symbios25
Re: STICKY: GAMES LIST: Games That Work On The Pi
Sun Sep 03, 2017 7:27 pm
rpiMike wrote:
Sun Sep 03, 2017 5:10 pm
symbios25 wrote:
Sun Sep 03, 2017 9:05 am
Anyone knows how to compile/install assault cube on the raspberry it actually works with the opengl driver, but i cannot find instructions anywhere
This will get the code and build it - but I get an error : readdir_r is deprecated
# check additional libraries installed
sudo apt-get install libsdl1.2debian libsdl-image1.2 zlib1g libogg0 libvorbis0a libopenal1
# clone Assault Cube repository to a folder called AC
git clone https://github.com/assaultcube/AC.git
# change directory
cd AC/source/src
# build and install
make install
Thanks try this command before you build
sudo sed -i "s/clang++/g++/g" Makefile
i successfully build it but after i run it i see the main game logo and after the screen goes black any idea about that?
rpiMike
Sun Sep 03, 2017 10:00 pm
I got it working, I was missing some dev packages :
sudo apt-get install build-essential libsdl-image1.2-dev libopenal-dev libvorbis-dev
# change directory
cd AC/source/src
# build and install
make install
cd ~/AC
/home/pi/AC/bin_unix/native_client --home=/home/pi/.assaultcube/v1.2next --init -t
Note - the '-t' flag starts in window, full screen gave me a corrupt screen. I've got OpenGL Full enabled. Also game doesn't always start reliably.
Video : https://youtu.be/klbdoGGNTtk
symbios25
Mon Sep 04, 2017 7:12 am
# change directory
cd AC/source/src
# build and install
make install
cd ~/AC
Hello, do you use raspbian jessie or stretch?
rpiMike
Mon Sep 04, 2017 7:22 am
I'm using the latest Raspbian Stretch.
symbios25
Mon Sep 04, 2017 7:36 am
i will try it later and let you know on rasbian jessie for now,did you try another open-gl game?
rpiMike
Mon Sep 04, 2017 7:40 am
Yes, I regularly play Minecraft which uses OpenGL.
runboy93
Mon Sep 04, 2017 7:54 am
Can you show your glxinfo output?
symbios25
Mon Sep 04, 2017 7:57 am
Right now i cannot i`m on work
where can i see the glxinfo output?
Did you installed clang? and if yes what version?
And did you use the command sudo sed -i "s/clang++/g++/g" Makefile before you build?
rpiMike
Mon Sep 04, 2017 9:12 am
No, I didn't install clang (might already be installed?)
glxinfo :
pi@raspberrypi:~ $ glxinfo
name of display: :0.0
libGL error: MESA-LOADER: failed to retrieve device information
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_SGI_make_current_read, GLX_SGI_swap_control
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Broadcom (0x14e4)
Device: VC4 V3D 2.1 (0xffffffff)
Version: 13.0.6
Accelerated: yes
Video memory: 926MB
Unified memory: yes
Preferred profile: compat (0x2)
Max core profile version: 0.0
Max compat profile version: 2.1
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 2.0
OpenGL vendor string: Broadcom
OpenGL renderer string: Gallium 0.4 on VC4 V3D 2.1
OpenGL version string: 2.1 Mesa 13.0.6
OpenGL shading language version string: 1.20
OpenGL extensions:
GL_AMD_shader_trinary_minmax, GL_APPLE_packed_pixels,
GL_APPLE_vertex_array_object, GL_ARB_ES2_compatibility,
GL_ARB_buffer_storage, GL_ARB_clear_buffer_object,
GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_copy_buffer, GL_ARB_debug_output, GL_ARB_depth_texture,
GL_ARB_draw_buffers, GL_ARB_draw_elements_base_vertex,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
GL_ARB_robustness, GL_ARB_sampler_objects, GL_ARB_separate_shader_objects,
GL_ARB_shader_objects, GL_ARB_shading_language_100, GL_ARB_shadow,
GL_ARB_sync, GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_transpose_matrix, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos,
GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
GL_ATI_fragment_shader, GL_ATI_separate_stencil,
GL_ATI_texture_env_combine3, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_polygon_offset, GL_EXT_provoking_vertex, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shader_integer_mix, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side,
GL_EXT_stencil_wrap, GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_swizzle, GL_EXT_vertex_array, GL_IBM_multimode_draw_arrays,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_INGR_blend_func_separate, GL_KHR_context_flush_control, GL_KHR_debug,
GL_MESA_pack_invert, GL_MESA_window_pos, GL_NV_blend_square,
GL_NV_fog_distance, GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
GL_NV_texgen_reflection, GL_NV_texture_env_combine4,
GL_NV_texture_rectangle, GL_OES_EGL_image, GL_OES_read_format,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 2.0 Mesa 13.0.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 1.0.16
OpenGL ES profile extensions:
GL_APPLE_texture_max_level, GL_EXT_blend_minmax,
GL_EXT_discard_framebuffer, GL_EXT_draw_buffers,
GL_EXT_draw_elements_base_vertex, GL_EXT_map_buffer_range,
GL_EXT_multi_draw_arrays, GL_EXT_read_format_bgra,
GL_EXT_separate_shader_objects, GL_EXT_texture_border_clamp,
GL_EXT_texture_format_BGRA8888, GL_EXT_texture_type_2_10_10_10_REV,
GL_EXT_unpack_subimage, GL_KHR_context_flush_control, GL_KHR_debug,
GL_NV_draw_buffers, GL_NV_fbo_color_attachments, GL_NV_read_buffer,
GL_NV_read_depth, GL_NV_read_depth_stencil, GL_NV_read_stencil,
GL_OES_EGL_image, GL_OES_EGL_image_external, GL_OES_EGL_sync,
GL_OES_compressed_ETC1_RGB8_texture, GL_OES_depth24, GL_OES_depth_texture,
GL_OES_draw_elements_base_vertex, GL_OES_element_index_uint,
GL_OES_fbo_render_mipmap, GL_OES_get_program_binary, GL_OES_mapbuffer,
GL_OES_packed_depth_stencil, GL_OES_rgb8_rgba8, GL_OES_stencil8,
GL_OES_surfaceless_context, GL_OES_texture_3D,
GL_OES_texture_border_clamp, GL_OES_texture_npot,
GL_OES_vertex_array_object
symbios25
Mon Sep 04, 2017 12:43 pm
make install stops with an error did you put the "sudo sed -i "s/clang++/g++/g" Makefile" before or after?
