Boot with number lock on
Hello, I have just got my pi and started using it, I have noticed that the system boots with num lock off, I use the number pad on the keyboard a LOT so this is a bit of a pain, is there a way to change the boot so that number lock is on by default? Thank-you in advance.
Re: Boot with number lock on
Hi magichat,
I'm having the same issue. I use the NUM lock a lot too. Hopefully someone will post a (simple) solution!
First post on Raspberry Pi.
This topic is number 1 on google so I figured I could contribute.Test to see if installed.Make a startup script.Insert this code in vim.
You'll need to set the script.Press "i" to input and Ctrl+C and type ":wq!" to finish.Add this to the bottomSave and reboot!
Edit: Forgot chmod
sudo apt-get install numlockx
numlockx on
numlockx off
cd ~/.config
vi numlock.sh
#! /bin/bash
numlockx on
chmod +x numlock.sh
sudo crontab -e
@reboot cd /home/pi/.config && ./numlock.sh
Edit: Forgot chmod
Thanks LinkCloud,
Much appreciated, I used nano instead of vim as I just can't get used to the annoying semantics of vim, I start gnawing keyboards whenever vim is mentioned
Dan
Dan
Thanks that works fine I use leafpad after startx because I too hate vi & it's ilk.
not sure if you can do it via edting
/etc/kbd/config
/etc/kbd/config
Covfefe
Covfefe
Thanks for the information - you are right (at least with the version of Raspbian that i am running). There is a line in the file that is commented out by default (LEDS=+num). Just remove the '#' character in front of the line, save the file, and reboot and NumLock is set - no other installations or changes are required! But unfortunately if you use the LXDE GUI (startx) it does not inherit this environment setting and it starts with number lock off if this is the only change you make. When you exit back to the console the number lock will be turned back on again.RaTTuS wrote:not sure if you can do it via edting
/etc/kbd/config
Yes, a quick search shows LXDE GUI has number lock default to off.
On GNOME you can set 'remember-numlock-state' using dconf-editor (org>gnome>settings-daemon>peripherals>keyboard) or 'gsettings set org.gnome.settings-daemon.peripherals.keyboard remember-numlock-state true' in terminal.
Likewise, I've found org>gnome>desktop>a11y>keyboard on Raspbian, but no numlock settings
Why a numlock option isn't included in the 'Mouse and Keyboard Settings' preferences tool is beyond me... I've had enough of Linux, and am going back to using my beloved RISC OS
this thread is 4 yours oldRichMoly wrote:Yes, a quick search shows LXDE GUI has number lock default to off.
however I think you can probably do it via the /etc/kbd/config file [LEDS=+num]
Covfefe
Covfefe
Thanks, but as urkraft points out, and hence my reply, the GUI (the horrible IMHO Pixel) ignores the config setting. Besides, why should a user have to edit a config setting for something like this?!
dunno much about pixel however this may work as PIXEL is LXDM
sudo nano /etc/lightdm/lightdm.conf
find
#greeter-setup-script =
and change to
greeter-setup-script = /usr/bin/numlockx on
sudo nano
/etc/xdg/lxsession/LXDE/autostart
and add
it is this way because this is the sensible configuration
why should other people have to edit something to make it as it should be ... [ha!]
find
and change to
sudo nano
and add
Covfefe
Covfefe
Thanks again, I'll give that a try, when I'm with my Pi
Whilst I like having Num Lock on by default, my main reason for it on the Pi is so I can see from the keyboard LED if my kids have left the damn thing on... again!
No fan noise, obscured power LED and supply, and non-functioning DPMS (another setting I have to change in Config I believe) so they turn the monitor off between usage, I guess it's inevitable...
just leave it running - it uses so little power ....
Covfefe
Covfefe
@RaTTuS - your prescription was right on the money.
Thanks for helping! The only correction I needed to make on my pi 3 was the directory to find the autostart file as below. You may have intended to type lxsession instead of xsession.
My kernel/system build is:
$ uname -a
Linux raspberrypi 4.4.38-v7+ #938 SMP Thu Dec 15 15:22:21 GMT 2016 armv7l GNU/Linux
I'm keeping a diary of all these system tweaks. I've needed to make many (from out of the box) to suit my preferences and get basic components of the hardware working properly.
Cheers!
$ uname -a
Cheers!
fixed and yes a typomsjames19702 wrote:@RaTTuS - your prescription was right on the money.Thanks for helping! The only correction I needed to make on my pi 3 was the directory to find the autostart file as below. You may have intended to type lxsession instead of xsession.
Covfefe
Covfefe
Not to necro this thread, but...
If you want numlock turned on so that the tenkey works without having to remember to press the num lock key, you can add
to the end of your ~/.bashrc
It won't turn on until you log in, which is okay for me at least, since I can't really do anything with the tenkey until I'm logged in anyway.
If you want it turned on before login (to use the LED as power indicator), I just found a post on the Debian forum
It's a little more complicated, but it works!
Here's the gist in case the link dies:
From a terminal:
All credit goes to user cybermcm on the Debian forum.
setleds -D +num
From a terminal:
- add
pi@raspberrypi:~$ sudo nano /usr/bin/numlock
and save.Code: Select all
#!/bin/bash # Turn Numlock on for the TTYs: for tty in /dev/tty[1-6]; do /usr/bin/setleds -D +num < "$tty"; done
- add
pi@raspberrypi:~$ sudo nano /etc/systemd/system/numlock.service
and save. (Capitalization is important!)Code: Select all
[Unit] Description=numlock [Service] ExecStart=/usr/bin/numlock StandardInput=tty RemainAfterExit=yes [Install] WantedBy=multi-user.target
pi@raspberrypi:~$ sudo systemctl enable numlock.service
- reboot and see if it works for you, too!
Tried this but... "bash: $: command not found " ... Using Raspberry 3 B+
rpdom wrote:
Wow, that's a lot of steps just to get the numlock key on at start-up. Why isn't it the other way around? What percentage of people use the numpad for cursor direction when there are dedicated keys to the left of them?
Raspberry Pi 3 B and B+
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_ID="10"
