As i'm making gaming consoles from RaspberryPi with EmulationStation i wanted to share a little thing that can really change user experience : get rid of all terminal texts and logs, on boot and when loading games.
There are many posts on the net where you will find that you can change the default tty in /boot/cmdline.txt (console=tty3 in place of console=tty1) but it changed nothing on my configuration.
So here is the procedure :
- edit /boot/cmdline.txt and remove the console=tty0 directive, add logo.nologo and vt.global_cursor_default=0
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait logo.nologo vt.global_cursor_default=0
I tried many options, like remove tty1 in /etc/inittab but there was always an issue with one or an other emulator (no input on pifba, unable to open gpsp)... So here is my final modification, and all seems to work well with that : i redirect tty1 output to tty2 in /etc/inittab.
So open /etc/inittab and replace the first tty with :
1:2345:respawn:/bin/login -f pi tty1 </dev/tty1 >/dev/tty2 2>&1
but note that /dev/tty2 replaces /dev/tty1.
The only inconvenient is that you will be able to get a terminal only with ssh then. (alt+fX to change tty does not work anymore)
But when you reboot and only see framebuffer images and emulationstation loading screen that worth it...
