Hi all,
Our next JDK 7 release (JDK 7u40) will provide support for hardfloat Linux/ARM, which means you will be able to use it with Raspbian. Early access binaries are available here:
https://jdk7.java.net/download.html
Use the Linux ARM 32-bit HardFP one for Raspbian, and the SoftFP one for Wheezy.
This EA should include full Swing/AWT support. Performance should be top notch compared to other JVMs. JavaFX is not included - that is introduced in JDK 8 (also available in early access).
Happy programming!
Henrik (Oracle Java team)
Re: Oracle JDK 7u40 EA hardfloat available
So is this better in any way than the JDK8 release for serverside stuff, specifically http://rupy.googlecode.com?
https://github.com/tinspin/rupy - A tiny Java async HTTP application server.
Probably about the same, but likely more stable since JDK 8 is still in very early EA
swing vs FX, you decidebullen wrote:So is this better in any way than the JDK8 release for serverside stuff, specifically http://rupy.googlecode.com?
So long, and thanks for all the fish!
