thagrol
STICKY: Using fstab A Beginner's Guide
Fri Feb 05, 2021 7:33 pm
There seems to have been a resurgence in folks having problems adding entries to /etc/fstab (not that that every really went away).
Many of the online resources I've seen are either incomplete, poor, or just plain wrong and often don't cover what to do when things go wrong.
As one of the folks who try to help with this, I figured I'd brain dump and throw something together.
First draft so likley a bit rough around the edges.
Released under a Creative Commons Attribution-NonCommercial-ShareAlike 4.0 International (CC BY-NC-SA 4.0) license
Zipped PDF attached:
fstab.zip
(119.31 KiB) Downloaded 21 times
2021-10-14: New version. Previous version available on github.
Change Log:
  • Addressed github issue #3
  • Updated 11.1 with additional systemd mount options
  • Changed heading for 11.3 to include exFAT
  • Adjusted page breaks
  • Corrected date in previous change log entry.
jahboater
Re: Using fstab A Beginner's Guide
Fri Feb 05, 2021 8:21 pm
Very impressive and likely very useful!
One problem I have seen more than once is the lack of ownership etc on FAT filesystems.
Perhaps a few words about how they are "faked" in Linux?
Also a short description of some common mount options, especially for ext4 since it is the most used FS?
bls
Fri Feb 05, 2021 11:20 pm
This is great! Seems fairly complete for a first go. Is there a way to make Troubleshooting bold in the TOC so that people are less likely to miss it? :lol:
The only suggestion I'd have is an advanced section along the lines of the "making things more secure" section for using x-systemd-automount, x-systemd-idle-timout, etc.
PS Love the 'password=derf' :lol:
Pi tools:
thagrol
Re: STICKY: Using fstab A Beginner's Guide
Mon Feb 08, 2021 12:27 am
Updated version.
From the change log:
2020-02-08
Numerous tweaks
Add two new trouble shooting items: 9.3 and 9.4
Added section 11
fstab.zip
(118.52 KiB) Downloaded 328 times
nrajesh
Sun Feb 21, 2021 12:03 am
can you update this doc for exfat ?
Would it change anything in the instructions?
thagrol
Sun Feb 21, 2021 12:22 am
Possibly but no promises as to when.
Only a single mount option. On current RPiOS "umask=000" is not neccessary as with the exFAT driver that is the default. However including it does no harm.
Edit: and the fs type, obviously.
thagrol
Sat Mar 06, 2021 8:21 pm
No new revision will be made.
After my recent experience I'm giving up on trying to help folks. It just isn't worth the hassle.
Mods please lock.
CaptainMidnight
Mon Mar 08, 2021 9:03 am
I do understand your point of view, as some replies on these forums are questionable at best... it's just a shame the minority can spoil this resource for the benefit of the majority.
Anyway, if possible I was just after a clarification of your final point on page 8 wrt choosing to make the mount point read only. I read this as if the mount point was just /mnt instead of /mnt/folder - assume it's choosing to make the former (/mnt) read only, which is the scenario that could cause potential conflicts.
"Never get out of the boat." Absolutely goddamn right!
Unless you were goin' all the way...
thagrol
Mon Mar 08, 2021 12:02 pm
It'll only cause problems when the mount fails. Which is the point of doing it.
When the mount fails, with a writeable mountpoit you end up writing to the SD card. Not only can this fill it up, it can also make files appear to be missing should the mount succeed at a later time. They won't be missing they'll be masked by the mount, which also make it harder to track down where your SD card's space has gone.
It's optional, if you're not happy with the potential conflicts don't do it.
DunkPS
Sun Apr 04, 2021 8:48 am
Big thanks !!!
Just downloaded the fstab.zip
Ever day's a school day
useful and interesting
Paul :geek:
Learning Linux in Lockdown
Raspberry Pi Model B Plus, Revision 1.2, 2014
Raspbian Linux 10 - Buster
thagrol
Tue Apr 13, 2021 6:47 pm
Now available on github: https://github.com/thagrol/Guides
neilgl
Tue Apr 13, 2021 10:27 pm
JonG
Fri Aug 20, 2021 10:05 am
Thank you for this excellent guide.
I notice that you recommend using the following for network shares:
defaults,noatime,nofail,_netdev
I found that using noatime with CIFS gives me an error 22 - invalid argument
Here is an example:
//10.100.102.108/User /mnt/User cifs defaults,noatime,nofail,_netdev,username=.........
Once I remove "noatime" it mounts correctly.
I've googled this issue, but I couldn't find any reference to problems with noatime and network shares.
Is this a general problem, or specific to my setup?
thagrol
Fri Aug 20, 2021 10:50 am
That's a mistake on my part. Thanks for pointing it out.
I'll correct in in the next update.
Udab
Mon Sep 27, 2021 6:20 pm
How i can set my external USB disk to automount at every boot?
thagrol
Mon Sep 27, 2021 6:27 pm
See the guide: viewtopic.php?f=91&t=302752&p=1815316#p1815316 I'm not going to retype it here for you.
thagrol
Tue Sep 28, 2021 9:42 am
On reflection that was a little harsh.
To briefly answer the question: add it to /etc/fstab starting your mount options with defaults,nofail. More details in the guide.
thagrol
Thu Oct 14, 2021 5:47 pm
New version available. See first post in topic.
Return to “Beginners”
