gyeben
Re: Mupen64Plus - N64 Emulator for the Pi
Sat Oct 05, 2013 10:56 am
welshy wrote:It should build without issues installing only SDL libraries (libsdl1.2-dev).
That's true.
I installed libsdl1.2-dev from a .deb package, and forgot to install the dependencies (which include libglu1-mesa-dev and libx11-dev, for example). D'oh! ;)
aguirrech
Sun Oct 06, 2013 9:34 am
Wich dependencies are necessary to compile? Can't get to compile after installling the SDL libraries.
welshy
Sun Oct 06, 2013 10:09 am
That's odd, I compiled with no problems using the latest Wheezy Image (2013-09-25), completing the 'Fix' (See Here - http://www.raspberrypi.org/phpBB3/viewt ... 78&t=57035), then the only dependency I installed was SDL (libsdl1.2-dev). Don't forget to apt-get update either so the SDL dependences download/install correctly.
marqs
Sun Oct 06, 2013 1:42 pm
I get this to compile and run (even with real N64 controller connected to GPIO), but unable get performance on the level mentioned in earlier posts. Mario64 startscreen results to around 30-40 VI/s, even though I have moderately high overclock (1GHz ARM, 400MHz GPU/core, 500MHz sdram) and disable sound+pads.
Lauszus
Sun Oct 06, 2013 2:35 pm
marqs wrote:I get this to compile and run (even with real N64 controller connected to GPIO), but unable get performance on the level mentioned in earlier posts. Mario64 startscreen results to around 30-40 VI/s, even though I have moderately high overclock (1GHz ARM, 400MHz GPU/core, 500MHz sdram) and disable sound+pads.
I also tried the code with medium overclock, but I also had problems with latency. Btw how did you disable the sound and pads?
@ric_rpi thanks for all your hard work!
ric_rpi
Sun Oct 06, 2013 3:51 pm
The speed is very dependant on window resolution and the timings mentioned earlier were when using 640x480 in cfg file. The sound plug-in reduces the fps by around 10. A capture from 'top' may allow us to diagnose the problem.
welshy
Mon Oct 07, 2013 1:30 pm
Lauszus
The easiest way is to just take the 'plugin-name' .so file from the Test folder, mupen will then just run without that plugin.
marqs
Mon Oct 07, 2013 4:16 pm
Lauszus wrote:Btw how did you disable the sound and pads?
I changed AudioPlugin and InputPlugin to "dummy" in ~/.config/mupen64plus/mupen64plus.cfg
Lauszus
Mon Oct 07, 2013 4:22 pm
Thanks to both of you. I didn't thought it would be that simple :)
ric_rpi
Mon Oct 07, 2013 8:11 pm
More updates, the screen is now scaled up to fit the tv. The resolution is set in the cfg file but would recommend keeping it low.
I have also been cutting my teeth on some assembler and managed to gain another 5 fps in the graphics plugin.
Lauszus
Mon Oct 07, 2013 8:47 pm
ric_rpi wrote:More updates, the screen is now scaled up to fit the tv. The resolution is set in the cfg file but would recommend keeping it low.
I just tried to build it, but I think you forgot to add rpiGLES.c and rpiGLES.h?
tinkernaut
Mon Oct 07, 2013 11:45 pm
Yep, I also seem to be missing the rpiGLES.h file.
ric_rpi
Tue Oct 08, 2013 7:12 am
Missing files should be in repo now.
Just a word of warning, I have found it difficult to close the application as it runs full screen and Ctrl+C doesn't work (I assume due to X windows).
KitchUK
I've not built or tried this emulator yet as I want to wait until it's finished, but what is the current average fps with sound currently at?
ric_rpi
Tue Oct 08, 2013 8:20 am
The sound won't work constantly until an average of 60 fps is achieved. I currently get ~45fps with the Legend of Zelda but other games may be playable with sound now.
I still need to integrate keyboard/mouse input and there are several issues with X windows I need to fix.
KitchUK
Tue Oct 08, 2013 8:29 am
Did the orignal N64 games run at 60fps?
ric_rpi
Tue Oct 08, 2013 9:17 am
They do with mupen64plus on a PC in the UK.
welshy
Tue Oct 08, 2013 2:46 pm
ric_rpi wrote: Just a word of warning, I have found it difficult to close the application as it runs full screen and Ctrl+C doesn't work (I assume due to X windows).
Yup it corrupted my card! However, if running straight from Console Ctrl Alt Delete will reboot the RPi safely.
KitchUK
The NTSC console (JAP/UAS) did, the UK version however ran at 50 FPS due to the 50Hz Frequency PAL TV system (As did most consoles and computers using TV Modulators until the late 90's) and if the code wasn't optimised the Image wasn't fullscreen either due to having more scan lines* (it wasn't because they were Widescreen!).
* NTSC 525 (486 Visible) PAL 625 (576 Visible)
marqs
Tue Oct 08, 2013 3:13 pm
welshy wrote:KitchUK
The NTSC console (JAP/UAS) did, the UK version however ran at 50 FPS due to the 50Hz Frequency PAL TV system (As did most consoles and computers using TV Modulators until the late 90's) and if the code wasn't optimised the Image wasn't fullscreen either due to having more scan lines (it wasn't because they were 'Widescreen!).
Let's not mix fps and Hz. While NTSC N64 games are 60Hz and PAL games 50Hz, only a handful of games ran at full 60/50fps (F-Zero X is the only one that comes to my mind). Most games updated the screen only at every other or third vertical sync interrupt (results to 30/20fps on ntsc).
ric_rpi
Tue Oct 08, 2013 3:14 pm
KitchUK
Sorry about that, I'll see if I can get it drawing in a window instead of full screen to make closing it easier.
welshy
Tue Oct 08, 2013 3:26 pm
ric_rpi
No Probs! That's testing for you!
welshy
Tue Oct 08, 2013 3:29 pm
Agreed, it all gets very complicated for the non-technical, I was trying to summerise for simplicity without writing a whole page of exposition!
welshy
Tue Oct 08, 2013 4:20 pm
ric_rpi
Update - Running from Console Ctrl & c quits with no issues. Users just be aware running in XWindows doesn't allow quit or reboot resulting in possible Card Corruption (As happened to me!).
mystara
Tue Oct 08, 2013 4:31 pm
ric_rpi
I literally made an account to tell you that these projects are the reason I'm planning on a minor in CS; seriously awesome work!
I'll be sure to post my input for your debugging, as with my limited knowledge of CS, that's probably the most I can do. Keep it up!
liz
Tue Oct 08, 2013 7:16 pm
mystara wrote:ric_rpi
You have *no idea* how good that makes us feel - thank you very much, and good luck with the CS part of your course!
Return to “Gaming”
