (rpix86.patrickaalto.com)… 198.136.61.225
Verbindungsaufbau zu rpix86.patrickaalto.com (rpix86.patrickaalto.com)|198.136.61.225|:80 … verbunden.
HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
Länge: 257520 (251K) [application/x-msdownload]
Wird in »/home/fbterm/rpix86/4DOS.COM« gespeichert.
/home/fbterm/rpix86/4DOS.COM 100%[============================================>] 251,48K   362KB/s    in 0,7s
2020-12-09 18:53:53 (362 KB/s) - »/home/fbterm/rpix86/4DOS.COM« gespeichert [257520/257520]
Speicherzugriffsfehler (segmentation fault)
Return to “Gaming”
