DigitalLumberjack
piFBA enhanced (4 players mode and more)
Sat Nov 15, 2014 5:43 pm
Hi pals,
I made few modifications on piFBA by Squid.
First, thanks to him and all people that allow us to make enraged gaming nights with our friends on ours little raspberries :)
Here we go : https://github.com/digitalLumberjack/pifba
What is up :
- You can now configure d-pad per button (in case sdl does not detect the hat on the controller) so it adds the ps3 d-pad control on all games
- You can now choose a HOTKEY and QUIT Button (I hate accidentally quit with start+select :))
- You can now pass the configuration file as an argument when you start the program in command line like
./fba2x --configfile configfile.cfg
- And the last but not least : You can now play in 4 players mode !
I removed capex from the source, and for now you will have to build the binary. I'll make a binary release soon but now it's time to play.
See you.
Last edited by DigitalLumberjack on Sun Nov 16, 2014 7:59 am, edited 1 time in total.
Jessie
Re: piFBA enhanced (4 players mode and more)
Sat Nov 15, 2014 6:24 pm
Good job. Ps3 support will help getting arcade cabs configured.
mgoulart
Mon Nov 17, 2014 6:48 pm
Amazing news!!!
Do you have any plan to put Capex on source again?
DigitalLumberjack
Mon Nov 17, 2014 8:19 pm
Hi, no plan to put capex in sources or release but you can use the one in squid binaries :)
perest
Mon Nov 24, 2014 7:20 pm
thanks,great job
sth wrong to my pi
./pifba roms/1944.zip
after loading,,,
Segmentation fault
another question : how to rotate fba'screen 90°?
DigitalLumberjack
Wed Nov 26, 2014 9:22 pm
My 1944 runs well...
Did you tried with other roms ?
If you want to rotate the screen it should not be too difficult with few modifications on source code.
perest
Thu Nov 27, 2014 4:21 pm
DigitalLumberjack wrote:Hi,
Now,I know what's wrong,
after I copy roms to the new' pifba/roms/ ,it runs well.
I want to run all shootinggames with the following 3 cfg
./fba2x --configfile 1944.cfg roms/1944.zip
./fba2x --configfile 1944_rotate_clockwise_90.cfg roms/1944.zip
./fba2x --configfile 1944_rotate_anticlockwise_90.cfg roms/1944.zip
can you help to make it ?
DigitalLumberjack
Thu Nov 27, 2014 6:26 pm
Check the new release : https://github.com/digitalLumberjack/pi ... es/tag/0.2
You will be able to rotate games 90° clockwise.
I just used existing code already used to rotate vertical games and i disable that rotation when you set RotateScreen to 1 in the config file :)
perest
Sat Nov 29, 2014 5:30 am
thank you, is it possible to add new game support to this fba such as raiden 2 ?
DigitalLumberjack
Sat Nov 29, 2014 12:24 pm
I don't know.
expandables
Wed Dec 17, 2014 2:01 am
Hi how to choose a QUIT Button? I am using Logitech's F310 Gamepad. I want the middle button be the quit button
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
McCheeseBob
Sat Feb 14, 2015 9:01 pm
Hi there, is there any way to rotate the game 90 degrees counterclockwise?
DigitalLumberjack
Sun Feb 15, 2015 9:26 am
McCheeseBob wrote:Hi there, is there any way to rotate the game 90 degrees counterclockwise?
No I cannot do that. The modification i made for the rotation was just a little if, the code was already written. However the rotation is clockwise. I don't have time to edit the code now but if you want to take a look, begin here :
https://github.com/digitalLumberjack/pi ... pi/run.cpp
Return to “Gaming”
