I'd love to build a weather satellite receiver station, just need a basic receiver connected to the audio input of the R-Pi which can then do the audio signal processing to generate the images.
I think that this would also be an ideal project for a classroom as receiving and displaying live images from space of earth would be pretty interesting to most kids.
I've been looking at the various software out there today and it is all windows based, can't see any Linux binaries for this application. Anybody know of one?
Cheers,
Colin
Re: Weather Satellite Receiving Station
http://www.wxtoimg.com/ Though it is not open-source, there are Linux builds and you might convince the author to build it against ARM for you.
Also, with sources:
http://atpdec.sourceforge.net/index.html
http://5b4az.chronos.org.uk/pa.....s/apt.html
Also, with sources:
Thanks for that, I'll check it out!!
Cheers,
Colin
Cheers,
Colin
There is no audio input.
Not on board but as the faq states an usb sound device is supported.
Oh right, forgot about that.
Cheers,
Colin
I think that's a great project idea. I've experimented with this myself, and had a great time. Receiving weather satellite images with Softrock I did mine with a "Software defined radio," which would be a great next step once you try it with another radio. General purpose communication receivers don't have enough bandwidth to properly receive weather satellite images, but it will still work. It will probably look fairly nasty.
Another aspect of the project that might be fun with the kids is building a special antenna for receiving the satellite signals. Helical Quad Antenna for Weather Satellites
Cheers,
Colin
If you are interested in radio applications then you might wish to have a look at this: http://sdr.osmocom.org/trac/wiki/rtl-sdr
I very cheap USB dvb-t receiver that can be used as a software defined radio with GNU radio.
The chinese makers have cottoned on really quickly and upped the prices on ebay for ones that definately work by about a fiver but its still great value:
http://www.ebay.co.uk/sch/i.ht.....w=RTL2832U
I have seen in another post someone has made a driver for the RTL on RPi, really even using two RPis(one receive,one processing) and a RTL SDR would still be cheaper than most 137MHz receivers.
From what I understand, the data on 137Mhz is frequency modulated, so why not make a downconverter and use a FM radio to do the demodulation.
The standard bandwidth of a FM radio demod is around 75KHz.
The converter can be preceded by a 137MHz bandpass filter and a low noise amplifier before being mixed with 37Mhz from a crystal controlled local oscillator which would give 100MHz out after some more filtering.
Since a standard FM radio has a tuning range of 88 – 108 MHz, a third overtone crystal for the local oscillator can be chosen so the the weather sat data will be available on an unused part of the FM band.
Then it's a simple matter to work backwards and select a crystal with the correct frequency.
There are plenty of 3rd overtone crystals available in the required range (29MHz to 49MHz).
EDIT:
Car radios are great for this kind of thing as they are fairly cheap, widely available, are synthesized and have pretty good sensitivity.
They also have a proper RF input (closer to 90 ohms then 50 ohms).
Just get a basic model with no fancy RDS features and no high power output as this will only complicate power supply requirements.
An added bonus of many car radios is that they also have a line level audio output which can be fed to a sound card whilst the speaker outputs can be used to "listen" to the signal via a speaker or a pair of headphones.
EDIT:
For the front end filter, a helical type filter could be used as they are pretty simple to tune and offer good selectivity versus number of stages.
Just keep the insertion loss down or this will degrade the overall noise figure.
See below:
See below:
Sorry I can't work out how to edit a post to contain more then two pics in sequence.
Anyhow, below is a schematic for a possible converter using the NE/SA602 IC and a dual gate mosfet as a LNA.
(I modified it from the NXP datasheet which can be found here: http://www.nxp.com/documents/d.....SA602A.pdf).
I haven't tried it but may do so when time permits.
Quite interested in receiving the weather maps/pics myself.
The main reason the FM broadcast receivers don't work is noise. The WX is 25KHz wide and FM is 125KHz wide. I wish you could simply up-convert, it would have saved me a lot of time & money building WX sat receivers. Playing with RTLs now, and will soon have one on WX duties. I would definately like to try a RPi as the receiver, using a RTL but probably won't be sent a RPi til next year.
Keep in mind that we have to add extra for Doppler shift so a bandwidth closer to 40 or 50KHz is what would be required.
The extra bandwidth of the FM receiver shouldn't be a problem if the noise figure of the receive system
is kept low and we have sufficient gain by using a good antenna system and LNA.
I'm also waiting for my Pi but in the meantime I think I will build some "turnstile" dipoles from some
aluminum tubing housed in some PVC tubing.
Have found some low noise GaAsFets made by HP so will probably make a LNA from one of those and try out the FM convertor idea feeding the audio output to a XP box I have here.
If the results are not that great then I reckon I'll have a go at replacing the FM receivers I.F. SAW filters
with one of these:
http://parts.digikey.com/1/parts/403992 ... 7-30a.html
It may need some simple matching to bring the impedance closer to the "cheaper" ceramic type SAW
filters found in FM receivers.
Still much easier and cheaper then buying or building a dedicated receiver.
with one of these:
Did a "quick and dirty" simulation to see what it would take to match the xtal filter with an impedance
of 5k ohm and about 0.5pF to a ceramic filter which have an impedance of around 330 ohms
in parallel with 10pF.
It shows an expected loss of around 12dB which could easily be overcome with a single stage of amplification.
http://s16.postimage.org/yph2pr9bp/IF_FILT_SIM_1.jpg
- yv1hx
- Location: Now an expatriate, originally from Zulia, Venezuela
Please have a look to this site: http://www.df2fq.de/english_version/r2fx_eng.html, maybe is a bit expensive, but may be worth the effort.
Marco-Luis
Telecom Specialist (Now Available for Hire!)
http://www.meteoven.org
http://twitter.com/yv1hx
I know this is an old thread but did anyone get software working to decode the signals.
Have dedicated 137Mhz receiver, antenna etc, but would like to free up the windows computer for other things.
Name is Mike, Radio Ham and Weather Nut.
Total Beginner with Rpi Zero
- yv1hx
Long time ago I downloaded from-i-dont-remeber-were a program called "wxapt".UK_Ham wrote:I know this is an old thread but did anyone get software working to decode the signals.
Quote from the help file:
wxapt is a non-interactive command line tool for decoding weather images transmitted by satellites using the APT format. Currently wxapt can decode images in the American NOAA and Russian Meteor satellite APT formats. Images are decoded either in real time, direct from the receiver's o/p and through the computer's sound card, or from a file of sound samples recorded by wxapt.
I still have that program in my backup disk, however, I never tried it. If you like to test, I can put the files in a dropbox link for you.
73's & DX,
Marco-Luis
Thanks for your reply, I need to find other bits first and check it is all still working, Also need to find my USB sound input stick.yv1hx wrote:Long time ago I downloaded from-i-dont-remeber-were a program called "wxapt".UK_Ham wrote:I know this is an old thread but did anyone get software working to decode the signals.
73's & DX,
- yv1hx
Drop me a line anytime.UK_Ham wrote:Thanks for your reply, I need to find other bits first and check it is all still working, Also need to find my USB sound input stick.yv1hx wrote:Long time ago I downloaded from-i-dont-remeber-were a program called "wxapt".UK_Ham wrote:I know this is an old thread but did anyone get software working to decode the signals.
73's & DX,
Good luck!
Marco-Luis
