ech0
Samba: Mount windows folder
Wed Jul 04, 2012 8:48 pm
I've been trying to access my windows folder on the raspberry for quite a while without managing it.
I right clicked, properties, share the windows folder called "Files".
Then I went on the Raspberry Pi and tried various commands such as Run ->
smb ://192.168.0.14/Files
smbmount ://192.168.0.14/Files
smbmount //Desktop-PC/Files
I tried accessing it in the file manager with the local IP, tried finding a /shared folder on the raspi but can't find that either.
I'd appreciate any help possible to set this up
Thanks in advance guys!
Michael
nickon314
Re: Samba: Mount windows folder
Thu Jul 05, 2012 3:43 am
I have managed to mount a windows directory using a command line 'mount' command.
I can't remember the exact command, but it involves something like "mount -t cifs xxxx".
'cifs' is the directory type.
I also needed to add a username and pasword to the command, and the IP address of the windows PC.
If you are still stuck I can dig out the exact command I used later.
Regards
Nick
SirLagz
Thu Jul 05, 2012 6:05 am
try this
mount -t cifs -o username=<username>,password=<password> //<ip>/<path> /<localdirectory>
Replacing all the <>s with the relevant details.
ech0
Thu Jul 05, 2012 12:35 pm
SirLagz wrote:try this
Didn't work
I get the same result as I would get with the command mount -h
obarthelemy
Thu Jul 05, 2012 1:35 pm
I think there's some weirdness in Windows 7/Vista sharing that throws non-windows PCs a bit off. Sorry, I don't remember specifics ^^ Fixable though.
mikerr
Thu Jul 05, 2012 3:11 pm
Attaching to a windows XP share called "temp" containing a file hello.txt
Make a directory to hold it, and mount it there:
mkdir /tmp/windows
sudo mount -t cifs -o username=administrator,password=secret1  //192.168.1.4/temp /tmp/windows
Now access that folder like any other in linux:
ls /tmp/windows/
hello.txt
mikerr
Thu Jul 05, 2012 4:17 pm
..that's under wheezy image if it makes any difference.
ech0
Thu Jul 05, 2012 4:28 pm
mikerr wrote:Attaching to a windows XP share called "temp" containing a file hello.txt
mkdir /tmp/windows
ls /tmp/windows/
hello.txt
I'm afraid that still doesn't work for me, it just prints out the mount -h command, explaining the usage of the mount command.
samuelellis
Thu Jul 05, 2012 5:36 pm
I know this is a link to an Ubuntu page but it does a good job of explaining mounting of shares on Linux
https://help.ubuntu.com/community/Mount ... ermanently
As it looks like the Debian and Ubuntu share the same method of dealing with shares this may be some help to you
gkmanning
Thu Jul 05, 2012 9:45 pm
Under debian make sure you have the smbclient package
sudo apt-get install smbclient
Check that you can see the windows share (replace <WindowsPCNetBiosName> with the appropriate PC name)
smbclient -L //<WindowsPCNetBiosName>
then the information provide in the earlier posts should work. You might need to provide the -o options as in the previous posts if you username on the Rpi doesn't match that of the PC username.
stevep
Thu Jul 05, 2012 10:45 pm
As far as I can work out Samba doesn't work properly, especially with the Wheezy install. I struggled with for some time and eventually got it to work, after trying and failing with the e-linux tutorial. The key bit for me was to accidentally delete my smb.conf file, and then writing a new one from various bits found at random on the net. I'm no closer to understanding what was wrong with the e-linux tutorial or what I did right, but I can now transfer files between the Pi and my Mac and vice versa. Here's the thread (along with my working smb.conf file):
http://www.raspberrypi.org/phpBB3/viewt ... =27&t=8784
LetHopeItsSnowing
Wed Jul 11, 2012 10:28 am
I has some problems connecting to a windows share and my NAS drive from the Raspberry Pi. Most of my issues just came down to incorrect config. I posted some instructions on my blog (to save my sanity next time I needed to do it!), they might be useful for you http://stuffaboutcode.blogspot.co.uk/20 ... share.html
LHIS
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
xfx
Mon Dec 31, 2012 12:08 am
mikerr's solution worked great for me.
Thank you!
