Triffgits
[Solved] AP + Client using BCM43143?
Sun Jan 31, 2016 5:07 am
Is it possible to connect my raspberry pi to my router via the official raspberry pi wifi dongle and use it as an access point as well?
Re: AP + Client using BCM43143?
Sun Jan 31, 2016 9:15 am
No. A dongle can only run as an infrastructure client or an access point, not both at once. You'd need two dongles.
Triffgits
Sun Jan 31, 2016 9:58 pm
Thanks, marking as solved.
glynhudson
Re: [Solved] AP + Client using BCM43143?
Fri Mar 18, 2016 12:42 am
I think AP + client mode could be possible with BCM43143. I have a Pi3 which has the same chipset
$ iwlist
Returns:
valid interface combinations:
                 * #{ IBSS, managed, AP } <= 2, #{ P2P-client, P2P-GO } <= 1, #{ P2P-device } <= 1,
                   total <= 3, #channels <= 2
Which suggests that managed + AP mode is possible
I have AP mode running using hostapd on wlan0, I have tried adding a second wlan1 interface to /etc/interfaces but get error
Cannot find device "wlan1"
Bind socket to interface: No such device
When I try and bring it up. How can a second WLAN interface be bind to the network device for use in client mode at
Return to “Beginners”
