nemo93
Marvel First Alliance 2 (OpenBoR)
Wed Jul 30, 2014 10:21 am
Hi Guys,
I just saw this and it looks awesome!!!! This project is based on the OpenBoR engine and I was wondering if there is a chance to get this working on the Pi? I've seen a post in this forum about a successful compile of OpenBor but it would be great to have a guide or some guidance to properly compile and make MFA2 to work!
http://www.zvitor.com.br/projeto/mfa2.html
Thanks a lot!
welshy
Re: Marvel First Alliance 2 (OpenBoR)
Wed Jul 30, 2014 10:40 am
nemo93
From a quick check, looks like its Windows only at present. At a minimum It would need a Linux version to be made available.
Jessie
Wed Jul 30, 2014 9:53 pm
Someone got openBOR compiled and the fps was in the 3 to 8fps range. Not what I would call playable.
mgoulart
Thu Jul 31, 2014 9:40 pm
I tried to compile OpenBoR few months ago but the gamespeed is terrible (~10 fps). The OpenBoR developer said to change the graphics engine to Allegro 5 but when I tried to compile directly no RPi, I got many random errors (Segmentation Fault). I don't know how to do it but you can compile it on any PC changing the processor architecture to ARM
grizzybeard
Wed Mar 25, 2015 2:36 pm
OpenBOR makefile (works with official repository code) and binary:
https://www.dropbox.com/sh/mligl85vwmic ... FQc8a?dl=0
Runs OK on pi2- including with MFA2.
Problem with running in full screen though. The window size stays the same, so if a pak is 320x240 creates a 320x240 square with giant black borders. Anyone had a problem with this before?
It has an option to stretch to full screen but it doesn't seem to work. Built with SDL.
Return to “Gaming”
