ahaz86
Cant get autostart to work
Thu Jan 07, 2016 9:19 pm
Hello, I have read through many posts on here about getting autostart working on the pi 2 running Jessie.
Things I have tried
1. Edited: sudo nano /etc/xdg/lxsession/LXDE-pi/autostart to include lxterminal
Looks like this now:
@lxpanel --profile LXDE
@pcmanfm --desktop --profile LXDE
@lxterminal
@leafpad
@xscreensaver -no-splash
2. Edited: sudo nano /etc/xdg/lxsession/LXDE/autostart to include lxterminal
@lxterminal
3. Attempted to edit: sudo nano ~/.config/lxsession/LXDE/autostart
The path didnt exist so I created each directory and the file but still no luck.
If I login as root and run the command startx applications launch though (not sure if this helps in figuring out what is going on or not)
None of these launch any application at startup
Any help is appreciated and I apologize in advance for this being such a newbie question!
Alex
malicious
Re: Cant get autostart to work
Fri Jan 08, 2016 5:15 am
ahaz86 wrote:3. Attempted to edit: sudo nano ~/.config/lxsession/LXDE/autostart
Autolaunch worked for root because:
is editing the file for root's profile. Do the same edit as your regular, non-root account and leave out sudo. I am not sure why the autostart file under /etc is not working though.
QuietZone
Fri Jan 08, 2016 5:36 am
malicious wrote: Autolaunch worked for root because:
No. Try: sudo echo ~
And then you will know who expands the ~ (and when).
This is correct advice, though. People should not get in the habit of prefixing every command with those 4 magic letters.
"If you haven't got anything nice to say about anybody come sit next to me." — Alice Roosevelt Longworth
JimmyN
Fri Jan 08, 2016 12:55 pm
Maybe I can help you out a bit.
ahaz86 wrote:Hello, I have read through many posts on here about getting autostart working on the pi 2 running Jessie.
1. That is the global autostart file, and works for all users... unless they have a user autostart. If the user has an autostart file the global one is ignored and the personal autostart is used. User settings are applied last and take precedence over global settings. Jessie creates a user's autostart file during the install, so changing settings in the global file no longer have any effect.
2. That is the "old" location, the new location uses "/LXDE-pi/". The "/LXDE/" directory may exist, but it will be ignored.
3. That attempt is close, but should have been "/LXDE-pi/" rather than "/LXDE/". Before Raspbian started including the users autostart (and switched from LXDE to LXDE-pi) you had to create your own "/lxsession/LXDE/autostart" to override the one at "/etc/xdg/". If you had used "nano ~/.config/lxsession/LXDE-pi/autostart" you would have been editing the correct autostart, but using "/LXDE/" it created a new file instead, but of course it won't use it.
To add to or edit your user's autostart:
That file belongs to the user so don't use "sudo" to edit it.
ahaz86
Fri Jan 08, 2016 7:19 pm
JimmyN wrote: To add to or edit your user's autostart:
THANK YOU SO MUCH!!!! Ugh... I cant believe it was this simple.
gordon77
Fri Jan 08, 2016 7:33 pm
It's usually easy when you know the answer :D
JimmyN
Sat Jan 09, 2016 1:00 pm
ahaz86 wrote: THANK YOU SO MUCH!!!! Ugh... I cant believe it was this simple.
You were all around it but hadn't quite hit the right combination. :D
drips
Sat Jan 30, 2016 10:46 am
Hi. Sorry for bumping, but I still have the same problem.
I am very new to Raspberry Pi and Raspbian, so it may be a simple solution.
I am trying to autostart midori, but the Pi just boots to the default screen. I've done what you guys said and used the autostart
" nano ~/.config/lxsession/LXDE-pi/autostart "
And this is what my autostart looks like:
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
#@xscreensaver -no-splash
@xset s off
@xset -dpms
@xset s noblank
@midori -e Fullscreen -a http://google.com
I appreciate all the help I can get!
muuh
Tue Feb 28, 2017 11:10 pm
same here (for 2017-02-16-raspbian-jessie), by trying to start a script with
@~/.script.sh
where ".script.sh" is chmod 744 (or 777). the script works by manually starting it. any hints?
KLL
Wed Mar 01, 2017 6:40 am
muuh wrote:~/.script.sh
? what is the file name?
i think its script.sh or absolute /home/pi/script.sh or ~/script.sh
to start it use
./start.sh
but when you are not in /home/pi/ must start it with
. ~/script.sh
where there is a "blank" between "." and "~"
! this has nothing to do with the way you want do auto start, just with the way to call your file !
gordon77
Wed Mar 01, 2017 1:29 pm
drips wrote:Hi. Sorry for bumping, but I still have the same problem.
@xset s off
@xset -dpms
@xset s noblank
I tried this on mine and it works , BUT I needed to 'sudo apt-get install midori ' first..
I use the latest Raspbian (NOT Noobs)
@point-rpi
@xset s off
@xset -dpms
@xset s noblank
wheresmattdamon
Wed Apr 25, 2018 1:57 am
@~/.script.sh
Hi, sorry to bump the thread.
For anyone coming here in the future, to autostart a ".sh" script, you need to add "sh " between the "@" and the file path, so that your entry looks like "@sh ~/.script.sh" instead of "~/.script.sh".
Ryan780
Fri Dec 11, 2020 10:13 pm
Does this solution not work anymore? Because for the life of me I can't get it to work . And there is no more .config/lxsession directory to hold an autostart file. So, I don't really know what to put in a new one.
klricks
Fri Dec 11, 2020 10:20 pm
Have a read here: viewtopic.php?f=66&t=294014
3B+ & 4B4G Running RPi OS Bookworm w/ Desktop
