Knappster
SDLQuake Segfault??
Fri Feb 15, 2013 7:29 pm
As a little project I'm trying to get SDLQuake to run on my Raspberry Pi.
I've grabbed the code from here: http://www.libsdl.org/projects/quake/
So far I've got the thing to compile but when trying to start a new game from the in game menu I get a segmentation fault. I'm not a wizz at this but using gdb I've got the following info:
Program received signal SIGSEGV, Segmentation fault.
0xb6def284 in fread () from /lib/arm-linux-gnueabihf/libc.so.6
Is it simply the case that I'm linking to the wrong libs or something stranger?
Here's the Makefile I've hacked up to get it to compile: http://pastebin.com/LWQDLyms
Mechduino
Re: SDLQuake Segfault??
Sat Feb 16, 2013 4:14 am
I believe segmentation faults are usually issues with a lack of ram.
Bluebian, the better Raspbian, okay maybe worse, well...definitely worse.
Knappster
Sat Feb 16, 2013 1:08 pm
Well googling this thing to death still hasn't got me anywhere. Obviously it's an issue reading a file of some kind. I've checked that the pak files are ok, it's either a problem in the code itself or /lib/arm-linux-gnueabihf/ is the wrong lib to be using on the RPi. I don't think it is.
Anyone know of a way of finding where in the code this error might be occuring?
It certainly doesn't seem to be lack of ram.
Knappster
Sat Feb 16, 2013 1:57 pm
OK I've learned a bit more about using gdb and have the traced whereabouts the error is.
This is part of the trace from gdb:
#0 0xb6def284 in fread () from /lib/arm-linux-gnueabihf/libc.so.6
#1 0x000475e0 in Sys_FileRead (handle=115, dst=<optimized out>, count=413116) at sys_sdl.c:218
#2 0x00010f5c in COM_LoadFile (path=0x51c6c "progs.dat", usehunk=<optimized out>) at common.c:1583
#3 0x0002e004 in PR_LoadProgs () at pr_edict.c:995
PR_LoadProgs() calls COM_LoadHunkFile() like this:
progs = (dprograms_t *)COM_LoadHunkFile ("progs.dat");
This is the COM_LoadFile function:
cache_user_t *loadcache;
byte    *loadbuf;
int             loadsize;
byte *COM_LoadFile (char *path, int usehunk)
	int             h;
	byte    *buf;
	char    base[32];
	int             len;
	buf = NULL;     // quiet compiler warning
// look for it in the filesystem or pack files
	len = COM_OpenFile (path, &h);
	if (h == -1)
		return NULL;
// extract the filename base name for hunk tag
	COM_FileBase (path, base);
	if (usehunk == 1)
		buf = Hunk_AllocName (len+1, base);
	else if (usehunk == 2)
		buf = Hunk_TempAlloc (len+1);
	else if (usehunk == 0)
		buf = Z_Malloc (len+1);
	else if (usehunk == 3)
		buf = Cache_Alloc (loadcache, len+1, base);
	else if (usehunk == 4)
		if (len+1 > loadsize)
		else
			buf = loadbuf;
	else
		Sys_Error ("COM_LoadFile: bad usehunk");
	if (!buf)
		Sys_Error ("COM_LoadFile: not enough space for %s", path);
	((byte *)buf)[len] = 0;
	Draw_BeginDisc ();
	Sys_FileRead (h, buf, len);
	COM_CloseFile (h);
	Draw_EndDisc ();
	return buf;
And finally the Sys_FileRead function where the call to fread is:
int Sys_FileRead (int handle, void *dst, int count)
	char *data;
	int size, done;
	size = 0;
	if ( handle >= 0 ) {
		data = dst;
		while ( count > 0 ) {
			done = fread (data, 1, count, sys_handles[handle]);
			if ( done == 0 ) {
				break;
			data += done;
			count -= done;
			size += done;
	return size;
Hopefully this will help :P.
Knappster
Sun Feb 17, 2013 1:21 pm
I asked a few folks on a Quake forum about the issue. They suggested I tried to compile it with optimisation set to -O0 and it now works. Something goes horribly wrong when gcc tries to optimise it :/. They also suggested I try fteqw, which has a gles support, I'll let you know how it goes.
pjtpjt
Sun Mar 01, 2015 9:04 pm
I ran into this one myself when I turned optimization on. And it sure isn't gcc's fault. This is the caller code:
	if (!progs)
		Sys_Error ("PR_LoadProgs: couldn't load progs.dat");
And gcc says the first string constant "progs.dat" is practically the end of "PR_LoadProgs: couldn't load progs.dat", so we'll only use one, so the first string points into the longer one.
And COM_FileBase starts to search backwards from the dot "." to the beginning of the path (which is only "progs.dat") and since there's no '/' character in it it will search till the end of the longer string. And it's 33 characters, which will overwrite the the handle variable to 115 (lowercase 's').
void COM_FileBase (char *in, char *out)
	char *s, *s2;
	s = in + strlen(in) - 1;
	while (s != in && *s != '.')
		s--;
-->  for (s2 = s ; *s2 && *s2 != '/' ; s2--)
	if (s-s2 < 2)
		strcpy (out,"?model?");
	else
		s--;
		strncpy (out,s2+1, s-s2);
		out[s-s2] = 0;
The fix is, change
for (s2 = s ; *s2 && *s2 != '/' ; s2--)[
to
for (s2 = s ; s2 > in && *s2 != '/' ; s2--)
RPi B 256M, and RPi 2 B
Return to “Gaming”
