Ivan219
Mencoder on jessie
Sat Mar 12, 2016 9:41 pm
Hello, i try to use mncoder for make timelapse on jessie,
sudo apt-get install mplayer mencoder
I get:
E: Package 'mencoder' has no installation candidate
How to install it? Or may have an analogue?
Re: Mencoder on jessie
Sat Mar 12, 2016 10:11 pm
Ivan219 wrote:Hello, i try to use mncoder for make timelapse on jessie,
I get:
Jessie has changed packages: viewtopic.php?f=66&t=123442
Ivan219
Sun Mar 13, 2016 6:10 pm
Sorry, i don't understand. What must I do?
Sun Mar 13, 2016 6:34 pm
Ivan219 wrote:Sorry, i don't understand. What must I do?
https://wiki.debian.org/ffmpeg
sudo apt-get update
sudo apt-get install mpv
sudo apt-get install libav-tools
Ivan219
Sun Mar 13, 2016 7:00 pm
I have done this commands. And how to run:
sudo mencoder -nosound -ovc lavc -lavcopts vcodec=mpeg4:aspect=16/9:vbitrate=8000000 -vf scale=1920:1080 -o timelapse.avi -mf type=jpeg:fps=24 mf://@stills.txt
Sorry, I'm still new
kyle2k
Sun Mar 13, 2016 7:50 pm
You now create your timelapse with avconv command.
the code below will take all .jpg called test_0001 (and upwards) files in the current directory and create a video called test_timelapse.mp4 at 10 fps
avconv -r 10 -i test_%04d.jpg -r 10 -vcodec libx264 -crf 20 -g 15 test_timelapse.mp4
See this link for a tutorial and explanation of the code used.
https://www.raspberrypi.org/learning/cr ... worksheet/
Regards Kyle
Ivan219
Sun Mar 13, 2016 8:42 pm
Thank you for reply. My files has number with time, for example: foto_1425121203.jpg, foto_1433371203.jpg
How to write mask with "foto_"+number_time?
kyle2k
Sun Mar 13, 2016 10:10 pm
Hi again,
If you want to make a timelapse from pictures you have already taken then you could try the code below.
avconv -r 10 -i foto_%10d.jpg -r 10 -vcodec libx264 -crf 20 -g 15 test_timelapse.mp4
The (foto_%10d.jpg) part is assuming your files are incrementally named foto_(and 10 digits).jpg
for future timelapse try to name your files pic_0001.jpg etc........
See the tutorial link I posted in the above post :)
Regards Kyle
Ivan219
Mon Mar 14, 2016 5:01 pm
I try your command and get:
foto_%10d.jpg: No such file or directory
, may be i have this error, because the first name: foto_1421361203.jpg, not foto_0000000001.jpg?
raspberry949
Thu May 19, 2016 3:54 pm
I had a similar problem, and would like to post a fix. You have to rename the files so they are named 000000.jpg, 000001.jpg, etc:
x=0;
for i in *jpg;
do counter=$(printf %06d $x);
ln -s "$i" /tmp/img"$counter".jpg;
x=$(($x+1));
you may then create your timelapse:
avconv -i /tmp/img%6d.jpg -r 24 -vcodec libx264 -crf 20 -g 15 test_timelapse.mp4
The following script takes pictures with numerical file names. The advantage over raspistill is it takes one picture and then quits, so it won't use memory continuously, and you can put it into crontab and have it work automatically after a reboot.
#!/bin/bash
DIR=/home/pi/timelapse/pics
if [ -f $DIR/000000.jpg ]; then
    NUM=`ls -t $DIR/*.jpg | head -1 | sed -r 's/.*\/([0-9]*)\..*/\1/g' | sed 's/^0*//'`
    NUM=$(($NUM + 1))
    printf -v NUM "%06d" $NUM
else
    NUM="000000"
fi
echo $NUM
fswebcam -S 30 -r 1920x1080 $DIR/$NUM.jpg