finally after putting this and building finish i run it with the "/home/pi/AC/bin_unix/native_client --home=/home/pi/.assaultcube/v1.2next --init -t"
it goes in a window showing the assaultcube logo and after goes full screen and nothing all black in raspbian jessie
in raspbian stretch it shows the logo in a window and stucks not only the game the whole OS i have to remove the power adapter and put it back on
did you do anything else except the steps you write?
rpiMike
Mon Sep 04, 2017 3:12 pm
I didn't use the 'sudo sed ... ' command at all, just 'make install'
I did have the game lock up on me a few times and had to unplug the power. It seems to attempt to access stuff on the internet - and doesn't always work.
I didn't do anything other than my steps.
symbios25
Mon Sep 04, 2017 5:48 pm
hello, if you dont use this command the install stops with an error and the game is not working at all since is missing the executable i dont understand how it worked to you with the install crashed ,it worked now without internet but when i select the bot-deathmatch some levels it plays some other not crashing, too bad we cannot get this game from apt-get since like this is all problems
Battles4Seattle
Sun Sep 24, 2017 7:03 pm
This is an awesome list! Thank you!
Setting up my first RetroPie and tried to get three games. I used the apt-get for all three (SuperTux, Triplane, and Pingus). SuperTux showed up in the PORTS emulator but I can not find the other 2. I tried to reinstall them but it says Pingus and Triplane are installed.
What am I doing wrong?
Sincerely,
Noob
symbios25
Wed Sep 27, 2017 6:47 am
Hello, is it possible to put also a list in the main/first post the games that working/tested With The OpenGL Driver?
MSearles
Wed Sep 27, 2017 8:15 pm
Which Doom should I install on my RPi 3? I'm seeing tons of different ports of Doom. I've found Chocolate Doom, PrBoom, ZDoom, etc. I have no idea what's the differences between all of them and can't find any information pertaining to it. I just want to play classic Doom as close to the original game as can be.
symbios25
Fri Sep 29, 2017 9:31 am
chocolate doom is as close you can get all other are crap slow performance and bugs
Rooneyy259
Wed Jan 03, 2018 4:29 am
Thanks! I'll try not to!! I'm currently testing some stuff (RailWorld, OpenArena running through Quake3, ETC)
Actually I'm not testing. I'm just messing around having fun! I will play ELECTRIC MAN 2 (https://sites.google.com/site/funnyunbl ... -unblocked) for fun and keep thinking about: Games That Work On The Pi
COMMANDERY11
Wed Jan 03, 2018 4:40 pm
Do these games u mentioned what OS are they compatible with? Are they for Raspbian? Are some for specific OS? Whats the catch? :|
DeirdreTerry
Wed Feb 21, 2018 6:32 am
As far as gaming is concerned, Raspbian is capable of handling all sorts of retro games. Bringing to the console era, it can handle almost every game that can be played on Nintendo or Atari. And for a credit card sized motherboard this is just another medal of achievement. earthslab.com
- Deirdre Terry
tannenba
Mon Mar 26, 2018 4:03 am
Have the new Pi3 b+ and loaded the new stretch with pixel desktop. Only minecraft is included and none of the favorites are there. I especially enjoyed killing time with mahjongg and no versions are with pixel. :cry:
Joe
rpiMike
Mon Mar 26, 2018 9:39 am
From a terminal window enter:
sudo apt-get install gnome-mahjongg
Mahjongg should be installed and a menu option added under 'Games'.
tannenba
Mon Mar 26, 2018 2:05 pm
My sources .list must be wrong...apt-get can't find it:
deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspbian.org/raspbian/ stretch main contrib non-free rpi
This is the default sources.list that came with the latest Raspian stretch + Pixel for the Pi 3 B+
apt-get update goes to
Hit:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Joe
rpiMike
Mon Mar 26, 2018 8:48 pm
Thats the same as my sources.list file. I get the same apt-get update hits.
Did you type the application name correctly?
What does the following return?
sudo apt-cache search gnome-mahjongg
Mine returns:
gnome-mahjongg - classic Eastern tile game for GNOME
By the way 'Pixel' is now referred to as 'Raspbian Stretch with Desktop'.
tannenba
Mon Mar 26, 2018 8:51 pm
Doesn't find anything.
rpiMike
Mon Mar 26, 2018 9:24 pm
What happens if you use Menu -> Preferences -> Add / Remove Software and search for mahjongg?
Return to “Gaming”
